Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Dec 5, 2015 | 08:01 AM
  #7396
Jusseth's Avatar
Originally Posted by Time2findDaJuan
20x9+20 front and 20x10.5+20 rear what tires should I use? i'll also be installing airlift 3h kit so i plan on being low
Why are you asking the same question on different threads?
Old Dec 8, 2015 | 11:18 AM
  #7397
Tukeeg35's Avatar
Hey guys, my buddy just picked up an '07 V36 sedan and is looking to pick up a set of wheels, but were not sure if the offsets will work for his application.
Can anyone more knowledgeable chime in on whether or not 19x9+35 fronts and 19x10+42 rears would fit on an '07 RWD sedan?
I ran the changes through the 1010tires calculator, front are:
9mm less inner clearance | 29mm outside extension
Rears are:
29mm less inner clearance | 35mm outside extension
Vehicle will have a slight drop, not trying to run retarded amounts of negative camber and stretched tires, in this case function > form
Thanks!
Old Jan 2, 2016 | 12:34 AM
  #7398
Jussumman's Avatar
Has anyone painted MGP Brake Caliper Covers a customized color? They sell black and red I see on ebay/amazon, but I was thinking of something more along orange/yellow. Maybe I can ask the manufacturer for a set that hasn't been painted yet?
Any thoughts?
Old Jan 2, 2016 | 12:50 AM
  #7399
Tyke420's Avatar
^ ha ha... I don't think anybody on this forum has brake caliper covers...lol.. If you want to paint your brake caliper covers than just paint them.. It's not very hard....
Old Jan 30, 2016 | 10:09 AM
  #7400
03Sedan6MT's Avatar
M45 19s with 5mm spacers on sedan
Originally Posted by 03Sedan6MT
"I just tried to bolt them up and they hit the upper [sic] control arm [note: it's actually the A Arm]. It's not even close."
I WAS WRONG HERE
CORRECTION: According to the M45 on G35 Sedan Thread HERE:
https://g35driver.com/forums/g35-sed...45-wheels.html
a 5mm spacer will work. 5mm is close. I bought 4 (one for each wheel -- my rationale is that if I am changing the factory specs I might as well do it evenly). I'll update this thread with my results.
RESULTS: SUCCESS
M45 19s with 5mm spacers & 245/40 tires on an 2003.5 sedan
There is not even a finger-tip's width of clearance at the upper A arms in the front, but it does clear and the car performs very strong on the set up (note: unintended wheelspin in dry conditions with VDC off has ceased--& as we all know, spinning isn't winning).
Old Feb 20, 2016 | 05:58 PM
  #7401
joeslates's Avatar
Hey guys quick question. I currently have 19x9 +38 19x10 +34 on my Weds Kranze Bazreias. I am looking to relip my current front wheels to a 12" wide wheel and make those my new rears and bring my current rears (the 19x10s) to the front. Will I have clearence issues with the break calipers, etc.? the offset will be +5 (19x12 +5)
Old Feb 20, 2016 | 06:33 PM
  #7402
Lartytiejdke3's Avatar
no. youll be fine. your faces didnt change. also, learn that break clearance and bbk clearance is determined by disc size NOT offsets.
Old Feb 27, 2016 | 12:13 PM
  #7403
Raptor22ZMB's Avatar
Thinking of getting 19x9 with a 35 offset and back wheels being 19x10.5 with 35 offse
They are rays gram lights would these look good on my stock 2004 g35 coupe? What size tires would I have to run. Any help would be appreciated! Thanks maybe in the future I might drop the G but I scrape enough for now.
Old Feb 27, 2016 | 09:07 PM
  #7404
ChunkyMonkey's Avatar
Forgestar F14 SDC's
So I am in the market for new wheels and I have found a setup that I am looking into getting. The setup I am going for is based on this beauty of a G35: http://ksportusa.com/kblog/?p=1435
His setup is 19" Forgestar F14 Super Deep Concaves
19x10 -2 and 19x11 -6 wrapped with 225/35/19 and 245/35/19
But I am probably going to get a set of 245/35/19 and 275/35/19 instead for less of a stretch.
I am sitting on stock suspension with non-Brembos, however I do hope to get the AirLift air kit afterwards to avoid the nightmares of scrapping on everything. I am prepared for a fender roll and pull to fit everything, aswell as buying a pair of SPC rear camber arms.
Are there any specs I should change?
Old Feb 27, 2016 | 10:04 PM
  #7405
VenomGT9's Avatar
Looks is all a matter of preference. To me, that set up is weak for a coupe but you may like it.
Tires may need to change depending how you set up that camber.
Old Feb 28, 2016 | 02:57 PM
  #7406
Meaning less tire width? I figured a degree or so of negative camber will be needed, but of course I'm not trying for crazy slant.
Old Feb 28, 2016 | 05:39 PM
  #7407
VenomGT9's Avatar
With those aggressive offsets it's going to a nice little dilemma between tire stretch and camber.
The 245 up front probably won't be an issue so I would focus on the rear.
I'm speaking for when you are lowered...might look a bit odd at stock height
Old Feb 28, 2016 | 05:45 PM
  #7408
So would it make a difference if I was to go with 0 offset for front and rears, instead of -2 and -6 that the original setup had?
Old Mar 1, 2016 | 10:28 AM
  #7409
Crazy11Fox's Avatar
245/35/19 on 8.5 +35
I have a 06 sedan and I am wondering if these will clear my spindle and tuck on stock suspension.
Old Mar 9, 2016 | 03:19 AM
  #7410
Leo90's Avatar
I have a 2005 coupe with 19'' Momo GTR wheels with fronts on 245 40 tires and rears being on 275 35. Im wondering what size spacers i would need to have all the wheels flush with fenders.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
