Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
#3347
basic math, lol. for every .5" of lip you add, you add 6mm to the offset. but you gotta remember it becomes 12mm more aggressive overall. (half inch is ~12mm. 6mm is applied to the inside and outside lip, hence the 6mm offset adjustment). for example. 9.5 +17, a standard gt-s set up. if I rebarrel to 10", my offset is +12, but 10 +12 is 12mm more aggressive than 9.5 +17.
at least I hope it's like that. LOL. that's how L-Fab explained it to me when I wanted to rebarrel my gt-s to 20" steps. Blain, is what I said correct? make sure before I completely FUBAR somebodys wheels.
#3348
#3351
It's not as easy as it sounds, but it's not really that hard.
The hard part is guessing the seal. Once you've silconed the lip/barrel there is no way to confirm you've made a perfect seal until you mount a tire.
An no, they aren't all 40 bolt it differs from company to company. Not to mention the PCD is different with pretty much all companies.
#3354
PCD stands for pitch circle diameter and is the diameter of a circle drawn through the center of your wheel's bolt holes. P.C.D. is measured in millimeters and also indicate the number of studs or bolts the wheel will have. Ours are 5x114.3. Volkswagen Alloy Wheels are usually either 4x100: i.e. 4 bolt holes drilled through the centre of an imaginary 100mm circle, or 5x100: for VR6s, GTis and MK4s, etc.
#3360
Wheel/Tire gurus, your help is greatly appreciated.
I got my wheels used and they came mounted with tires. I have a g35 coupe with 19x10 +9 fronts 19x11 +13 rears Tires*225/40 fronts 245/40 rears.
I'm as low as possible on my BC coilovers and my fenders are rolled front and rear.
What other tire options can I go with? I'm not really a fan of stretched tires, especially not a major stretch but I know with my set up I'll need some stretch. I don't want extreme negative camber either I have SPC rear camber/toe kit and plan on getting the SPL front camber arms. What tire sizes do you guys reccomend? What's the biggest I can go? I'm considering getting fenders pulled if it gives me enough room for bigger tires. Any advice is greatly appreciated!
