another Lug Nut w/ stock Rays question from Tikiman12
on
Hello,
My question is will MUTEKI SR35 closed ended lugs be visible on the stock 19 rays? or should I go for the MUTEKI SR48 open ended lugs?
I like the look of closed ended but I want the lugs to stick far enough out for the color to be seen.
Thank you for your help
on
I'm pretty sure it can as long as its not an acorn shape
$225, but same difference!! Haha, i figure i'll never have to buy lugs again with these
You can use aftermarket lug nuts on OEM wheels as long as you dont have "mag" style lugs
IE: Toyota lugs with the flat washer attached. G37's also have mag lugs
Sorry, I'm not familiar with those wheels. The only reason I even knew about the Rays was because I had to mount them on my car once in an emergency and only had my Project Kics neo-chro with me, and did some research on whether or not it was safe.
