Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Jun 25, 2012 | 05:51 PM
  #3721
TGMcCoy's Avatar
Originally Posted by OH4G35
^Thsnks
20x10 -10
20x12 -22
Front 5" lip
Rear 6.5" reverse lip
Are those the same wheels you had previously? Just rebarrelled aggressive as hell?
Old Jun 25, 2012 | 07:55 PM
  #3722
OH4G35's Avatar
Yeah wheel flip did them for me they did awesome job on them
Old Jun 25, 2012 | 08:25 PM
  #3723
4DGS's Avatar
Triple nicks are pretty stiff sidewalls, especially compared to the Generals.
But the 265s should seat fine and you'll actually have just as much clearance as the 245.
You'll also be able to go lower...
Old Jun 26, 2012 | 07:41 AM
  #3724
OH4G35's Avatar
Just ordered them yesterday...Should be here today actually should have them mounted today to maybe start pulling my fenders too I would like to get them on this weekend..
Thanks alot for your help though
Old Jun 26, 2012 | 01:48 PM
  #3725
OH4G35's Avatar
What tires out there now have a soft sidewall like the uhp tires? In a 265/30?
Old Jun 26, 2012 | 01:51 PM
  #3726
VMRWheels's Avatar
Hankook Ventus V12s... They have a pretty soft sidewall.
Old Jun 26, 2012 | 02:11 PM
  #3727
OH4G35's Avatar
They have them in a 265/30
my tire shop ordered the wrong nittos pluss they
make a 265/30 they only have a 35 series
Old Jun 26, 2012 | 03:01 PM
  #3728
Gride650's Avatar
whats up guys!
Im looking at buying a new set of shoes for the car.
I found a set that are 19" front 9.5/ +5 and rear 10.5 offset +0 offset.
I have coils on my car and rear camber kit. I am wonder if i purchase these if all I will need to do would be to place a front camber and roll my rear fenders? Would I have to do any other major body work to the car?
Old Jun 26, 2012 | 03:18 PM
  #3729
4DGS's Avatar
Coupe or sedan?
Old Jun 26, 2012 | 03:37 PM
  #3730
VMRWheels's Avatar
Originally Posted by Gride650
whats up guys!
If it's a coupe, with a bit of work you could get that to fit. I have a car in our studio right now that is running essentially the same specs, but his car is very low.
He just has his fronts and rears rolled with a very small pull (probably like 2mm).
Old Jun 26, 2012 | 04:13 PM
  #3731
Gride650's Avatar
yes, its a coupe. So I would have to pull my fenders? What would a bit of work consist of?
thanks for the help
Old Jun 26, 2012 | 04:21 PM
  #3732
DrewDrew's Avatar
No pull is necessary. at +0, you'll run -1.8 camber, granted you run a stretched set, like 225/245/35. if that's more than you'd like to run, you can pull, or find a less aggressive set. for the fronts, you'll want to get a camber kit to adjust for flushness. if you let it keep the natural camber from the drop, you'll be sunken in a bit.
Old Jun 26, 2012 | 04:28 PM
  #3733
VMRWheels's Avatar
Old Jun 26, 2012 | 04:30 PM
  #3734
Gride650's Avatar
The tires which are on the set right now are front: (235 35 19) rear: (255 35 19)
So to sum it all up, I would need to get front camber kit, roll back fenders and pull both a little bit.
If you pull fenders is it possible to "de pull" them once I want to sell the car to make it stock? sorry for the dumb q. and what offset is the max before having to pull the fenders.
Old Jun 26, 2012 | 04:34 PM
  #3735
4DGS's Avatar
I'm running 10.5 -3 with a 255/35 and pretty much no camber. Rolled fenders...
Front is 9.5 +2 235/35 and again, pretty much no camber.
You can fit em, just run really mild stretched.
No pulling required.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
