Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old May 9, 2010 | 09:19 AM
  #916
O HELLA OEM's Avatar
hey shane!
okie the pic below is a sedan.
obviously i have a G35 coupe and i was wondering what type/size of tires i need, how much camber, and if i need my front and rear fenders rolled flat and pulled to pull that look that sedan has?
my specs on my volk te's are
19x9.5 +22 front and 19x10.5 +22 rear
the tires are
255/35/19 front and 285/35/19 rear
heres a pic of my G
Old May 9, 2010 | 05:54 PM
  #917
HXS's Avatar
HXS
hella, i ain't shane but here's my recommedation...
1. get at least 20-mm spacers all around
2. put your 255/35 to the rears and get 235/35 or 225/35 fronts
3. get at least -2.0 camber all around
4. lower at least 1 inch more
5. rolled flat fronts, rolled and slight pull rears
Old May 9, 2010 | 06:59 PM
  #918
4DGS's Avatar
Brian;
Max your coils, pull -3 camber, stretch a 245/35 onto the rear and and 225/35 on the front. Then 20mm Spacers or pull your fenders and run 25s.
Old May 10, 2010 | 01:44 PM
  #919
B_Lam's Avatar
What size tires should I use for 19x9.5+22 / 19x10.5+22 ? My g coupe is lowered to one finger gap all around. I don't want the vdc/ slip lights going crazy either. Actually I don't wanna mess with anything that'll set those off. Thanks
Old May 11, 2010 | 04:46 PM
  #920
HaTa's Avatar
Originally Posted by O HELLA OEM
hey shane!
Sorry for the interuption, but whos sedan is that ^^ ??!!
Old May 12, 2010 | 04:18 PM
  #921
Pepper's Avatar
Any Help??
Originally Posted by Pepepr
Current:
Tein Flex: Rear maxed out. Front as low as I can go and still turn the wheel.
Volk GTS
19x9.5 +17 255/35/19
19x10.5 +18 275/35/19
*Camber is uncorrected*
To get the top of the wheel to come super flush with the sheet metal, what size spacer should I use? Also what size tire to get a little more stretch out of it?
Old May 12, 2010 | 07:34 PM
  #922
4DGS's Avatar
^ 15mm front and rear.
Swap your 255/35 to the rear and run a 225/35 on the front.
That'll be hellaflush, you want?
Old May 13, 2010 | 10:36 AM
  #923
Pepper's Avatar
Will a 255 rear give me issues driving (reliability/safety wise)?
Old May 13, 2010 | 10:56 AM
  #924
4DGS's Avatar
You can run a 265 if you're worried. Deeznuts(the sedan just above) is running a 265 on a 10.5 there I believe.
Old May 13, 2010 | 03:23 PM
  #925
GOAT35's Avatar
sedan and fuel eco
im runnin 18''s 245 on my sedan and im averaging 20-22 highway n street but if i go up to 20''s on 235's since thats the same overall circumference im thinking only the weight increase of the rims themselves will be a factor.....but how bad!
Also this will be my 1st time runnin 20's ever in my life and i heard 235s are risky i also do bout 30-40 miles freeway a day! any advice would help an upcoming guy! Thanks!
Old May 14, 2010 | 06:19 PM
  #926
pch2005's Avatar
Is 19x10.5 +0 too aggresive for the front of a coupe? It's like -13 on a 9.5... Could I pull it off without using control arms in the front and just rely on being slammed? I was told to use a 235/35 for the front.
Old May 14, 2010 | 09:54 PM
  #927
gphoenix's Avatar
Hey Guys I NEED Help , I have an 06 G35 coupe (stock) and also i just got some PIAA SUPER ROZZA rims , But i was wondering. THE REAR wheels are 19X10 can I RUN 275 35 19 with no problems .... PLEASE HELP
Old May 15, 2010 | 03:31 AM
  #928
Dranom's Avatar
^depending on the offsets
you probably need to roll rear fenders just in case
Old May 15, 2010 | 02:02 PM
  #929
gphoenix's Avatar
Any body running PIAA SUPER ROZZA and what size of tires
Old May 15, 2010 | 02:09 PM
  #930
4DGS's Avatar
^ coupe or sedan? How wide of wheels?
Lots of people are running SRs, but that's a really vague question.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
