USA Spec Pa15-NIS
Old Aug 18, 2010 | 01:41 AM
  #196
WhosRich's Avatar
Can someone quickly summarize the differences between this and the PA11-NIS?
-PA15 has text
What else?
Old Aug 18, 2010 | 10:33 AM
  #197
flyinb501's Avatar
Does anyone know what you have to do to get the auxillary port to work? I tried using my Blackberry and Pandora and it would just play for a few seconds and then automatically change the fm channel and shut off.
Old Aug 25, 2010 | 06:24 PM
  #198
mao's Avatar
mao
Question for you guys, will i have to remove my shift **** (my car is a 6MT) when taking my dash apart to install the Pa15-NIS? The reason i'm concern is because i've read that you risk ruining your shift **** if you remove it.
i know that an automatic G35 shift **** can be removed with ease.
Old Aug 25, 2010 | 07:37 PM
  #199
msommers's Avatar
My shift **** was a bugger to get off, but it does eventually.
You MUST use this tool or something like it to ensure the rod does not rotate. I don't know what happens if it does rotate but it doubt it's good! I made a little tick mark on the rod and the white fluff around it just to make sure. I call these adjustable pliers, I'm sure there are many other names.
Some people use a towel so it doesn't scratch it...I said **** it just incase it slipped because man, I was reefin on this thing and if it slipped it would have been bad. Unscrew counter-clockwise and you'll be fine.
Also, you can use an adjustable wrench near the base of the shift **** (definitely use a towel here) but I just used my hand as I didn't want to gouge the crap out of it.
Be gentle taking off the interior pieces on either side of the headunit
Old Aug 26, 2010 | 10:32 AM
  #200
flyinb501's Avatar
No! There is absolutely no reason to remove your shift ****. The center console around the shift know just pops right out and there is enough slack in the shift boot to move the whole piece aside while removing the head unit.
Old Aug 26, 2010 | 04:30 PM
  #201
mao's Avatar
mao
perfect. thank you both for your response!
Old Aug 26, 2010 | 07:55 PM
  #202
rdeol's Avatar
Hi Would this work on a 2007 g35 sedan Non-Nav?
I read somewhere that all 2007 sedans are prewired for SAT.
Which part would you recommend the PA15 NIS or PA15 INF?
Old Aug 26, 2010 | 08:23 PM
  #203
thn116's Avatar
If you have the prewired sat go for the pa15 inf. Its going to be eaiser to install.
Its a combination of the switches on the box itself. The manual should show the correct combination for the use of the aux port.
Old Aug 27, 2010 | 01:19 PM
  #204
rdeol's Avatar
Thanks thn116!
Old Aug 27, 2010 | 01:59 PM
  #205
flyinb501's Avatar
So every time you want to use the aux port you need to change the dip switch settings?? If that's the case I sure am glad that my unit is still accessible...
Old Aug 30, 2010 | 12:30 PM
  #206
mao's Avatar
mao
Yes, i believe so. In order to have AUX option, your dip (#1) switch setting has to be set to on.
Old Aug 30, 2010 | 12:39 PM
  #207
mao's Avatar
mao
So i installed the Pa15-nis yesterday and i'm loving it so far!
I have a question for everybody though; In Folder mode, anyone having issues seeing the entire text such as artist or song name? When i hit the "DISP" button to scroll through the entire name, i find that it cuts off and doesn't show all of it. Is this normal? It's not too big of a deal for me since i prefer to use "Direct Mode" over "Folder Mode" but i was just wondering if maybe i installed it wrong or something?
My dip setting is as follows:
1-2-3-4
off, on, on, on.
Thanks in advance
Old Sep 1, 2010 | 05:59 PM
  #208
RemmyZero's Avatar
i can't get mine to display the song name at all. i'm not too happy with the USA spec product at this point. i also tried the combination of all switches on from your post (tried it previously) but it renders my satellite radio unusable.
it also causes my satellite radio to not display the text info properly when i go back to using the sat. unbelievable no one can make a good ipod product.
Old Sep 1, 2010 | 06:39 PM
  #209
mao's Avatar
mao
that's unfortunate to hear.
my fault, i forgot to mention, my radio is non-sat from an 2005 coupe so i don't think my dip settings will necessarily work on your car.
Old Sep 2, 2010 | 01:39 PM
  #210
thn116's Avatar
Thanks thn116!
You're very welcome!
Pretty much, but if you're going to use the aux at one point or another you have to go back to that same box to hook up your lines anyways. You can just adjust the switch then. I just kept mine on and aux hooked up to my blackberry so I can use Pandora.
1-2-3-4
off, on, on, on.
Thanks in advance
Try doing that installation procedure again. That might help. I think mine information scrolls.
Yea I'm not too happy with mine either. Its just a temporary thing until I do a full on double din unit.
