Hard Gear Changes?
Hard Gear Changes?
Hi,
I hope I can explain this well enough.
I test drove an '07 G35S, yesterday. I had it in manual shift mode (or whatever it's called) so I could try out the paddle shifters. I took an on ramp in 2nd and punched it. At about 6000-6500 RPMs, I hit the up paddle for 3rd. It shifted right away, but what I want to ask about is what that shift is supposed to feel like, because it seemed to change gears much harder than I expected.
I could just be used to my other auto transmissions feeling like a normal gear change when I shift manually (my old Altima SE-R for instance), but this was a hard bump that almost felt like another car had hit me in the rear end.
Is this normal? Is it supposed to change gears with such a hard "thunk" (I can't think of how else to describe it)?
Thanks!
Thanks!
Hi,
Thanks!
Thanks!
A small amount of jarring wouldn't be surprising shifting at that high # of RPMs (I do it all the time - how anyone can resist that engine noise, I don't know) but a major thunk is a little concerning. Hard to diagnose remotely but could need everything from a simple transmission flush to a new tranny, which would cost upwards of $3k. What's the mileage on the car? (Also good to see you're still test driving!)
It is a fairly high-mileage car, and I wish there was a way I could get someone knowledgeable enough about these cars to ride along with me. The shift could be perfectly normal, for all I know. I was surprised at how quickly it went from 2nd to 3rd.
Car Listing: http://www.infinitiofgwinnett.com/us...b1cebebb61.htm
Thanks, Nifti. It is a fairly high-mileage car, and I wish there was a way I could get someone knowledgeable enough about these cars to ride along with me. The shift could be perfectly normal, for all I know. I was surprised at how quickly it went from 2nd to 3rd. Car Listing: http://www.infinitiofgwinnett.com/us...b1cebebb61.htm
Yes that is normal. I complained about it for a long time to the dealers and came back nothing. Mine has been doing that since I bought it brand new. When I got the transgo kit for my car I had the guy look at my transmission to see if everything is normal. He pulled it apart and everything looked normal. During that point when your car is shifting there is less slippage going on in your transmission.
RemmyZero
V36 DIY
04-23-2018 11:13 AM
FS[SoCal]: D/S 4080 Enclosure & JL Audio W6v2 10 inch
MrIP35
Audio/Video/Electronics
11-08-2015 10:47 AM
