Do you like your stock bose system?
Old Feb 5, 2011 | 10:19 PM
tibasnatch's Avatar
i got an 03 with bose...that sounds ok...my previous car has bose also a 03 grand prix gtp...and it sounded a little better.......
is it real hard to change to an aftermarket system or can u just replace the speakers? Does the g35 have a bose amp built in?
How do u like yours? did u change it? if so what u got now and any pics?
Old Feb 5, 2011 | 10:20 PM
kennymo's Avatar
i hate mine. yes there is a amp in the car. its in the trunk
Old Feb 5, 2011 | 10:27 PM
tibasnatch's Avatar
yea there doesnt seem to be much highs at all even with treble to +5
Old Feb 5, 2011 | 11:02 PM
Frankieg35's Avatar
Just because its bose doesn't mean its good.. they have different quality bose and the used the cheapest crap they could find.. I upgraded all of mine to what it should of been..
Old Feb 5, 2011 | 11:11 PM
zoop425's Avatar
I hated mine when I had it. For the untrained ear the stock bose is usually very good but I couldn't stand the muddy sound that only delivers mids.. also idk how it was in previous versions but in the 07 plus sedan, they put massive drivers in the doors for mids which just seemed to buzz and rattle instead of deliver the proper mid tone.
Old Feb 5, 2011 | 11:44 PM
tibasnatch's Avatar
I plan to swap the whole thing out but where should I start...so here is a couple questions..
1) What should I replace first.....headunit, amp, speakers?
2)When I get an amp what do I want to look for...especially since the car has 8 speakers???
3) Anyone have any pics of there aftermarket cd player...
4) ummm?
Old Feb 6, 2011 | 12:21 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
I like mine so much I removed it so I could *preserve it instead of wasting its **beauty on my ears.
You can replace just the speakers, but the speakers are the least offensive part of the system. The worst part is the stock bose amplifier because it has a dumb-as-rocks EQ built in that destroys any semblance of good audio, and has about as much power output as an iPod. The headunit is built by clarion, and has such a high failure rate that it might as well be made out of dry bread. The headunit also outputs a differential-balanced signal, so you'll have to convert the signal or find an amp that accepts it.
So yeah, replace the whole thing.
* By preserve, I mean smash.
** By beauty, I mean hideous audio.
Oh, and you don't have 8 speakers.
You have four 6.5" speakers, two 6x9 woofers and two tweeters.
So you need a pair of 6.5" components, a pair of 6.5" coaxials, and a real woofer to replace the 6x9's.
Old Feb 6, 2011 | 10:19 AM
tibasnatch's Avatar
thanks....so I would need a amp that is like xxx watts x 6? ....so should I get a dash kit....cdplayer...and amp first and then replace the speakers....ill probbaly need some help if u dont mind sharing some info since you have already done it...
Old Feb 6, 2011 | 01:40 PM
Yeah, that's an ok path, but if you are planning on adding a subwoofer later, I'd recommend doing a 4-channel amp.
Phase 1 - Headunit, dual-amp wiring kit and 4-channel amp. Wire the front door speakers/tweeters to channels 1 & 2, and wire the rear 6x9's to channels 3 & 4. Leave the rear 6.5's unpowered.
Phase 2 - subwoofer(s) and 1/2 channel amp. Wire up the subwoofer(s) to the second amp, and put channels 3 & 4 to the rear 6.5's.
Phase 3 - replace the front 6.5's.
Phase 4 (optional) - replace the rear 6.5's.
Old Feb 6, 2011 | 09:02 PM
tibasnatch's Avatar
Ok...so replace the head unit....and most the speakers....leave the 6x9's out? and just use a sub?
is there an amp that can power a set of components, 6.5" mids and a sub so I dont have to have 2 amps?
Old Feb 6, 2011 | 10:51 PM
There are some that can, but it limits your options tremendously.
There's about 50,000 different 4-channel amps to choose from and about that many single and dual channel amps to choose from.
There's like 20 6-channel amps that aren't crap, and even less of those that fit in a decent budget.
Old Feb 8, 2011 | 11:32 AM
TannerG's Avatar
No highs, all lows, gotta be bose.
Pretty standard bose audio quality IMO
Old Feb 8, 2011 | 11:44 AM
GeeWillikers's Avatar
Walking The Fine Line...
Not great, but not the worst in the class either.
Definitely a candidate for upgrade IMO.
Old Feb 8, 2011 | 04:51 PM
blazeplacid's Avatar
not hard, just takes some time
I left what was there in case I ever sell the car.
Got a new headunit and ran rcas to the amp in the back.
didnt even buy a harness for the radio, I just ran a power wire and a switched wire since im not using the factory speakers.
EnCr1pt3d
Jul 8, 2019 02:48 PM
Daniel k.
Nov 3, 2015 09:52 AM
Tyler's03G
Aug 13, 2015 10:04 AM
Frostbite91
Aug 2, 2015 04:59 PM
