Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
  #2521
Old 10-15-2011, 12:53 PM
crazy8ship's Avatar
I'm not sure of the offset or the width. I think they are 9.5 or 10 though. Is the offset marked on the rim at all. I will have to go to my parents to check them. I have no room at my house for them plus my mustang is still sitting in their garage in pieces.
Originally Posted by 4D05G35
You should be fine. A lot of people run 275/30/19 rears. Do you happen to know the offsets and widths?
  #2522
Old 10-15-2011, 01:23 PM
Jamie's Avatar
Ok. I'm on a budget so
Will these fit an 04 with brembos?
I am prepared to roll the fenders
275/35/20
235/35/20
Size: 2 Front Rims are 20X9.0 +15 offset
Size: 2 Rear Rims are 20x11 +15 offset
Bolt Pattern Single Drilled : 5x114.3 (5x4.5)
Any advice will help
http://www.ebay.com/itm/20-9-11-XXR-...ht_4800wt_1270
  #2523
Old 10-15-2011, 11:26 PM
4DGS's Avatar
^ call the company. Offsets and widths don't warrant brake clearance.
  #2524
Old 10-16-2011, 12:29 AM
4D05G35's Avatar
I dont recall if TSW puts the offsets on their wheels or not, but I did a little digging.
If you have a square set-up you are probaly looking at 19x9.5 +35mm offset and it you have a staggered set-up you will have a 19x8 +20mm or +40mm offset up front with the 9.5 rear. Either way those will fit, but you are going to want to add spacers to make them a little more flush (they wouldn't good good tucked in). Both vehicles run the same bolt pattern so I would just bolt them up and then take measurements. Is the car lowered?
  #2525
Old 10-16-2011, 12:35 PM
crazy8ship's Avatar
I might go try them today. I can't lower my car. I wouldn't be able to get in my drive way. I have to go on an angle as it is. It dips of the road and then is a pretty steep hill. I need to get it fixed but don't want to spend the money if I'm going to move in a year or two.
  #2526
Old 10-16-2011, 02:42 PM
Jamie's Avatar
Thanks
  #2527
Old 10-16-2011, 03:11 PM
twestman's Avatar
With slight camber a 19x11 +25 will rub strut.
You're going to have to be sub +20 offset with an 11.5 HOWEVER, Aaron (Gsedan) rand 20x11 +36 with his camber zero'd
You should have room to move in there just remember every degree of camber is 5mm of offset.
Awesome... The *coupe* and sedan clearances are not the same though, am I correct?
Thanks
  #2528
Old 10-17-2011, 01:50 AM
4DGS's Avatar
No, they're identical. Same car, same suspension.
The OUTER clearances are different.
  #2529
Old 10-17-2011, 02:24 AM
twestman's Avatar
Gotcha. Thanks!
  #2530
Old 10-17-2011, 03:23 AM
4D05G35's Avatar
Just be aware that the 245/35/19 front tire might look really small with the increased fender gap from the smaller overall diameter tire. I ran that tire size breifly when my sedan was lowered about 1.25" and even then they looked small to me. Try it out and post some pics Or at least let us know of the outcome.
  #2531
Old 10-17-2011, 10:35 PM
a471133's Avatar
Need some help with my winter setup. Just picked up some used Asa jh3 18s. My question is about hub bore. I know the 04 coupe has a 66.x mm hub diameter. I've tried to google the Asa hub bore diameter, but it's an older model and I can't find the bore diameter specs. I've searched and can't seem to if any other g drivers use the hub centric spacer rings to center the wheels, and in particular the ID and OD of the rings. Any help would be great. Thanks.
  #2532
Old 10-18-2011, 01:10 AM
4D05G35's Avatar
Measure the wheel bore, then get a ring that has that outside diameter with a 66.1mm inside diameter.
  #2533
Old 10-18-2011, 08:50 PM
crazy8ship's Avatar
I put them on today. I think they look good. I will take a couple pics tomorrow in the sunlight and post them. I wish I could lower the car but I will need to get the driveway raised first.
  #2534
Old 10-19-2011, 04:36 PM
crazy8ship's Avatar
Here are some pics.
  #2535
Old 10-19-2011, 08:07 PM
P10 WRC's Avatar
allright everyone, i need new front tires allready since i waited too long for an allignment. I have 235/35/19's on a 9 inch wheel now and am looking for advice. Once my rears go out i will get new ones back there too. for now, i want a bit more of a stretch then they currently have.
i was thinking about 225/40/19 to keep the diameter close to the 255/35s out back. once the rears go i will go with 245/35 out back. My question is on tire brand. I have found that size anywhere from $150/tire to $275/tire. The KDWs i have don't come in the size i want so i will have to change.
Are generals, hankook, or khumos okay for stretching? here are the choices on tire rack
http://www.tirerack.com/tires/TireSe...40&diameter=19
I want to stay under $200/tire
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
Quick Reply: Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
