Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Jun 3, 2012 | 11:26 PM
  #3586
vq35dedriver's Avatar
Originally Posted by 4DGS
Width?
My bad, 19x9.5 +12 and 19x10.5 +12 for an 06 G35 Coupe
Old Jun 4, 2012 | 03:24 PM
  #3587
HXS's Avatar
HXS
which stretches more on a 9.5": 225/35/20 or 245/30/20?
i know they stretch about the same, but i wanna know which set-up stretches more.
Old Jun 4, 2012 | 05:33 PM
  #3588
4DGS's Avatar
Originally Posted by whoozyadaddy7
Blain, (I cruise the forum a lot so I hope it's not creepy I know your name haha) do you think you could give me some advice on a wheel set up? I am seriously considering picking up a set of wheels, but am only holding back waiting to hear back from a few people on the fender work and modifications required to fit the set up. The rears are 20x12 -4. In an ideal world (being as frugal as possible) I would run a 285/30 that's already available to me. Would it be possible to pull the fenders enough so I wouldn't have to run retarded camber and could run the 285/30's? I'm trying to stay away from ridiculous stretch on the tires because local shops here had trouble even mounting a 255/30 on an 11". Adon's ride has been giving me a pretty good idea of what to expect, and I thought I read he was running a 285/30 or a 275/25. Thanks in advance.
Whats the max amaount of camber you want to run? With a healthy pull and about -5 you can fit those in the back.
295 will rub without camber or a pull.
225/35
Old Jun 4, 2012 | 06:41 PM
  #3589
whoozyadaddy7's Avatar
Thanks for the advice! -5 Isn't too bad, I've been at -3.5 before with a previous set up. Did I read correctly that something around a degree of additional neg. camber will help tuck 5mm more of wheel/tire? So is it rational to assume that with something like a 275/30 tire I could eliminate a degree of camber or close to?
Old Jun 5, 2012 | 08:03 PM
  #3590
NorthDakota's Avatar
04 sedan on eibach prokit
will 19x9.5 +22 with 275/35 tire fit in the rear? I don't have a problem rolling the fenders.
Old Jun 5, 2012 | 10:02 PM
  #3591
usingthejohn's Avatar
well, just got my Work VS-XXs off my buddy 19x10 +29 all around; going to run 10mm spaces all around on 245/35/19. Will post pics once its done.
Old Jun 6, 2012 | 12:18 AM
  #3592
4DGS's Avatar
Every degree of camber is 5mm in offset change. To answer the second portion it's kind of a yes and no. It really depends how the tire stretches weather or not it will really give you 10mm more clearance or not. 10mm in tread width usually will only warrant 5mm in clearance (side to side) However some tires just seat differently. But a 275 will definitely help you reduce some camber. And remember your camber will be FULLY adjustable with camber arms, so even if you switch to a 275 and 1 degree can't be removed then a .9 will probably do the trick, know what I'm sayin?
No.
Not really the thread for this info, but congrats on the wheel purchase!
Old Jun 6, 2012 | 01:56 PM
  #3593
For sure. I really appreciate the help, that's just what I needed.
Old Jun 7, 2012 | 12:42 AM
  #3594
MPG35fiend's Avatar
small, true, large tires for stretch.
ok. its time to decide on TIRES...
can anyone tell me what is the best looking "safe" tire to put on 19x9.5/10.5 +22?
im currently leaning towards a "true" or "large" size fitment on tires... im open for some suggestions...
My Tire Options
archilles (but afraid that the will run a bit small) really digging this tread.
hankook v12 (true) or something close to it.. but a bit pricey.
falken 452 (large) or something around this price range.
best price, best looking, ride comfort, tire life, functionality on rough roads.
thanks in advanced.!
Old Jun 7, 2012 | 02:07 AM
  #3595
DrewDrew's Avatar
last I checked, 452s run small. I like the v12s all around design - my fav out of your list.
Old Jun 7, 2012 | 02:05 PM
  #3596
Johnmikins's Avatar
Am I right in thinking if I go from a 285 to a 265 tire I can gain an extra 10mm in wheel fender clearance? Think I found my answer above...
Old Jun 7, 2012 | 06:07 PM
  #3597
4DGS's Avatar
My Tire Options
Achilles have proven to be fantastic cambered and stretched tires.
Hankooks have proven to bubble and wear too quickly
Falkens are ****
In all honesty, I'd go with the achilles out of them, they run sorta small but not to the point where it's ugly.
FKs differ have way through the widths, below 255 run small and above 275 run large. Falken is terrible for that.
Yes.
Old Jun 7, 2012 | 06:28 PM
  #3598
SAMzG35's Avatar
G35
Quick question for you guys
I'm lowering my 04 Coupe this weekend. Im running 20x11 275/30 rear & 20x10 245/30 front +15 all around.
I'm dropping around 1" back and 1.5" front. What would i need when it comes to camber/toeing?
Much apprecaited
Old Jun 7, 2012 | 06:48 PM
  #3599
4DGS's Avatar
What do you mean?
Old Jun 7, 2012 | 07:47 PM
  #3600
SAMzG35's Avatar
G35
My question is do I need front & rear camber kit? What about toe kits?
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
