MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Engine, Drivetrain & Forced-Induction
User Name
Password
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Rate Thread Display Modes
Old 05-08-2009, 06:30 PM
Engine stalls on deceleration ?!?! Anyone else had this problem ?
So for some reason my engine has twice now stalled on deceleration.
I'll be exiting off of the highway and shift into neutral to coast as I slow down for say a light or something on the service road and all of a sudden without any audible or physical warning the engine will shut off even though all the electronics are running without any problems.
Btw, the car drives absolutely normal otherwise.
If it weren't for a more firm steering column I wouldn't have noticed it at all even the first time.
I've been lucky and just got a SES light come on so I'll be checking it as soon as I get access to a reader.
Just wondering if anyone else on here has ever expierenced a similar problem.
The only mods that are on this car drivetrain wise are nismo exhaust, headers, t-stat.
I once had a vortech full kit on there with the unichip and use the cipher to increase the idle RPM but changed it back to the factory RPM before getting rid of the FI. After uninstalling everything I've had not a single issue for about 2000 miles now so this is an odd new problem to me.
Old 05-08-2009, 06:31 PM
i had this for a while when i got my lightweight flywheel, then i got my idle bumped and everything is bueno now.
__________________
06 G35 6MT Tuned by Uprev. PM ME ABOUT TRANSGO INSTALLATIONS!
Old 05-08-2009, 06:57 PM
oh ok I guess I'l just pick up another cipher cable and bump my idle a tad.
Old 05-11-2009, 07:42 PM
so SES light shows 0300 0174 and 0171.
0300 is misfire and 174/171 are bank 1 and 2 running lean condition.
I checked the MAF sensor and it doesn't look dirty at all.
It only happens when I'm driving over 40 mph and shift into neutral and it drops down to a super low IDLE.
Old 05-11-2009, 08:06 PM
I think it might be related to my car being hit in the back a few weeks ago. this problem only started happening since I got my car back after the accident. very bizarre!
Old 05-12-2009, 07:35 PM
so here's an update. I took it to the nissan dealer in town and they did the idle air volume relearn on it and it seems to be ok so far. no stalling yet but on idle it does seem to run very lean (17s and 18s AFR) and I only know b/c I still have my AFR gauge in.
I recall my car idling at around mid 14s to low 15s previously. Does anyone else know if this is true?
Old 05-13-2009, 01:17 AM
ok i'm gonna check for air leaks this coming weekend.
it only has problems on idle.
Old 05-16-2009, 01:05 PM
the nissan dealer here in town diagnosed the problem as a MAF sensor failure. replaced the MAF and still had the same problem. will take it back in to them for them to re-diagnose.
Old 05-19-2009, 10:16 AM
so the nissan dealer gave up. they didn't however take out the air-duct. I decided to take it all apart myself and see if there were any leaks while at the same time cleaning up my k&n drop in filter.
I think I figured it out!!!
So I took apart the engine's factory air intake system and the resonator of the air duct was broken and hinged.
I'm gonna replace it with a z-tube and hopefully tomorrow my car will be back to 100%.
Old 05-19-2009, 12:14 PM
SUCCESS!!! Once replaced the engine runs PERRRRFECT!
Old 05-19-2009, 01:58 PM
Tollboothwilley's Avatar
2003 Infiniti G35
Good. Glad you got that figured out.
I was gonna say..the only reason I have heard of people really stalling without major mods would be from a intake leak. It drops the idle.
__________________
Stillen Airbox | JWT Popcharger | Z-Tube | UR Light Crank Pulley | E-Fan | Catch Can | GG 10 Wire | MD Copper 1/2" Spacer | TB Spacer | Kinetix HFC | MD XYZ + VQ Resonated | Stillen Engine Damper | SPC Rear Camber | Stillen Sways | CircuitSport Tie Brace | 350Z Suspension
Old 11-02-2009, 05:14 PM
2004 Infiniti G35
Finally I found this thread, I just started having the same issue, but I am not throwing any codes what so ever and like the OP, my car is otherwise running perfectly. In fact it seems peppier with this nicer cooler air we're getting.
Anyhow, I guess I'll check my intake path, I do know that ever since I bought the car, one of the latches has been missing on the air box, but this problem did not start until recently (so 40k miles later). I'm due for a new air filter, so I'll go pick up a purolator tonight and see how that goes. I just hope I dont have to replace the MAF.
It stalled on me this morning and just like the OP, if it wasnt for the firm steering I would not have noticed.
My other guess was bad choice of oil. I recently switched to Shells Rotella-T Full Synthetic 5w40 and it seems to be working well, unless of course it has something to do with this recent issue. For now I'll do the air intake stuff and wait to see how it does for these next 1500 miles before my oil is due for a change. If it is still there, I'll go back to a convential full synthetic 5w30.
I also just found that it could be related to the crank position sensor, but again Im not throwing any codes so I wont know that until I do.
__________________
2004 DG Coupe 6MT l Cobb - Tokico - Nismo - Forgestar - Hankook - Hawk - Seibon - Circuit Sports
Tags
2003, car, decel, decelerating, deceleration, dies, engine, g35, itr, slowing, stalling, stalls, what
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
