USA Spec Pa15-NIS
Old Dec 17, 2011 | 02:36 PM
  #301
ccc123pm's Avatar
X
2007 sedan has a plug already in the arm rest compartment, try that
Old Dec 17, 2011 | 06:27 PM
  #302
R6n350GT's Avatar
After a years use my cable is playing up. loosing connection etc... where can we get a new cable from?
Old Dec 25, 2011 | 04:57 PM
  #303
FlyingLumpia's Avatar
http://www.ipodcarpros.com/
Old Jan 5, 2012 | 09:32 PM
  #304
Badpreston577's Avatar
From: Fairfax County, Va (just outside Washington DC)
Originally Posted by ccc123pm
I was wondering if anybody out there has installed the PA15-NIS by USA Spec. I know the PA11 is more widely used, and from what I'm told the PA15 is newer and has some added features.
Has anybody installed the PA15 yet, and if so, your thoughts?
Here is what I was told about the PA15:
The PA11 is no longer available, its been discontinued. We are the biggest USA Spec dealer therefore it has been released to us first.
The PA15 has been reformatted and updated to be faster, better and out perform the PA11.
I have it on my 06 g35x with Bose stereo and satellite radio, it allows ipod control from the console. it allows direct and folder mode on the ipod and addtional audio from an out board source. Hope that helps.
Old Jan 6, 2012 | 01:18 AM
  #305
R6n350GT's Avatar
Mine has been great but after a year of twisting the cord it now crackles when picking up iphone and its playing. Any idea on finding a replacment cord?
Old Jan 27, 2012 | 02:53 PM
  #306
GraphiteX's Avatar
Originally Posted by Hcp911
does this work for a 2005 g35x sedan?
also am i supposed to get:
PA15NIS
PA15INF
are they the exact same?
This..only for an 04 model, looking at them on Crutchfield.com and the only difference i see is one comes with an extra harness.
Old Jan 27, 2012 | 04:38 PM
  #307
lowkeeg35's Avatar
I don't know if this helps anyone here, but I had bought the PA15-NIS because my CD changer got jammed and i really didnt want to go get it fixed. In the USA SPEC manual it says you must take out all your cds which i could not do because my cd changer has no functions whatsoever. I kind of freaked out but installed the PA15 regardless. Luckily, you don't need the CD button whatsoever as long as you dont mind using the radio button. Folder and Direct Mode work good except that i can't get it to display the names of the songs. But i could care less about that cause it says it right on the ipod :]
Old Feb 11, 2012 | 04:02 AM
  #308
Tepke's Avatar
Originally Posted by R6n350GT
I have 03 350GT (V35) *** version of G35.
I got PA15-NIS
I have NO SAT, NAV, RADIO or CD button. Only DISC
My BOSE has no 12pin plug, only 10 pin so i plug 10 pin in and connect stock 10 pin to female end of the PA15-NIS. Put cable in for iphone
iphone says accessory not recognized.
I cant get it to see the ipod at all. Pressing DISC after FM or AM does nothing... Any ideas?
Thanks
R6n350GT,
I got a 350Z and i'm also missing the 12pin plug. Only have the 10pin.
Did you ever got the PA150-NIS working without the 12pin plug?
Old Feb 11, 2012 | 07:13 PM
  #309
R6n350GT's Avatar
Originally Posted by Tepke
R6n350GT,
Hey man, yeah you dont need it from memory, it will be the only plug you dont use.
All others plug in!
They are my plugs
In the 2nd photo you can see the top wire is separate from the head unit, the other wire should be plugged in so ignore that.
Old Feb 12, 2012 | 11:14 AM
  #310
Tepke's Avatar
All others plug in!
They are my plugs
Thanks for the pics man!
The back of my radio looks like this:
As you can see, i'm missing the connector on the bottom right.
It's also explained here:
http://www.350z-tech.com/wiki/index....e_Sound_System
Tried to install the PA15-NIS yesterday again, but unfortunately I can't get it to work
Old Feb 12, 2012 | 06:04 PM
  #311
R6n350GT's Avatar
Can you please take pic of you USA SPEC plugs? looks like you may need PA11-NIS not PA15-NIS..
Old Feb 12, 2012 | 06:17 PM
  #312
w4kj4k's Avatar
do you guys know if that if its not grounded properly will it not work?
Old Feb 13, 2012 | 02:43 AM
  #313
Tepke's Avatar
These are the 3 plugs that I have in my car.
Only the first fits the PA-15NIS:
Attached Thumbnails USA Spec Pa15-NIS-cable-1.jpg   USA Spec Pa15-NIS-cable-2-3.jpg
Old Mar 11, 2012 | 03:19 PM
  #314
Makuz's Avatar
Well, I bought this device PA15-Nis, and installed on my g35 coupe 05 with boss and SAT, it was pretty easy, but i spend some time on hiding that adapter.
After i put all parts back together, and drove my car for about a day, i noticed that one of my speaker doesn't work properly, it works, but sometimes its quiet, or when it works on high volume it makes bad noise. If anybody knows what it maybe let me know plz. P.S. its a front left speaker.
Old Apr 3, 2012 | 08:42 AM
  #315
Bandy1080's Avatar
Help!
I am hoping some of you guys can help me with this issue.
Have the PA15-NIS installed in my 2005 G35x without bose or sat button. Normally I press the radio button and XM1 and XM2 show up. Been working flawlessly for 10 months now. Randomly this morning I go to drive to work and plug in the phone and the radio will not display XM1 or XM2. The unit is charging so it is not a power issue.
Any ideas at all?
