DIY: Add a sub to your Bose equipped G35 Coupe
Old Jan 7, 2012 | 02:32 PM
  #571
g35SedanSC's Avatar
Originally Posted by SAMzG35
look at the picture below
there's a fuse inside that plastic cap, its usually within few inches from your battery when you have an aftermarket subwoofer
offtopic,is that yor strut brace,if yes you had to remove the battery cover?
Old Jan 7, 2012 | 03:55 PM
  #572
syshs's Avatar
Got it. Thanks.
Another question. On the 2006 g35 will i need to take the stock subwoofers out to fit the 4080 box?
I got the passenger side 4080 box. Looks like the box wont slide in w/o taking the stock sub, sticking out from the top, out but i might be wrong.
Old Jan 7, 2012 | 04:01 PM
  #573
SAMzG35's Avatar
G35
Nope. Just some random picture off google to show where the fuse sits, i edited the post. thanks for pointing it out
Old Jan 7, 2012 | 04:15 PM
  #574
Wrathernaut's Avatar
Gentle Manne of Leisure
Originally Posted by syshs
Got it. Thanks.
The 4080 box sits behind the rear tires. The stock subs and 6x9s sit in the rear deck, so unless you have an aftermarket sub, there's no way at all they even get close to one another.
If you're talking about the zenclosures box that sits behind the rear seats, however, I think it fits without removing them.
Regardless, you should remove the factory sub or 6x9s so that the bass can get into the cabin.
Old Jan 7, 2012 | 06:42 PM
  #575
syshs's Avatar
^ i had to slide it at an angle and it slide in.
if you try to put in it straight, the 6x9 hanging from the top, comes in the way.
this is the case of a 06 g35 coupe.
Old Jan 8, 2012 | 03:24 PM
  #576
ThatOneDude's Avatar
I didn't even know there was a factory subwoofer o.o.
It's recommended to remove the 6x9's in the rear deck?
My zenclosure box slid in without removing anything, but was a little difficult to figure out at first.
Old Jan 14, 2012 | 10:34 PM
  #577
bluranver6's Avatar
look nice but where did the box come from or did you make the box yourself and im just worried about the
You need to be able to convert 18 gauge wires to an RCA jack to connect to the amp. One way was to get an RCA jack with a twisted pair of wires that you can cut and then splice. Another option is to get the JL line conversion that I used (pricey - $25, but I couldn't wait for mail-order). Splice them with in-line splicers available at Radio Shack and tape it up with electrical tape.
i dont think i understand this if i get the adapter which wire goes where? and where do i get one of the adapters at/
Old Jan 14, 2012 | 10:36 PM
  #578
cmdedge's Avatar
one wire is positive and one is a neg you can get them at most any car audio shop.
Old Jan 14, 2012 | 10:38 PM
  #579
bluranver6's Avatar
awesome thanks how bout the box all i find online is th box thats in the middle not on the side thats what i would like
Old Jan 14, 2012 | 10:47 PM
  #580
bluranver6's Avatar
o and one more thing do our cars have a factory sub where would it be...? "this is my firs G"
Old Jan 14, 2012 | 11:00 PM
  #581
cmdedge's Avatar
well welcome to the community and the rear deck speakers are your factory "subs" as far as i know. dome people say remove them but i left them in place and they still produce sound and it doesn't bother me.
Old Feb 8, 2012 | 01:38 AM
  #582
w4kj4k's Avatar
So if i have already done this and i just now get a DD set up, will my sub continue to work? Sorry, super noob question! Thanks in advance
Old Feb 8, 2012 | 01:53 AM
  #583
Ray Ray's Avatar
It should still work; however i would wire the rca from the amp to the back of the headunit instead of having it wired to the stock bose amp. This way you can have better control of the sub amp and subwoofer.
Old Feb 8, 2012 | 02:09 AM
  #584
w4kj4k's Avatar
ahh sounds so complicated, when i got it to work i was so glad that it didnt blow up haha
Old Feb 9, 2012 | 09:34 PM
  #585
Xx AzN xX's Avatar
does anyone know where to find this piece?
You have already rated this thread Rating: Thread Rating: 7 votes, 4.86 average.
