Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Sep 13, 2011 | 01:47 PM
  #2446
4DGS's Avatar
The BBS are wider and lower offset....
Old Sep 16, 2011 | 03:19 AM
  #2447
illest G's Avatar
i ordered a universal air suspension and i didnt want my rims to tuck under the fender, is there anything i can do to get the fender to sit on the lip of the rim. im currently running 20x9.5 20x10. i just want my rear wheels to sit completely flush with the fender. only thing i can think of is doing custom fender work. or maybe extending the axle or some sheit idk ive been thinking about it all day. i dont think i need spacers cause my rear wheel already has a poke. i dont got a fortune to spend on my car. i know this is a stupid question, but ive spent all day looking this up and havent found anything on forums or google. so i decided to just ask someone.
Old Sep 17, 2011 | 12:31 AM
  #2448
fwdsux's Avatar
What offset are the wheels you have?
Old Sep 17, 2011 | 04:21 AM
  #2449
SuckTheDWang's Avatar
what offset will clear my stock brembo BBK and still be as aggressive as possible? im looking to get Varrstoen 1.1.2 rims in size 19x9.5F 19x10.5R
Old Sep 17, 2011 | 02:24 PM
  #2450
XiN's Avatar
XiN
Supersonic... Hypertonic
Itasha Coupe
Offset doesn't affect how much brake clearance you have. It is the disc face of the wheel.
Old Sep 19, 2011 | 05:15 PM
  #2451
4DGS's Avatar
You'll need to know the offsets. But it looks like you need new wheels and I'm going to take a shot in the dark that the wheels are roughly a +20.
If you don't have a fortune an "extended axle" should not have even been sort of a thought.
Figure out the specs on your wheels but I'm going to guarantee the look that you want will not be achieved with the current wheels....
Assuming this is the look you want...
Call varrstoen and ask, this is not a question that can be answered mathematically.
Old Sep 20, 2011 | 07:28 PM
  #2452
BokChoiBoi's Avatar
What rear tire should I get on a 20x11 to match a 225/35/20 on a 20x9
Old Sep 21, 2011 | 02:28 AM
  #2453
4DGS's Avatar
265/35
But you'll need spacers and need to be dropped to pull it off.
Old Sep 21, 2011 | 04:26 PM
  #2454
illest G's Avatar
my wheels are 20x9.5 +15offset r disk in the front and 20x10 +0 o disck in the rear. pretty popular setup for the t1s. i am planning on getting a new setup soon. any advice on offsets and wheel size?
Old Sep 21, 2011 | 05:17 PM
  #2455
cHink's Avatar
Quick question.
so...If i get the 350Z Eibach Sportline it will be more dropped then the G35 Coupe Eibach Sportline for my 06 G35 coupe.. Is this correct?
If yes how much more it would be dropped ?
Old Sep 21, 2011 | 10:29 PM
  #2456
HXS's Avatar
HXS
any of you stretch guys have problems with balancing?
i recently went from 235/35/20 general exclaims to 225/35/20 achilles on my 9.5".
i had no balancing issues with the generals and at high speeds encountered no vibrations.
ever since i switched up to the achilles, i get a slight vibration over 55 mph.
i even road force balanced the achilles, and they still do that.
is it because they're stretched? do stretch tires prevent you from getting that perfect balance?
Old Sep 22, 2011 | 02:00 AM
  #2457
4DGS's Avatar
Originally Posted by *****
Quick question.
.5" more than what it says they drop the Z.
No, stretched tires should never cause balance issues. It's most likely because achilles are so damn cheap. There is probably an issue with the tire itself, be it too much rubber compressed into one side or whatever.
Generals are surprisingly good tires for how cheap they are...
Old Sep 22, 2011 | 11:43 AM
  #2458
HXS's Avatar
HXS
^ i kinda figured that out too, but i just wanted a second opinion.
i'mma try to switch up to the v12's like you recommended...
Old Sep 22, 2011 | 11:49 AM
  #2459
hawaiinpunch's Avatar
I have a set of used Toyo proxy 4 for sale..
I'm running a 235/35 on a 10 would a 265/35 on 12 be an even stretch?
Old Sep 22, 2011 | 03:53 PM
  #2460
4DGS's Avatar
275/35 would be a closer match to the 235/35 but a little more stretch in the bank won't look too silly.
I'd do 275/35 if you have room though.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
