Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Jul 23, 2012 | 11:06 AM
  #3931
frontieragent's Avatar
I picked up a set of TSW Londrina 19x9.5 +40. I want the aggressive look like MarcusCooke sedan. Will the 25/30mm spacers come close to that and wrapping it in 225/35/19s? Need some advice. Thx
Old Jul 23, 2012 | 11:41 AM
  #3932
4DGS's Avatar
Originally Posted by MPG35fiend
^ yea DPE Aristos... yea I'm already dumped! -1.2 up front and probably going to set it at -2. the rears are already -2.. hmm... maybe ill consider a slight pull to get it at -3... THANKS ONCE AGAiN!!!
i forgot to ask.... is -4 in the rear usual? is it like a crazy camber to have?? wanted to know bc i probably won't do a pull.. gotta see how everything goes first... lmk guys thanks,.
Yea -4 is the norm for unpulled fenders.
Already dumped and only pulled -2 and -1? Doesn't seem very low.
Originally Posted by jimmyboi860
I'm located in Hartford, CT. Surrounded by New York, New Jersey, Massachusetts.
Also, what can I do about getting the lips re polished Blain? I want to make the wheels look like brand new again.
Thanks.
There a guy in PA that I can hook you up with....
As for the polishing if you can't do it yourself look around for metal polishers locally. If you can't find any go to a body shop and ask them to buff the lips.
Originally Posted by luisp88
Size: 19x9.0 +41 offset / 19x10.0 +37 offset
would these specs be flush on a g35 coupe?
Not even close. You would need roughly 40mm spacers which are unsafe to run. Look for different wheels.
Which set up? His LMGT4 set up or the SSR set up?
Old Jul 23, 2012 | 11:57 AM
  #3933
LMGT4 setup with narrower tires
Old Jul 23, 2012 | 01:30 PM
  #3934
Sheridan79's Avatar
I just bought an 07 G35x sedan and i wanna know before i buy my rims can i do 20x10 all around or do i need to go thinner in the front and run staggered rims or a specific offset to get them to fit?
Old Jul 23, 2012 | 01:31 PM
  #3935
Mraries75's Avatar
My G coupe with sport pack comes with 19's but have 17's on them. Is this a major problem?
Old Jul 23, 2012 | 01:56 PM
  #3936
4DGS's Avatar
You're going to need 30mm spacers front and rear.
Camber will be roughly -3ish once you're dropped low enough.
You will need slightly higher offsets but it depends how you want them to fit. Do you want them to be flush or do you want them to poke?
What do you mean?
Old Jul 23, 2012 | 02:24 PM
  #3937
Sheridan79's Avatar
I want them to be flush as possible i will roll my fenders and what not if needed.
Old Jul 23, 2012 | 02:47 PM
  #3938
4DGS's Avatar
Are you willing to stretch? or looking to run full size tires?
Are you lowered? Plan to lower?
What wheels are you looking at?
Old Jul 23, 2012 | 03:12 PM
  #3939
Sheridan79's Avatar
Hell yes i'm willing to stretch its kinda what i wanted to do and i plan on doing coilovers. 1st option is Black Menzari Vim 20x10 with a 35 offset no tires just rims. and the second option is 20x 10 Black Wheel Niche Nurburg with a 40 offset again no tires just rims
Old Jul 23, 2012 | 04:04 PM
  #3940
Mraries75's Avatar
the 19's were taken off and replaced with 17's
Old Jul 23, 2012 | 05:42 PM
  #3941
4DGS's Avatar
You'll need pretty big spacers with those, Aim for the offsets to be around +15 to make this work. And run a 235/35 or a 245/35 (245 is pretty mild stretch)
Definitely get coils first though!
Old Jul 23, 2012 | 05:46 PM
  #3942
Sheridan79's Avatar
Ok thank you very much for clearing that up for me. I appreciate the advice
Old Jul 23, 2012 | 06:23 PM
  #3943
MPG35fiend's Avatar
LOL. thats because i have FRONT&REAR SPC camber kits..
the lowest i can go with feeling safe... use to be 0.8" lower before i got my front camber kit..
Old Jul 23, 2012 | 06:27 PM
  #3944
Drew113's Avatar
Ban Hammer Expert
^^thats really not "dumped", its definately lowered but if you would be running -4 degress of camber and not lower than you are in that picture it will look weird...
  #3945
MPG35fiend's Avatar
oh yea before i got my front lip i never scraped my front bumper its always just the bottom of my G.. i have like literally 2.5" clearance under my G.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
