TGMcCoy
close
- Join DateMar 2004
- LocationPortland, Oregon
iTrader Positive Feedback100
iTrader Feedback Score(6)
Liked:95 Times in 88 Posts
I've seen a good deal on tires sized 225/45/19 front and 245/40/19 which if i'm not mistaken are g37 19" tire specs... 19x8.5/19x9.
My question is how would these look on g35 rays? A little tall I figure on the front, but not crazy ugly tall, right? Just checkin...
Thanks
Thanks
Quote:
245/45 is OEM IIRC.Originally Posted by michael454rs
have an 05 sedan stock just bough coupe 7 spoke 18 what tire size do you guys reccomend i buy? from usign a tire calculator 235/45 would me at an almost exact wheel tire circumfrance what do you guys think? thanks
235/45 or 245/35 even 225/45 will work for the OEM 18s.
Thanks
225/45 and 245/40 are actually almost the same sidewall height. So it won't look silly.Originally Posted by TGMcCoy
I've seen a good deal on tires sized 225/45/19 front and 245/40/19 which if i'm not mistaken are g37 19" tire specs... 19x8.5/19x9.My question is how would these look on g35 rays? A little tall I figure on the front, but not crazy ugly tall, right? Just checkin...
Thanks
Getting 19x9 / 19x10. +22 for my 07 coupe, inner clearance is supposedly 17mm less than stock, should be fine right ? I'm only dropped on z htech, so no fender rolling should be needed, and only 245/40/19 in the back
Thanks!
Thanks!
Won't run, why are running a 245/40 on a 10? That's the wrong tire for this application.
quick question! i have 2008 g35S with H&R springs, i'm Planning to upgrade my rims to 20's, 20x8.5F/20x10R. how low the offset and what size of tires should i use for aggressive look without using any camber kit? thanks
TGMcCoy
close
- Join DateMar 2004
with this in mind, would a 225/40 front and a 245/35 have approx same sidewall height on rays also?Originally Posted by 4DGS
.225/45 and 245/40 are actually almost the same sidewall height. So it won't look silly.
Just checking all options
Question , buying a set of Stance SC5ive wheels for my coupe . Bad thing is the offsets are 20x10 +35 and 20x10.5 +27 . If I ran a 30mm spacer all around with a 235/35 and 245/35 tire. Would this get me a even stance ?
quick question how would this tire combo look?I know on a 10 i could run a 275/30 but I can get these for a steal they are nitto invo's
20x10 255/45/20
20x11 305/25/20
20x10 255/45/20
20x11 305/25/20
what tire size options would i have for a 08g35s sedan besides the 225/50/18 and 245/45/18 without compromising handling and performance?
