Wrathernaut's Double-Din Installation FAQ, Shopping and Resource List
Old Jan 7, 2012 | 03:48 AM
  #691
Aztec's Avatar
Old Jan 7, 2012 | 11:55 AM
  #692
AARONHL's Avatar
Just tapped into the cars steering harness and it's still not working!!
Old Jan 7, 2012 | 12:38 PM
  #693
SAMzG35's Avatar
G35
which steering wheel harness do you have
Old Jan 7, 2012 | 12:54 PM
  #694
AARONHL's Avatar
AXXESS ASWC
First set of blinks: 3short 1long 3short (Meaning the gray/red isn't connected, which it clearly is)
Second set of blinks: 7short (I don't have an Alpine, my Pioneer 4300 hasn't detected the SWC.)
Old Jan 7, 2012 | 01:13 PM
  #695
AARONHL's Avatar
I connected the 3.5mm plug to the "AUX" on the Pioneer, so it should be in the right spot.
Old Jan 7, 2012 | 01:22 PM
  #696
AARONHL's Avatar
I AM AN IDIOT (CONNECTED TO THE WRONG PLUG ON PIONEER) Thanks guys!!!!
Old Jan 7, 2012 | 01:25 PM
  #697
SAMzG35's Avatar
G35
k i read your comment & was going to slap you, glad you corrected yourself
Old Jan 7, 2012 | 03:08 PM
  #698
AARONHL's Avatar
Hahahaha, so now it's a really tight fit to mount the JDM kit on the Pioneer!
Old Jan 7, 2012 | 04:42 PM
  #699
SAMzG35's Avatar
G35
fingers crossed, my kit should be here in few days and i'll be installing this babyy
along with this, even though not many might agree with it lol
two of these
and this one is sitting home might as well use it
Old Jan 8, 2012 | 03:35 PM
  #700
AARONHL's Avatar
Here is where to stuff the harnesses:
Old Jan 8, 2012 | 06:49 PM
  #701
SAMzG35's Avatar
G35
thanks for the picture! helps alot
so did it fit fine? and glad to see you didnt have to remove the shifter, i was kinda worried about taking that out
Old Jan 8, 2012 | 11:05 PM
  #702
AARONHL's Avatar
Make sure you put a towel over the shifter trim, that way you can lay the head unit console onto it when plugging everything in. Everything fit fine, definitely enough room. You don't want to have wires or plugs above the the plastic/metal bracket (seen where the antenna adapter hangs off in the picture above) and all the way to the plastic wall. There was actually a lot more room than I thought there would be once I put everything in the lower left.
Old Jan 9, 2012 | 01:48 AM
  #703
SAMzG35's Avatar
G35
awesome! are you using Metra or JDM kit?
Old Jan 9, 2012 | 02:08 AM
  #704
AARONHL's Avatar
JDM
My Pioneer 4300 mounts into the dash kit with a 1/4" gap at the top and sticks out about 3/8" from the face of the dash kit. Doesn't look as good as I wanted it to look, but I'm not going to complain..
Still can't figure out how to dim the brightness...it's so bright at night!!!!!!!!!
Old Jan 9, 2012 | 02:13 AM
  #705
SAMzG35's Avatar
G35
have you tried using the trim that he mentioned on page one of this thread?
You have already rated this thread Rating: Thread Rating: 31 votes, 5.00 average.
