DIY: Add a sub to your Bose equipped G35 Coupe
Rating: Thread Rating: 7 votes, 4.86 average.
Old Sep 3, 2007 | 03:10 PM
  #136
Gilley's Avatar
^ www.fatmat.com
Old Sep 19, 2007 | 01:46 PM
  #137
rob40wilson03's Avatar
i know this can be found all over the forum but it's tedious to read through every single search result until i get the answer but......
does the Bose amp power the speakers in the coupe doors? if so, will putting infinity kappas in the doors mess things up if LATER i want to add an amp and sub??
thanks guys
Old Sep 19, 2007 | 02:53 PM
  #138
Gilley's Avatar
Yes.
Maybe, if you get 2 ohm speakers to replace the Bose speakers and your new amp doesn't handle 2 ohm loads.
Old Sep 20, 2007 | 01:11 AM
  #139
EndlessWaltz112's Avatar
how long did this take for you to do this? how much was that box? i got everything already but im kinda iffy on doing this myself..
Old Sep 20, 2007 | 04:41 PM
  #140
broke_as_ajoke's Avatar
real nice write up bro... .. i'm looking to do the same thing with mine o7 G
Old Oct 4, 2007 | 10:06 PM
  #141
ZoominG35's Avatar
Settings For Stock Hu And Amp?
For Those Who Are Running The Same Setup:
4080 Box, Jl 500.1, And 10w6 What Settings Do You Guys Have?
Bass =
Treble =
Volume =
Fade =
Amp Gains =
Thanks For Any Reply
Old Oct 14, 2007 | 12:47 PM
  #142
TR11's Avatar
I have a question:
I have the 10w6 and the 500/1.
When im converting wiring up the RCA's for the input into the amp I need help.
I have two RCAs 1 black, 1 red. Each has two twisted wires coming off them.
Now, what do I hook up to each of these wires?
I have the left and right rear + and negatives, making four in total and the 4 RCA wires in total. Which goes to which? Does it matter?
Can I go left + to red RCA positive, and left - to red RCA negative, then right + to black rca + and right - to black rca -?
Or is this not the way to do this. Or do I use only 1 of the channels, example, just the left rear channel and hook up 1 wire from each rca to the speaker wire. Like; + from red RCA to + from left rear and - from black RCA to - from left rear? Then leave the right channel alone?
Also, how do you suggest I disconnect the 6x9's, at the speaker? or from the out from the amp.
I also couldnt locate a DIY or guide or anything on removing the 6x9's or taking off the rear deck to add padding for rattling.
thanks, any help is appreciated.
Old Oct 15, 2007 | 10:09 AM
  #143
ntoxtiger's Avatar
ahhh... sub & amp in my trunk will leave me no room for my golf clubs. Nice work though.
Old Oct 15, 2007 | 12:14 PM
  #144
TR11's Avatar
i think i got it guys, just double checking.
Did I wire this right:
I took the Right Rear Positive & Negatives, and wires them into the Positive and Negative of the Red RCA.
Then I took the left positive and negative and wired them to the left Rca. Positive being the pin of the RCA.
Am I all good?
I have a feeling if I want to crank it above like 22, the stock fronts will start to sound brutal. I may try this infinity kappa route if it'll slightly prevent the distortion. Do they just sound better or give you more headroom on the volume you can get them to without distorting them. I know without a better amp it may be the former.
Thanks,
Old Oct 15, 2007 | 01:46 PM
  #145
TR11's Avatar
ps: any further tips on removing the bottom rear seat cushion? it really feels like im going to break something.
Old Oct 15, 2007 | 02:07 PM
  #146
Gilley's Avatar
Coupe or sedan?
Pull up in the middle of each side for the coupe. The sedan has a plastic pull ring release in the middle of each side. Then pull up on the bottom seat cushion.
Old Oct 15, 2007 | 04:17 PM
  #147
TR11's Avatar
coupe.
thanks - will try
Old Oct 16, 2007 | 12:48 AM
  #148
TR11's Avatar
done - everything works great - have to wire remote into the sub tomorrow, i thought auto sensing would work but its iffy. Says right in the instructions - not recommended for line level..
so i have to do that and then stop my rear deck and roof liner at the rear where it hits the back window from rattling like crazy.
tips?
Old Oct 30, 2007 | 02:42 AM
  #149
tbg35c's Avatar
This is a great write up, thanks. Can anyone point me where to get the complete JL 4 gauge amp kit for this project from? Does it contain everything including battery connector, twisted RCA wires, etc?
Old Oct 30, 2007 | 11:08 AM
  #150
TR11's Avatar
just go into any car audio store and tell them what your doing. They'll give you the right stuff.
I grabbed 16' of 2 Gauge power wire. 3' of 4 ga. ground wire. Fuse kit w/ fuse, 2 battery connectors, 6' RCA's. 3' 12 Gauge speaker wire for remote.
I chose 2 gauge power wire because if I add another amp later for the speakers, Ill still have a nice safety margin.
You have already rated this thread Rating: Thread Rating: 7 votes, 4.86 average.
