Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Feb 21, 2014 | 09:46 PM
  #6841
herrschaft's Avatar
Originally Posted by nirvanaxux
Any advice from people who researched the whole spacer area on what size looks best for the size rims im running?
What looks best is subjective. If you're going with the same brand tire then you can calculate how different sized tires will fit compared to your current setup. You need to lower the car to fill in those gaps.
Old Feb 21, 2014 | 09:54 PM
  #6842
BenitesG35's Avatar
18x10.5 +25
Or
19x10 +15
Old Feb 21, 2014 | 10:01 PM
  #6843
herrschaft's Avatar
Originally Posted by BenitesG35
18x10.5 +25
Or
19x10 +15
Should I go with 18x10.5 +25
Or
19x10 +15
Missing a little info..........Coupe/Sedan? lowered? Goals?
Old Feb 21, 2014 | 10:25 PM
  #6844
g35SedanSC's Avatar
FOR 2004 SEDAN...
Goal 265/35/18
Old Feb 21, 2014 | 10:40 PM
  #6845
BenitesG35's Avatar
05 coupe coil overs no Brembo and I was lookin at stretched tires and a flush look
Old Feb 22, 2014 | 02:42 AM
  #6846
Tazm's Avatar
Hey guys,
I was looking at buying 20"s. Not knowing too much about wheels except for what wheels I think look good. I spoke to the guys at the garage and I've decided in 20" Vertini Fairlady's (8.5F 10R).
My 2004 V35 is stock at this stage (18s 225/45, 245/45). I was going to run with what the guys at the garage suggested but my friends scared me in to not getting 20s due to rub/noise.
I wanted to come to you guys about what I need to do to make this work. Are the guys at the garage setting me up for a bad time here or is this going to work? I'd like to be armed with a little extra information as to what I'm buying before committing to something silly. Is there any reason I should not go 20s - would 19s be easier? I guess if I'm going to be spending all this money I'd want the visual change to be the greatest possible.
My goal is looks and practicality balanced (Australian roads are horrible too).
Appreciate the help.
Old Feb 22, 2014 | 06:19 PM
  #6847
TonyKing28's Avatar
Guys, i need help.. i bought wheels that are 18x9.5 width all around with a offset of +40... The rear fits fine but the back of the front wheel rubs against the metal bar that holds the rotors (dont know that name). What size wheel spacer will i need to fit it properly? and rear wheel spacers to even it out so it wont look weird. Its an 06' coupe, stock height. Any help would be greatly appreciated.
Old Feb 22, 2014 | 08:39 PM
  #6848
tonytothel's Avatar
20x10J Front 20x11J Rear set up need advice
I have a 2013 G37 coupe. Currently Im building it up with 20x10J Front, and 20x11J Rear. What offset I should be looking at to line up the edge? Since there is not many people having thise set up.
Also, what's a good tire suggestion?
Old Feb 24, 2014 | 10:48 AM
  #6849
BenitesG35's Avatar
Need some advice on wheel spec
I've asked plenty of times in the right thread but never got an answer. I'm planning on getting a whole new set up. I have an 05 coupe no Brembo. I'm stuck between 18x10.5 +25 or 19x10 +15 I'm looking for a flush fitment would I need spacers for either setup
Old Feb 25, 2014 | 02:02 AM
  #6850
ckendG35's Avatar
Max Tire Width on 18" Stock Rims
Hello all, I have 18 inch 7 spoke hyper silver rims on my g35. Plan on getting new rims but for now how much width can I use in the rear? Rear tires are nearly gone with tread and need to purchase new or used rear tires with a wider contact patch. Right now fronts; 235/40/18 and rear, 245/45/18. Can I use a 255/40/18 or 265/40/18 without disturbing the ride height look in the rear end or should I stick with 255/45/18 or 265/45/18?
Old Feb 25, 2014 | 06:07 AM
  #6851
lowblocks's Avatar
Hey I have a 2003 g35 sedan on air ride I just want to know if a 10. 5 with a offset of 25 fit the front of my car
Old Feb 25, 2014 | 12:58 PM
  #6852
BenitesG35's Avatar
Need some help asap!!
- 2005 infiniti g35 coupe, no Brembo, rolled flat, coil overs
- should I go with 18x10.5 +25 or 19x10.5 +15 all around
- what tires would be the best choice for those setups
- looking for a flush and stretched look without messin with the speedometer
Old Feb 25, 2014 | 07:09 PM
  #6853
vj_Gsedan's Avatar
Help!!! I have a g35 sedan with bbk lowered on 350z coil overs and lowering spring kit. I have coupe 19 on it now. what would be the best wheel and tire set up with 19in wheels. I want to be able to ride wit 4 adults in the car and not rub
Old Feb 27, 2014 | 04:04 PM
  #6854
BenitesG35's Avatar
Bump for answers!!
Old Mar 2, 2014 | 06:17 PM
  #6855
guitarrocker98's Avatar
Okay guys I have spacer questions. As some may know I will be putting on fender flares. Aka doing a cheap widebody.... My wheel specs are 19x10. -10 fronts 19x11 -5 rears I was wondering if I put on 30mm spacers in the rear and 25 fronts that would set me at -35 all around. Should I go with a different setup... Possibly a 30 on the front and a 25 rears..... My tire setup is 245 fronts 275 rears if that helps. Just want it to look good and aggressive.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
