How To Install A Sub In A G sedan Using Stock Bose System
Old Mar 16, 2013 | 09:29 PM
  #196
Knew_EraG's Avatar
Can anyone please confirm this -----> "In the coupes :
Locate the bose amp. (drivers side trunk under the plastic next to the spare tire)
The remote turn on wire is the Light Blue in the black / blue plug.
The sub wires at the amp aswell are in the White plug.
Colors for the sub are Blue/red is postive and Blue/White is Negative."
I have a 2004 G coupe, bose system. I plan on doing this tomorrow and I don't want to run into any unecassary problems like splicing the wrong colored wire. Thanks in advance guys.
Old Mar 27, 2013 | 11:43 PM
  #197
SickFourDoor's Avatar
help please!!
wondering if anyone can help me. I tried wiring up my sub and amp to the bose system. I bought a line out converter, spliced that into 2 wires going into the subwoofer black and white, then spliced a remote wire the the green w/ white stripe from stock amp. I read this DIY on a different forum. Well turns out it did not work and now I have no radio what so ever. it turns on but cant get any station it seems like it has no signal at all. I reallly hope someone can try and help me out with this issue i have been having shitty day. By the way i have a 2003 g35 sedan. thanks
Old Mar 28, 2013 | 08:00 AM
  #198
MotoCARR's Avatar
G35 Sedan
When you say you have no radio, do you mean no radio stations come in, like you just hear static, or is there no audio whatsoever? Does the sub work of you play a cd?
Old Mar 28, 2013 | 08:45 AM
  #199
No sound comes out what so ever not even static. When i try to change stations it goes through them like there are none getting a signal. It will just seek past every station. I had power to the amp and sub and when i did not hear any sound i disconnected them. I cannot play a cd right now becasue of the legendary CD ERROR FO.
Old Mar 28, 2013 | 09:22 AM
  #200
MotoCARR's Avatar
G35 Sedan
-Did you remove the factory radio at anytime and forget to plug the antenna back in? Was everything working(besides the CD) before starting the install?
-Even with everything disconnected does the radio still seek past all stations?
-100% sure you tested and tapped into the correct green/white wire on the amp?
Old Mar 28, 2013 | 09:44 AM
  #201
Wrathernaut's Avatar
Gentle Manne of Leisure
There's a fuse specifically for the antenna amplifier - fuse #6, that probably got burned out when you used the wrong green/white wire from the radio.
Did you use the green/white at the subwoofer's amp, or elsewhere in the wiring?
Old Mar 28, 2013 | 09:45 AM
  #202
I never went near the radio. Yes everything worked perfectly fine before i tried this. Only thing i unplugged at all was the 1 connector to the amp to splice the remote wire to the green/white wire then i plugged it back in.
Old Mar 28, 2013 | 09:47 AM
  #203
I will check that fuse once i by the car!. I used the green/white wire right at the connector for the amp.
Old Mar 28, 2013 | 09:56 AM
  #204
MotoCARR's Avatar
G35 Sedan
Wrathernaut saw where I was going lol. I couldn't remember if there was a separate fuse or not. It should be a simple fix.
Old Mar 28, 2013 | 10:28 AM
  #205
Either you accidentally grounded the amp signal wire, or the amp is drawing too much power, which is causing the use to blow.
If it blows again, I recommend using the cigarette lighter's +12v power wire as the power signal for your amp.
Old Mar 28, 2013 | 12:11 PM
  #206
Thanks alot for the help so far guys! Once i get out of work i am going to check it out and i will get back to you if i get it fixed or not.
Old Mar 28, 2013 | 05:49 PM
  #207
I am not seeing any fuse for the amp. Only the radio...
Old Mar 28, 2013 | 07:06 PM
  #208
Just wondering if you can help me anymore at all? Could my HU finally shot or does it have to deal with the amp?
Old Mar 28, 2013 | 07:07 PM
  #209
The radio and amp share the same fuse, so if the radio's on, the antenna amp should have power also.
Check for power at the antenna amplifier in the driver's side rear C-pillar behind the trim. If there is power there, either the antenna amp itself is screwed, or the radio's tuner's bad.
Old Mar 28, 2013 | 07:35 PM
  #210
fine there. this sucks i am running out of reasons why i got no sound
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
