Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Jan 25, 2015 | 11:53 PM
  #7201
Conissah's Avatar
How much poke/camber would I have to run with this setup? I don't want to run excessive camber but I want a nice flush look. Also should I run 255/35 and 285/35 or 245/35 and 275/35?
19x9.5 +12
19x11 +12
Or would these sizes with +22 and +25 offset respectively work better?
Old Jan 26, 2015 | 10:06 PM
  #7202
loki05's Avatar
Is this alignment spec. good for a coupe lowered about 1.5-2 inches?
Left Front Camber After/Before = -2.1 / -1.6
Right Front Camber After/Before = -1.9 / -1.4
Left Front Caster = 8.6
Right Front Caster = 9
Left Front Toe After/Before = 0.12/0.08
Right Front Toe After/Before = 0.15/-0.05
Left Rear Camber After/Before = -2.2/-1.5
Right Rear Camber After/Before = -1.9/-0.9
Left Rear Toe After/Before = -0.43/-0.96
Right Rear Toe After/Before = -0.43/-1.32
Old Jan 26, 2015 | 10:10 PM
  #7203
BowWizzel's Avatar
Left Front Toe After/Before = 0.12/-0.08
Fronts decent but rear camber & toe could of been better matched.
Old Jan 26, 2015 | 10:13 PM
  #7204
loki05's Avatar
Can you elaborate more on the rears? I was told that I could of gotten toe near 0 or a bit positive but my rear camber would be well over -2.5, possibly -3. The alignment shop advised that the spec provided above is best for tire wear... not 100% positive though.
Old Jan 26, 2015 | 10:17 PM
  #7205
BowWizzel's Avatar
^ I'm talking about matching the left & right side camber & toe specs to each other. Could of been more closely matched.
Old Jan 26, 2015 | 10:19 PM
  #7206
loki05's Avatar
Hmm.. they seem closely matched to me. The actual alignment now would be the left side numbers.
Old Jan 26, 2015 | 10:30 PM
  #7207
BowWizzel's Avatar
Oh damn, looked at it wrong. What size wheels & tires you running? Also offset?
My camber specs are more aggressive & my toe spec is way less than yours. My front toe is at .05 with -3 camber & rear at .15 with -4 camber.
Old Jan 26, 2015 | 10:49 PM
  #7208
BowWizzel's Avatar
Maybe someone else more knowledgeable in this area can chime in but my alignment guy would be looking at me like WTF with those toes specs.
Old Feb 5, 2015 | 09:36 AM
  #7209
35reilly's Avatar
Ok guys I posted I guess in the wrong place. Hopefully I can get some feed back here... I have a set of ssr ms1 front 19x10.5 -2 rear 19x10.5 -26 Not worried bout the front so much. They came off my boys 350z. My fenders are roll and pulled. I want to run a 245/35/19 I'm trying to get some help on what I'm gonna need to do to get these rears to work.. Any help would be great thanks!!
Old Feb 5, 2015 | 09:47 AM
  #7210
the93owner's Avatar
Lots and lots of camber. Lol. Those are very aggressive specs.
Old Feb 5, 2015 | 12:49 PM
  #7211
35reilly's Avatar
yeah I know. I was running a 20x11 0 offset on my old set up w a 255/35/20 I forget what my camber was... Think I'm leaning towards a 235/35/19. I know I'm gonna have to runs lk 2 more degrees then where I'm at now.
Old Feb 6, 2015 | 04:18 PM
  #7212
cleejones5's Avatar
I am ready to buy wheels for my 2003 G sedan. I want to go with 20x8.5 +20 in the front and go 20x10 +40 in the rear. Since I might have to roll my rear fenders and I definitely want to slam it (front and rear camber kit and Coilovers ect.). Should I work on my suspension first or work on my wheels and tires first?
Old Feb 6, 2015 | 07:31 PM
  #7213
cleejones5's Avatar
whats up everyone. kind of a noob so sorry in advance. I want to get 20x8.5 +20 wheels in the front with 245/35/20 tires and in the rear i want to get 20x10 +40 with 275/30/20 tires. I also want to lower it. Do i need a camber kit in the front and rear with rolled fenders in the rear to fit my wheel and tire specs?
Thanks
Old Feb 7, 2015 | 04:54 PM
  #7214
the93owner's Avatar
Is this alignment spec. good for a coupe lowered about 1.5-2 inches? Left Front Camber After/Before = -2.1 / -1.6 Right Front Camber After/Before = -1.9 / -1.4 Left Front Caster = 8.6 Right Front Caster = 9 Left Front Toe After/Before = 0.12/0.08 Right Front Toe After/Before = 0.15/-0.05 Left Rear Camber After/Before = -2.2/-1.5 Right Rear Camber After/Before = -1.9/-0.9 Left Rear Toe After/Before = -0.43/-0.96 Right Rear Toe After/Before = -0.43/-1.32
I just got my car realigned yesterday, here's my spec sheet for comparison. I am lowered on 350z S-Tech springs (about the same drop) and have a camber kit in the rear but not in the front.
Attached Thumbnails Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::-image-4131677185.jpg
Old Feb 14, 2015 | 12:32 AM
  #7215
thegreatkwijibo's Avatar
so I kinda need an answer on this ASAP does anyone know if 18x10 +45 will clear on the inside on an 03 G sedan non sport with KW v2 OEM style coilovers in the rear?
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
