need advice on offset...
Old Jul 21, 2005 | 02:14 PM
Mik's Avatar
Mik
hi there,
i'm not that knowledgeable about offset for wheels.. well, wheels in general really. i need some education and advice.
i am about to buy some rims, 17x7 with a +42 offset. these will be my winter rims. now the questions...
- will th +42 offset fit my 2005 G35 6MT sedan?
- what does this mean exactly?
- what would be the difference between a +42 and +45 offset?
thanks in advance!
Jon
Old Jul 21, 2005 | 02:45 PM
Chico's Avatar
Yes they will fit just fine provided you get the right bolt pattern.
Old Jul 21, 2005 | 03:14 PM
LUV2DRIVEMYG35's Avatar
Originally Posted by Mik
hi there,
thanks in advance!
Jon
Offset is the distance between the center of the rim and where the inner rim hub face meets the wheel hub. A +42 offset means that the face of the rim that meets the hub is 42mm out (towards the street) away from the center line of the rim. The amount of offset that is acceptable depends upon the width of the rim and the starting distances the OEM rim is away from suspension or brake components and the fender. For example, my OEM rims are a +30 offset. Taking the rear wheel as an example, going to a +20 offset and increasing width from 8" to 9" in the rear will effectively push your rim edge out 10mm (30 - 20) and another 1/2" or 12.7mm, for a total of 22.7mm towards the fender (street). From what I've been told, 28mm total push out towards the fender is about the max you want to go with before you'll need to roll your fender for an '04 G35 coupe, sorry don't know what it would be for the 05 sedan.
In your case, if you're going from an 8" to a 7" width, you're effectively coming back 12.7mm from the fender just due to the 1/2" difference in rim width. I don't know what the offsets are on the 2005 wheels, but if it's +30, then a +42 will effectively pull you another 12mm in from the fender for a total of 24.7mm in from the fender. (As for the distance towards suspension and brake components, you'll be moving 12mm inward, but the 12.7mm reduction in width will effectively pull you out 0.7mm as a final result - almost no difference).
So if you don't mind having a wheel that looks pushed in about 24.7mm (31/32nds of an inch) more than stock then you should be ok. Again that based on an OEM +30 offset. If your offset is more, then you wheel will be pushed in more, if it's less then it will stick out more.
Old Jul 21, 2005 | 03:47 PM
Mik's Avatar
Mik
LUV2DRIVEMYG35: thanks, that was very helpful!
now, does anyone know what the offset for the 2005 G35 6MT sedan rims r? the tires r the Goodyear Eagle NCT5 235/45R18 if that helps.
thanks again!
Old Jul 21, 2005 | 04:14 PM
You could try asking your local Infiniti dealer (parts department), however I've found their info not always accurate. Dan at EverythingG35.com would likely know. He's pretty knowledgeable.
Old Jul 22, 2005 | 05:50 AM
skeleton_cru's Avatar
Sedan
thanks again!
I haven't heard that the '05's have a different offset than the '03-'04. With that in mind you will be fine with the +42 offset.
Old Jul 22, 2005 | 06:42 AM
harleydood's Avatar
The offset of +42 will work fine as will the tires that you suggest. I believe but could be wrong, the offset on my stock 05 x wheels is +45mm. In doing a ton of research as of late for wheels, I have seen some go as low as +35mm with a 19x8.5 in the rear (with the x that would be all the way around...).
Hope that helps.
Old Jul 22, 2005 | 02:19 PM
Mik's Avatar
Mik
excellent! thanks guys, u have been most helpful.
what do u think of this set up... i am getting a set of CSA Pursuit 17x7 rims, with 225/55/17 Kumho KW19 winter tires.
i don't need anything really bling-bling for winter.
Old Jul 22, 2005 | 03:57 PM
I'm not sure if this is an issue with the sedan so much as it is with the coupe, but if your sedan had VDC then perhaps it is. You will want to make sure that regardless of what rim diameter/tire profile set up you go with that the over diameter is fairly close (+/- 1/4 inch) of your OEM tires. I'm no expert here but from what I've learned, the ABS and VDC systems expect a tire diameter to be close to that of OEM to be most effective.
Old Jul 22, 2005 | 07:00 PM
Sedan
Good advice. You can use this wheel/tire calculator to get close to matching the overall diameter of the stock wheels.
http://gs.tolan-hoechst.com/tirecalc.htm
The spec. you want to look at is "Tire Height".
Fox843
Nov 7, 2015 05:43 PM
Rose M
Oct 12, 2015 10:00 AM
6spdGspot
Oct 5, 2015 01:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
