Wrathernaut's Double-Din Installation FAQ, Shopping and Resource List
Old Mar 30, 2011 | 04:54 PM
  #286
Wrathernaut's Avatar
Gentle Manne of Leisure
Originally Posted by jjthing
hahaha.. awesome!! Will you give me a discount..?? let's say.. a sirloin steak and pitcher of beer??
I will plan the trip once school's out.. I will contact you again! Btw, i'll be coming from Rockville, Maryland.. :P
Thanks so soo much!
Quite the trip. Just make sure you arrange a good time via PM, I do have training exercises and such that occasionally cross some large swaths of time.
Old Apr 2, 2011 | 09:42 AM
  #287
carlos-g35's Avatar
this info really helps
Old Apr 2, 2011 | 04:28 PM
  #288
Drtybrd61's Avatar
quick question, why the difference in part numbers between vendors for the 03-04 double din finisher in WILLOW?
MyNismo.com & Wrathernaut - 62860-0304WC
Yosi (J's Garage) & World Famous Z - 68260-AL712
Old Apr 2, 2011 | 06:03 PM
  #289
No idea why there's different numbers, but I'll put both in the list, just for completeness. I used the mynismo.com number because they were a pretty reliable source.
Old Apr 3, 2011 | 06:03 PM
  #290
or_G's Avatar
hey the Scosche universal double din trim ring didn't fit the AVN5510
Old Apr 3, 2011 | 07:20 PM
  #291
^ Nothing's perfect. That's why razor blades and scissors were invented.
Old Apr 4, 2011 | 12:53 AM
  #292
SILVERAZG35's Avatar
Anyone know what a good frequency response is good for a sub amp to be set at. Also, what about the mids/tweeters amp. Thanks
Old Apr 4, 2011 | 06:13 PM
  #293
^ Depends on the components, but this has nothing to do with this thread.
Old Apr 5, 2011 | 12:07 AM
  #294
JZ's Avatar
JZ
G35 Coupe KY0
great installs.... all thanks to his thread.
Old Apr 5, 2011 | 10:19 AM
  #295
G35xTurbo's Avatar
Hey wrathernaut, sorry for what is probably a dumb question, when wiring my new head unit to the pacroemnis do i wire the power and signal outputs from the radio to the low level inputs or just the positive and negative inputs? The pacroemnis has low level, high level and positive negative so I'm just wondering with the boss which option i would use. I'm assuming low level? Thanks!
Old Apr 5, 2011 | 11:31 AM
  #296
shawndeo22's Avatar
Agreed
Old Apr 5, 2011 | 12:51 PM
  #297
Low level are preferred. Attach them to the RCA outputs. If you can't do that, the high (speaker-level) can be used instead.
Old Apr 5, 2011 | 02:05 PM
  #298
Sorry bout that, I will tke it by the local stereo shop that put them in.
Although since I installed my own receiver, I am trying to figure out why my stereo reception is somewhat poor. It comes in great at first, but start to go in and out while driving. They same stations worked fine with the stock radio.
Any suggestions would be greatly appreciated. I have the Pioneer AVIC - 930BT
Thanks
Old Apr 5, 2011 | 05:31 PM
  #299
G35xTurbo's Avatar
Ok cool. That's what i was thinking but i feel better with some confirmation. Thanks again!
Old Apr 5, 2011 | 06:40 PM
  #300
Thanks
You can try connecting the power antenna amp signal wire to the cigarette lighter, that'll remove the headunit from the line of things that could be interfering.
You have already rated this thread Rating: Thread Rating: 31 votes, 5.00 average.
