Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Mar 8, 2010 | 11:11 AM
  #676
LightsOut's Avatar
SIETESG
Originally Posted by DyslexicG35
I asked about tires for my new wheels weeks ago. LightsOut answered a few posts later saying they would be "Sunken in" and to buy spacers if I was gonna keep them.
I've checked several calcs and DTD and Neal @ Tire Rack all say it will actually stick out.
Essentially. Stock wheels are 18x8 +30 (I had thought this was +33), New ones are 19x8.5 +20
I assume at this point LightsOut was wrong and there have been no other responses. The question still remains about tire sizes and add another questions about adding Tein H tech springs to the mix, any fitment/rubbing issues?
Thanks in advance.
Im not wrong... 8.5 width +20 will be sunken in. front and rear and deff. no rubbing
new suggestion on spacer size. since your running 8.5 +20 all around
15F 245/35
20r 255/35
Old Mar 8, 2010 | 11:13 AM
  #677
LightsOut's Avatar
SIETESG
Originally Posted by O HELLA OEM
i didnt put these tire sizes on my nismo. They are the Oem Potenzas factory tires that came with the rims. So i should have bought 20mm spacers all around instead of 25mm.
try the 25mm, if it rubs as I predict then just sell them.
Old Mar 8, 2010 | 12:40 PM
  #678
OCG35's Avatar
Originally Posted by coreydee
Sir, could you help me with my selection?
S5:F
19"x9.5J +35 offset front
19"x10.5J +22 offset rear
if you're a sedan - I wouldn't use those offsets (unless you like running massive negative camber)...
if you're a coupe - I have no idea...
Old Mar 8, 2010 | 01:29 PM
  #679
DyslexicG35's Avatar
15F 245/35
20r 255/35
As before I'm still asking for an explanation of why you think it will be sunken in. Offset pushes the wheel 10mm further out than stock. Plus the additional .5" width will push it out another 12-13mm(Or perhaps half of this?) so 22-23mm further out than stock... Why would that look sunken in? Furthermore if I add 15-20mm spacers it will be sticking out nearly 2 inches more than stock. Please explain, If I'm wrong thats fine, I just want to know what is wrong.
Old Mar 8, 2010 | 02:53 PM
  #680
LightsOut's Avatar
SIETESG
Im not good in explaing things...maybe someone else can explain it to you in better detail. I know cause, I just know from seeing other cars close up and knowing the details of their wheel setup and me having good knowledge in wheel spacer sizes with wheel specs.
most common set up is 9.5F 20R with 10-25 offsets. and they sit flush/semi flush with a fender roll. but even then, with a 22+ offsets some dont even have their fenders rolled. (depending on suspension setup)
your setup on the other hand is way smaller than the most common setups. which means it will be sunken in.
Old Mar 8, 2010 | 05:28 PM
  #681
Per Neal at Tire rack: "Lower the offset number the further out the wheel will move. So the new wheels, with the additional width, should sit 3/4" further outboard compared to the oe wheels."
I hope someone can explain it more clearly because your "just know"ing doesn't make sense in my head.
Old Mar 8, 2010 | 07:48 PM
  #682
TwilightSedan's Avatar
G37 Sport 19's question
I'm putting some new G37 Sport 19's on an 03 Twilight blue G35 Sedan. Should I be concerned with any camber problems or an alignment afterwards? Here are the specs:
OEM 19" 10 spoke G37 Sport wheels & tires
Front:
Wheels: 19"x8.5". Cast aluminum. Made for Nissan/Infiniti by Enkei. Weight: 26.5 lbs. Bolt pattern 114.3 x 5 Offset +43
Tires: Bridgestone Potenza RE050A 225/45/19 92W. UTQG 140AA, weight 27 lbs., tread depth 10/32"
Rear:
Wheels: 19"x9". Cast aluminum. Made for Nissan/Infiniti byEnkei. Weight: 27.5 lbs. Bolt pattern 114.3 x 5. Offset +45
Tires: Bridgestone Potenza RE050A 245/40/19 94W. UTQG 140AA, weight 30 lbs., tread depth 10/32"
Other: Lugs- 60° tapered seat, 2.7oz/76 grams each. OEM wheel locks- 3.2oz./91 grams each. Center caps .3oz./14 grams each. TPMS sensors (with valve stem & collar) 1.2oz/34 grams each (Part # 40700 -JK00B) .
Old Mar 8, 2010 | 08:24 PM
  #683
OCG35's Avatar
Front:
Rear:
front will be about 8mm inside of fender edge - rear about 4mm in (with 0 camber)
Old Mar 8, 2010 | 10:42 PM
  #684
I'm sorry, please excuse my lack of knowledge. 0 Camber is a good thing correct? It means perfectly centered? Will I be able to sustain that camber and clearance with the fender no matter how much i lower it?
Old Mar 8, 2010 | 11:32 PM
  #685
sureshot73's Avatar
G35 Coupe with Brembo - Volk GT7 - Offsets - I've done a lot of searching today but haven't been able to determine if these wheels would work on my car with no spacers. I don't want to buy any wheels that would require them. I know a lot of people prefer 19's but I don't mind the 18's because the tires are less pricey.
18x9 + 28 235/35/18 Front
18x10 +29 275/35/18 Rear
Thanks in advance for any guidance you can offer.
Old Mar 8, 2010 | 11:44 PM
  #686
4DGS's Avatar
Yes, they will clear, but go with lower offsets. Those offsets are kinda high for a coupe. You want them to look flush and bad ***!
Old Mar 9, 2010 | 12:03 AM
  #687
OCG35's Avatar
no, I should have not used 0 camber as reference... no additional negative camber to OEM specs - OEM does have slight negative camber... you wont need camber adjusters... you will be able to go pretty low, which inherently causes neg camber, but it might not look so good being real low with wheels tucked in that much...
how low do you plan? Something like Eibach Pro might look okay...
I'm not an offset guru, and am not into the real wide with extreme negative camber look - so it really depends on what you are after... some of the other guys will be able to guide you better if you want an overly aggressive look but the specs of the wheels you mention isnt that far off what your OEM is (as far as wheel track).
Old Mar 9, 2010 | 12:05 AM
  #688
Thank you very much for your help.
Old Mar 9, 2010 | 12:08 AM
  #689
OCG35's Avatar
anytime ~
Old Mar 9, 2010 | 12:12 AM
  #690
coreydee's Avatar
anybody know about these for a 04 coupe w/ brembo?
Spacers? Rubbing? Not looking right at all? sunken in?
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
