Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
May 26, 2010 | 04:40 PM
  #961
wider than the 245 and 225? Thats whats on the car right now. I WAS going to put my 205s on there because of the rims. But I've decided to just keep the stock 245/225 tires on the car and sell my 205s
Reply 0
May 26, 2010 | 10:07 PM
  #962
What's the best offset so I won't need to buy spacers?
Reply 0
May 29, 2010 | 09:58 AM
  #963
ok my wheel specs are 19x9.5 +23mm front and 19x11.0 +15 for the rear.. I was told that the rear would clear a BBK.. and the front wouldnt... now... would wheel spacers help clear the BBK in the front.. and if so what size would you think i need?
Reply 0
May 29, 2010 | 04:11 PM
  #964
i got a 03 sedan, i want to put 18x9.5 +35 all around. will this work, an what might my tire options be. yes i will roll front an rear fenders. Running G coupe tein s.tech.
Reply 0
May 30, 2010 | 01:34 AM
  #965
I usually dont like asking these kidn of questions, but i am lowered on z h-techs with spring mount mod. I am getting some new wheels are are 19x8.5 F and 19x10 R
The tire sizes are 245/35/19 and 275/35/19
offsets are 15 in the fronts and 20 in the rear
Do you guys think ill need to roll my fenders?
Thanks guys
Reply 0
May 30, 2010 | 11:07 AM
  #966
Shane I have 19x9.5(F) +24 and 19x11(R) +29 what size spacers do you reccommend and what brand, also will I need an alignment after installing the spacers. Thanks for your help.
Reply 0
May 30, 2010 | 11:08 AM
  #967
forgot tire size (F) 245 35 19 (R) 275 35 19
Reply 0
May 31, 2010 | 06:14 PM
  #968
hey im running 19x8.5 + 17 in the front and 19+10 + 22 on the rears and hvae 255/35/19s in the front, whats the best for the rears. lmk thanks
Reply 0
Jun 2, 2010 | 12:30 PM
  #969
Noob here really trying to figure out if i can get a BBK setup... really need the help and advice from the experienced members here..
(ok my wheel specs are 19x9.5 +23mm front and 19x11.0 +15 for the rear.. I was told that the rear would clear a BBK.. and the front wouldnt... now... would wheel spacers help clear the BBK in the front.. and if so what size would you think i need? )
Reply 0
Jun 3, 2010 | 12:31 PM
  #970
what max wide I can put on my rear oem 18' ?
Reply 0
Jun 3, 2010 | 02:21 PM
  #971
bump
Reply 0
Jun 6, 2010 | 01:47 PM
  #972
Need help! I'm new to the forum and have leanred a lot but not confident enough to know what to do here. I have an 04 sedan with aero kit and I have a chance to buy 07' M45 wheels with 245/40/19 tires on them. The wheels are 19x8.5 all around, offset 47. Others have installed these with wheels on 1st gen. sedans with 15mm spacers. The question is whether I need to run smaller tires to avoid rubbing, say 245/35/19 or 240/35/19. The car is not dropped. Thanks!
Reply 0
Jun 6, 2010 | 02:04 PM
  #973
I run 245 40 19 on my wheels now they are 8 by 19" with a 30 offset. It gives the exact same diameter as my stock sport rims and 235 45 18" did.
I did have to run 5mm spacers in the front to get my old M45 sport rims to stop rubbing on the upper control arm in the front.
Reply 0
Jun 6, 2010 | 02:21 PM
  #974
Is your sedan a 1 st generation? Overall, do you think I can run the 245/40/19s without trouble? Many thanks!
Reply 0
Jun 6, 2010 | 02:24 PM
  #975
Yes, and yes. With the right offsets (spacers).
Reply 0
15  55  61  62  63  64  65  66  67  68  69  75  115  165
