USA Spec Pa15-NIS
Jun 6, 2010 | 01:03 AM
  #136
Quote: @Bigtime - I think that's if you use CD right? I'm using RADIO... maybe?
@Djfermion - I don't know why your light would turn on unless you did something wrong. All you do is plug in the PA15 harness and attach the original harnesses to the PA15 and attach the ground.
If I just press PTY CAT > SEEK it'll go to Direct Mode
I use SAT, and all I have to do is press 5 and it goes to direct mode.
Reply 0
Jun 6, 2010 | 01:17 AM
  #137
3rd time was a charm. Thanks a lot Calvin the light is gone. So there isn't a real reason the SES light was on right, nothing to worry about?
Reply 0
Jun 6, 2010 | 01:18 AM
  #138
Quote: 3rd time was a charm. Thanks a lot Calvin the light is gone. So there isn't a real reason the SES light was on right, nothing to worry about?
Nothin' to worry about.
Reply 0
Jun 6, 2010 | 01:24 AM
  #139
Quote: I use SAT, and all I have to do is press 5 and it goes to direct mode.
Oh, I don't have SAT, I have PTY CAT
Reply 0
Jun 6, 2010 | 02:12 AM
  #140
Quote: Oh, I don't have SAT, I have PTY CAT
SAT is where the adapter is connected to, thats the mode you use to operate the device. I think pressing 5 does switch to direct mode, I haven't tried it.
Reply 0
Jun 6, 2010 | 05:43 AM
  #141
Quote: SAT is where the adapter is connected to, thats the mode you use to operate the device. I think pressing 5 does switch to direct mode, I haven't tried it.
yup, 5 does the job. It took me some time of pressing buttons to figure out how to do it because I don't like using the head unit.
Reply 0
Jun 7, 2010 | 01:04 AM
  #142
if you have the PA15-INFI, its required to adapt to the SAT
But the PA15-NIS can be used either with the SAT input, Radio, or CD
I have to use Radio because I don't have SAT
Reply 0
Jul 9, 2010 | 01:56 AM
  #143
So if my headunit has no "SAT" button, I should buy the PA15-NIS? I think im prewired for sat but not installed. I have an 07 G35 Coupe with OEM Navi...
Also, can I control the iphone while plugged in? I want to play pandora radio through my car speakers.
Reply 0
Jul 10, 2010 | 12:00 AM
  #144
ok so this is whts in my trunk
so it appears im pre-wired (i certainly hope so), so I was under the impression, all i need now is the USA PC15-INFI connected to that empty white connector (highlighted below) and fish wires to where i would want to connect my iphone.
<a href="http://s822.photobucket.com/albums/zz150/freepicaccount/G35-Truck_Harness/?action=view&current=Empty_Connection.jpg" target="_blank"><img src="http://i822.photobucket.com/albums/zz150/freepicaccount/G35-Truck_Harness/th_Empty_Connection.jpg" border="0" alt="Empty Conn" ></a>
am I even close or did i completely mis understand the connections.
thanks
Reply 0
Jul 10, 2010 | 12:12 AM
  #145
Is the Pa15-INF compatile with the iPhone 4?
Reply 0
Jul 10, 2010 | 01:28 AM
  #146
Quote: Is the Pa15-INF compatile with the iPhone 4?
Yep I have an iPhone 4 and Pa15-INF, works just like any other ipod/iphone.
Reply 0
Jul 10, 2010 | 01:48 AM
  #147
Quote: Yep I have an iPhone 4 and Pa15-INF, works just like any other ipod/iphone.
Thanks for the reply bro. Ima go ahead and cop!
Reply 0
Jul 10, 2010 | 07:19 PM
  #148
any inputs..?
thanks
Reply 0
Jul 10, 2010 | 11:14 PM
  #149
Quote: any inputs..?
You can only use the Pa15-INF if you have satellite radio installed, for the PA15 it doesn't matter if you are pre-wired or not.
So if the have it installed, you plug the Pa15-INF into the satellite radio box in the trunk.
If you don't have the satellite radio box in your trunk, then you need the Pa15-NIS and it plugs into the back of your head unit.
Your trunk area looks a little bit different then my 06 coupe, but from the pic it looks like that box on top of the bracket is the satellite radio box. Try and read the label and see what it is. it looks like it but I could be wrong.
using your Radio button on you head unit can you keep pressing it until it selects XM-radio ?
Reply 0
Jul 10, 2010 | 11:52 PM
  #150
Quote: Your trunk area looks a little bit different then my 06 coupe, but from the pic it looks like that box on top of the bracket is the satellite radio box. Try and read the label and see what it is. it looks like it but I could be wrong.
The only thing that makes sense to me on that box is the label "Visteon Voice technology". a google search brings up some thing related to bluetooth (which i have).
regardless, im pretty sure i ve read in these same forums, that just having a prewired harness is sufficient to have the PC15-INFI connected.
but i could be wrong....
Reply 0
