Wrathernaut's Double-Din Installation FAQ, Shopping and Resource List
Rating: Thread Rating: 31 votes, 5.00 average.
Old Jan 23, 2012 | 11:36 PM
  #751
AARONHL's Avatar
That's a Nissan part, not Metra, you MUST use the smaller factory double din HVAC controller with that, which is about $200. You cannot use any part of your current set-up.
Old Jan 24, 2012 | 03:13 AM
  #752
SAMzG35's Avatar
G35
X2
Go back few pages I just had mine installed in an 04. You an not use anything from the stock one except the rear metal bracket. What you have there is a jdm kit without hvac controls. Which will be useles in your case without th jdm controls
Old Jan 24, 2012 | 09:33 AM
  #753
Wrathernaut's Avatar
Gentle Manne of Leisure
Originally Posted by g35sleeper123
hey everybody. So my a/c works fine and everything, but i am looking to upgrade to a pioneer double din head unit. I have a 2004 g35 coupe. I was wondering if i could just get a metra dash kit without any buttons and use the stock buttons for the a/c stuff... Since the metra buttons look cheap. I just want the plastic shell to make room for the double din. Please help soon!
Please read FAQ section:
Originally Posted by WRATHERNAUT'S FAQ SECTION
do i need to buy the a/c controls too, can't i re-use them?
Yes, you need the controls, no, you can't re-use your stock ones:
this is the reason why you need the jdm ac controller
but that's an 03/04 and i have an 05-07, do i need to buy the a/c controls too, can't i re-use them?
Yes, you need the controls, no you can't re-use your stock ones.
Old Jan 24, 2012 | 10:55 AM
  #754
007JD's Avatar
hey srry for all the questions...lol
i just wanna be sure i get everything right before i go ahead and pull the trigger on this
head unit - Pioneer AVH-P4300DVD
which cable do i use to watch videos. and hear the sounds and will be able to use the apps such as pandora . netflixs . youtube and gps . and such
the two im confused with is
Pioneer CD-IU51V or
Pioneer CD-IU200V Usb Interface Cable For Ipod/Iphone
cause i heard for video and sound and everything
use the IU51V .. i read the reviews about the 200v on amazon n ppl were saying that the wire wasnt working
and then i searched around n read to fixs the problem use the 51v.
so please any1 who can help let me know thanks
and also wats the differences btwn the 2
Old Jan 26, 2012 | 09:53 AM
  #755
G35CO's Avatar
I started my install yesterday and when I unplug the HVAC harness I didn’t have the two pins that the install instructions mention I will need to pull before I can disconnect the HVAC wires, is that ok?
I wasn’t able to find a ground wire when I used the 70-7550 wires so I ran a ground wire to one of the metal bracket, is that ok?
Also, were did you put all the wires? I have IPod and GPS box and tons of wires and it doesn’t look like its going to fit behind the stereo.
Old Jan 29, 2012 | 11:25 PM
  #756
SILVERAZG35's Avatar
Wrathernaut or anyone else with advice ...... My transmission stutters when the stereo is turned up loud and i am driving and also the rpm guage drops down quite a bit when the bass hits in idle, and I have 1150 watts RMS currently. My question is if anyone has had this problem and if the "Big 3" upgrade fixed it. I already have a yellow top optima battery. I tried a H.O. alternator but blew it in the 1st 4 months. I spent alot of money on it and dont want to go that route again. Any help would be appreciated to help me fix this problem. Thank you!!
Old Jan 30, 2012 | 09:02 AM
  #757
I'd always recommend Big 3 at 1,000w RMS or above. It might not completely solve the problem, but it will eliminate one of the points of failure. If that doesn't work, get a higher-quality HO alternator.
I've never had a problem with RPMs at idle with 800w RMS, but then again, I never have my audio up that loud unless I'm cruising the freeway.
Old Jan 31, 2012 | 11:58 AM
  #758
G35CO's Avatar
Thank you Warathernaut for all your help and for creating the shopping list. I completed the install and it sounds great. The only problem I have is with the Metra axxess. It's not changing the stations in the radio when I use the steering button instead it seek. Finding space for all the wires was a pain. Now I'm looking for background and splash screens to replace the Pioneer screens.
Old Feb 1, 2012 | 02:46 AM
  #759
Mikey_i21's Avatar
you are the man!
Old Feb 1, 2012 | 09:10 AM
  #760
Yep, that's Pioneer's fault. They're the ones who decided the commands would be interpreted that way, instead of the way the factory does.
AVIC411.com is a great source for splash screens.
Old Feb 1, 2012 | 12:11 PM
  #761
G35CO's Avatar
Good to know. Thank you again for all your help!!!
Old Feb 7, 2012 | 04:05 AM
  #762
Rhart's Avatar
can someone give me more information about how to get the navigation voice to work with a double din. im planning on getting the jdm double din kit and hoping to keep the stock bose amp and stock navigation. i have basic knowledge in soldering and would like to find a solution. im thinking of getting the pioneer p1400dvd.
I dont really care about steering wheel control.
pioneer avh-p1400dvd
jdm double din kit
(need help with the "Extraordinary Measures" part to get navigation voice to work)
do i need to buy anything else?
thanks for all the help!!1
Old Feb 7, 2012 | 02:23 PM
  #763
JaE35's Avatar
Moderator
G35 Sedan
Ordered antenna adapter and wiring harness, any cheaper options for the steering wheel controls?
Old Feb 16, 2012 | 02:39 PM
  #764
Thomas J's Avatar
Hello I have asked a few questions in this thread before and have always received great answers, I plan on doing my DD unit install within the next week or two and have compiled a list of what I need based off the list on the first page. I have an 03 coupe with all black interior w/bose(using bose amp) and have already received the JDM DD kit and AC controller. I will have to transfer over my Dual climate control button to the new AC controller. My main concern is that I want to make sure that I have everything needed to complete the install in a day and it fixes my problems with the AC unit and the fact that my stereo some times fades in and out and I get a static pop when it comes back on(with no display of course). So here is the list I have compiled to do the conversion:
Pioneer AVHP-3400BH DVD HD Receiver w/iPod & BT - Pioneer
Metra Axxess ASWC Universal Steering Wheel Control Interface (Black) - Metra Electronics Corp
PAC ROEMNIS2 Factory Premium Sound Interface Headunit Replacement, For Select Nissan Vehicles - PAC
Metra 40-NI10 Nissan Antnna Adapter -
Scosche Ddtrb Double Din Trim Ring - SCOSCHE
Pioneer CD-IU51V AV iPod/iPhone Cable for Pioneer AV and Navigation models - Pioneer Mobile
http://www.ebay.com/itm/PIONEER-AVH-...ht_1718wt_1312
And of course I have a soldering Iron(hakko 936) and shrink tube.
Old Feb 16, 2012 | 02:52 PM
  #765
JuiceDogg's Avatar
The Pac-Swi if your doing steering wheel controls, but overall I think you have what you need. I actually trimmed my own trim ring that came with my JVC HU using a Dremel on the inside of it to file down so it would sit more flush on the sides of my JDM dash kit. The scosche might pop it out more, but it won't be so sunk in. Not quite sure on the Pioneer HU though if you can trim down there ring or not, Wrathernaut will probably chime in on this one I believe he has a Pioneer or at least dealt with them.
You have already rated this thread Rating: Thread Rating: 31 votes, 5.00 average.
