Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Aug 29, 2011 | 10:04 PM
  #2431
agedog2gt's Avatar
Originally Posted by agedog2gt
Wow. This thread is perfect.
my question is:
I am purchasing 20" XXR 521 black with chrome step lip. Im going 10.5 " on tire width all the way around. I to plan on lowering the car as well. I am looking for somewhat of a flush look. Any ideas on tire size for front and rear?
Here is the ad with some specs.
http://cgi.ebay.com/ebaymotors/20-XXR-521-Black-Machine-Lip-Staggered-08-G35-G37-350z-/220828201768?pt=Motors_Car_Truck_Parts_Accessories &hash=item336a62f328
Old Aug 30, 2011 | 01:56 AM
  #2432
4DGS's Avatar
Originally Posted by Cabos G35 Coupe
Are Ventus Sport K-104 good to stretch a lil 235 35 19 on 19x9.5?
Yea those are fine.
Originally Posted by LILShiraz
I'd run stocks, but if I had to choose it would be the second one.
my question is:
I'd recommend rolling the rear and throwing a 15 or 20mm spacer on the rear and a 10 or 15 on the front.
As for tires, 275/30 would be ideal, but it's a pretty large tire up front. Depends how low you want to go.
Old Aug 31, 2011 | 01:08 AM
  #2433
agedog2gt's Avatar
I don't want to sit hellaflush but I mean I want to sit pretty low. 275 all the way around??
Old Aug 31, 2011 | 02:11 AM
  #2434
SEDANFTW's Avatar
will I need any more fender work if I run 19x9.5 +10 19x10 +10 on an 05 sedan? my rears are cut but my fronts are stock. also, what would the amount of negative camber look like if I were to run these?
Old Aug 31, 2011 | 09:07 AM
  #2435
xXThirty-FiveXx's Avatar
Tire pressure question. 4 days ago, my low tire pressure light came on. I checked the tire, and sure enough it was at 28 psi. So I filled it back up to 35 psi. This morning driving home from work, it came on again. I check my tires, all fine but the one I had to fill and it is back at 28 psi. I can't find a hole in the tire. Do I have a rim leak? How do I find this leak and fix it?
Thanks G forum!
Old Aug 31, 2011 | 12:18 PM
  #2436
4DGS's Avatar
Why do you want to run a 10.5" up front? yea 275, but this isn't an ideal set up.
What tire sizes? You're getting pretty aggressive with those specs. You're going to need at least a 225/35 up front and 225/35 or 235/35 in the back. Cut fender won't help you, you're going to need to roll and pull and add about -4 degrees of camber.
Thanks G forum!
Take it to a wheel shop and ask them to reseat the tire in question, it could just be a small leak caused from some dirt on bead. If you want to find the issue yourself, remove the wheel and spray some soapy water around the edge of the wheel. If that doesn't work start spraying it around the tread until you seem some bubbling from the air escaping.
Old Sep 2, 2011 | 12:15 AM
  #2437
simin510's Avatar
Hey guys
I'm getting wheels that are 20x9.5 and 20x10 +15 all around
Do you think 255/30 and 285/30 will rub
I'm pretty low as well. Thanks
or should i just stick with 245/30 and 275/30?
Old Sep 2, 2011 | 09:23 AM
  #2438
4DGS's Avatar
Are your fenders rolled?
Old Sep 2, 2011 | 12:33 PM
  #2439
simin510's Avatar
Yea I will roll the fenders, do I even need to touch the fronts ?
Old Sep 5, 2011 | 04:23 PM
  #2440
4DGS's Avatar
With a rear roll you'll be fine. If the front rubs pull the fender liner screws out.
Old Sep 9, 2011 | 12:49 AM
  #2441
007JD's Avatar
hey..
i have 04 sedan
and gonna have tein basics on and wana go as low as possible
the rims i have are 20x8.5 n 20x10 wit offset of 40mm for both
u had recomended 245/35/20 n 275/30/20
i wanna know if i go low as possible on my teins.
will i rub or hit anything ?
or worry about anything else
my fenders will be rolled
a fellow other g member that lives around my area
is running 245/35 on 19s i believe and hes on teins mono flex. lowered pretty low
and he says he rubs infront and back wen hits a small bump or dip
Old Sep 9, 2011 | 01:57 AM
  #2442
4DGS's Avatar
No that offset should not rub.
Old Sep 9, 2011 | 07:27 AM
  #2443
007JD's Avatar
and if i put spacer then ill rub ??
and thank you for your fast response
Old Sep 9, 2011 | 03:33 PM
  #2444
4DGS's Avatar
Depends what size spacer, in the front you could probably handle a 15 or 20 without rubbing but the rear you may start to rub with just a 10, you'll have to see what you're camber is at to really know what the rear can handle.
Old Sep 10, 2011 | 07:05 PM
  #2445
LILShiraz's Avatar
I narrowed my search to these 2 for a winter set. Looking to buy soon. Which would sit more flush?
http://washingtondc.craigslist.org/n...590547242.html
or the original 350z wheel?
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
