Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Feb 19, 2012 | 11:43 AM
  #2836
AnmoreG35's Avatar
Hello, new member here
I have a stock 2004 G 35 sedan Aero package and would like to know if i can install non staggered 18x8 wheels with 40mm offset without any issues
Any info would be greatly appreciated
Thanks to all
Old Feb 19, 2012 | 12:09 PM
  #2837
dub_clutch's Avatar
Well I'm not 100% sure but 40mm offset might give u sum rubbing I suggest a smaller offset under 35 IMO
Old Feb 19, 2012 | 12:27 PM
  #2838
AnmoreG35's Avatar
Hi and thanks for the reply, my car still has the stock wheels 17x7 on it
I am surprised as I see alot of similar cars with 19 etc on them
The wheels i am looking at are not staggered if that makes a difference on the rubbing you mentioned
Thanks again man
Old Feb 19, 2012 | 12:34 PM
  #2839
dub_clutch's Avatar
It bein staggered isn't the issue u could got wider wheels on there the only problem I c is the offset cuz wit a 40mm offset u risk it hitting the suspension or brakes
Old Feb 19, 2012 | 12:44 PM
  #2840
AnmoreG35's Avatar
Thanks for that, I am a little frustrate as I have an opportunity to buy some wheels at a smoking price but they are the 40mm offset
i am having difficulty finding 18x7 for sale
Thanks again
Old Feb 19, 2012 | 12:49 PM
  #2841
dub_clutch's Avatar
Well u can get them but u would more than likely have to get sum spacers
Old Feb 19, 2012 | 04:32 PM
  #2842
iamchris's Avatar
Quick question. I'm going to rebarrel my rims.
The fronts are 20x9 +37 offset with a 1 inch lip.
The rears are 20x10 +40 offset with a 2 inch lip.
Now I'm rebarreling the front lips to a 4 inch lip and the rear to a 5 inch lip. What would my width and offsets become? I'm not trying to run any 20x13 or trying to undergo major body work to fit these on my car. Any help is appreciated!
Old Feb 19, 2012 | 04:35 PM
  #2843
andrewyfang's Avatar
2 inch > 5 inch = 20x13... You'll need bodywork.
Old Feb 19, 2012 | 04:47 PM
  #2844
4DGS's Avatar
Originally Posted by RastaManMax
Don't want to roll the fenders because there's a ton of salt used here and there's already some rust developing in my fender liners so rolling just makes it harder to clean in the winters. I'm likely going to get the rust removed from in there at the start of summer then just POR it and run some decent wheels.
Just get the inner fender undercoated and you're fine....
So the 19*9 +10offset should work and the 19*10 +15 should be good without a roll and you're saying that the 19*9.5 +15 and 19*11 +28 would also fit without a roll?
Yes, as long as the rear doesn't rub strut.
Call me insane but I also don't mind a little bit of a tuck with the wheels - looks a bit more natural to me than having them perfectly flush or even sticking out. Since I may be tracking the car on occasion, (and too lazy at times to swap back to my OEM 18's all the time), i'm tempted to go with the 9" and 10" setup for slightly lower rotating mass and slighty cheaper tires.
If you plan to track you NEED to roll the fenders. the amount of body roll these cars have you will definitely be cutting sidewall. If you plan to track, you want 19s, not only for tire cost but for weight.
Thanks for the help!
Originally Posted by GAU-8
Within the next few months I want to swap out the OEM wheels. I tried reading the first few pages and very little applied to the sizes I'm looking to do. '06 Sedan with stock Z suspension (coils, struts, shocks all revised setup). Currently on OEM 10-spoke 18's and 20mm CZP spacers. Interested in the XXR 526 Black Chromium in 18X9. They list offsets of +35 and +25. From what I got off of the back of the OEM wheel is 42mm offset. With 20mm spacers, that puts me at 22mm offset. Correct? If not, where did my math go wrong? If correct, then I shouldn't have any issues putting the +25 option 18X9 wheels on? Meaning no fender rolling or pulling or cutting sidewalls with suspension travel? I'm not looking for "hellaflush" or staggered. I just want to line up the side real nice. I want to retain the proper tire diameter for the 18" wheels, so I need some recommendations for the proper tire to go on these without stretching sidewalls to get them on. No super low profile options please.
Please use the return button and break up your sentences.
Math is right...
You'll want to roll the rears for this set up.
Tires I would run are 255/40 all the way around.
Originally Posted by dub_clutch
I haven't got any pix yet I'm waiting to get sum new coilovers to put the wheels on there n I actually have the coupe wit sport suspension
Yea.... sedan and coupe are different due to the fenders. Please read before you try to hand out advice.
Originally Posted by AnmoreG35
Hello,new member here with a bone stock 2004 G35 sedan Aero package
Just wondering if you could share some insight; I need to know if 18 x 8 , 40 mm offset wheels will fit my car with no issues. The rims are not staggered and the tires I plan to match them with are 235/55/18 zr tires
Thanks very much
You'll have room for a 10mm spacer no problem and that tire size is not what you want. You will be much better off with a 245/40.
Thanks to all
Look above, you're fine.
Again, stop giving advice on sedans when you barely know the coupe.
Thanks again man
Ignore what was said, your set up will be fine.
1. 18x8 +40 is about 2 inches from the suspension
2. Offset has nothing to do with break clearance.
Thanks again
Do the 18x8 +40
Final specs will be
20x12 +1
20x13 +4
You'll need a full rebarrel to get decent sized lips on those wheels.
In all honesty, 5 inch lips come with some work you aren't just going to slap a wheel with 5 inch lips onto the car unless they like the XXR 526 or PIAA super rozza where they have a convex face giving the illusion of a wider lip.
Old Feb 19, 2012 | 05:52 PM
  #2845
iamchris's Avatar
So weird . I was talking to a rep from wheel flip who specialize in this and asked him about doing my fronts. He quoted me just for a lip rebarrel. And told me this.
Judging by the picture, I estimate that your front lips are about 2". If you want to make it a 6" lip, then your resulting size will become 20x13 -14 which is incredibly difficult to fit on your car. I would say that 20x10.5 +19 or 20x11 +12 are better options for a Lexus GS. That leaves you with roughly 3.5-4.5" of lip depending on the current sizing.
Is he wrong, or am I crazy.
Old Feb 19, 2012 | 05:55 PM
  #2846
4DGS's Avatar
No, he showed you the specs for relipping the front to have a 6" lip, not the rear.
Which is dumb, because the rear has a higher offset which would make it easy to fit in the long run. You're still never going to fit those on your car without knowing what you're doing.
And why is he talking about a GS?
Old Feb 19, 2012 | 06:38 PM
  #2847
Drew113's Avatar
Ban Hammer Expert
Hey Blaine could you give me a quick run through on the difference in offsets for coupes and sedans in terms of flush, poke, and extreme
I'm more versed on coupes so if you could give me an idea what offsets are flush for sedans and what offsets require modifications other than just rolling fenders
Old Feb 19, 2012 | 06:40 PM
  #2848
iamchris's Avatar
My original plan was to relip the fronts to 5 inch, swap those to the rear, and put my old rears in the front, after remounting the tires and whatever. . He said I was able to achieve a 20x11 +12 with a 3.5 to 5 inch lip, which is fine for me. But then after telling you guys about my specs, it would actually be a 20x12 +1? The specs he gave me after the relip are completely different than what you guys told me that's why I'm sort of confused here
Old Feb 19, 2012 | 06:42 PM
  #2849
bchalks's Avatar
What size spacer would I need for flush fitment in the front? Car is a coupe.
Specs are: 245/35/20 on a 20x8.5 +32
Thanks
Old Feb 19, 2012 | 06:48 PM
  #2850
Drew113's Avatar
Ban Hammer Expert
^is that a square fitment or are those just front specs?
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
