How to Add Auxiliary or iPod Input to the Factory Radio
Rating: Thread Rating: 5 votes, 5.00 average.
Old Oct 16, 2013 | 06:52 PM
  #76
Wrathernaut's Avatar
Gentle Manne of Leisure
It goes through the headunit. If you can turn the radio on and listen to FM/AM, the ISNI571 should work fine. Just keep hitting the radio/SAT/CAT button, whichever it is that your year/trim has on the plastic.
Old Nov 2, 2013 | 08:54 PM
  #77
Ghuss's Avatar
amazon don't ship that item to Canada the hell this sucks....
Old Dec 22, 2013 | 03:06 PM
  #78
JKL1031's Avatar
So I found out I have the sat harness but not the receiver. I bought the INFI module. What now..Can u buy a receiver and use the infi module?
Old Dec 22, 2013 | 04:15 PM
  #79
Ben35's Avatar
All you need is the sat harness, no sat receiver needed.
Old Dec 22, 2013 | 08:45 PM
  #80
JKL1031's Avatar
??? Am I supposed to have an extra plug left over? Well maybe it didnt work cause I didnt ground the ground wire.
Yea I totally derped out here.
Old Dec 23, 2013 | 07:41 PM
  #81
You have the plug that goes to the factory satellite adapter that won't plug into anything unless you've also got the factory satellite radio.
Old Dec 26, 2013 | 05:59 PM
  #82
greenythebeast's Avatar
I'm hoping someone can help me with the PA15-INFI I just received today. Before I purchased the PA15-INFI I checked in the trunk to make sure the white connecter was there and it is. So when I received the PA15 today I connected it as instructed. However, when I turn the car and and press SAT the LCD displays NO SAT. What does that mean? Did I connect something wrong? I tried the different DIP switch possibilities and all of them returned NO SAT. Please help!
Edit: I have a SAT button if it matters
Edit 2: Nevermind, didn't have it grounded!! Now to find a screw that will hold the ground in place...
Old Jan 29, 2014 | 05:48 AM
  #83
Purplevike's Avatar
Android Alternative
Some great information in this thread. Thanks for all of your expertise Wrathernaut!
I've found another alternative for those who want to maintain factory Bluetooth, use an Android device, and want to add an auxiliary input to their factory radio. Grom Audio, mentioned in the first post, also makes a device that isn't catering to iOS.
The (GROM-AND2-NIS02) installs behind the factory radio, and provides both 3.5mm and USB interface. I'm using this setup in my '06 Coupe with good success. This device also allows for use of the steering wheel controls, and lists id3 tag info on the radio display, (when using the USB input.) Since i hate cables dangling, I use a separate Bluetooth receiver that plugs in to the 3.5mm AUX jack. This allows A2DP audio streaming while also allowing the factory Bluetooth to connect for voice calls. Really a pretty slick unit.
Check out this link for specs and more information.
http://www.gromaudio.com/store/andro...interface.html
Old Jan 29, 2014 | 10:33 AM
  #84
ZkansasZ's Avatar
that's awesome. I want to see more on the installation of this if you have any?
Old Jan 30, 2014 | 03:03 AM
  #85
Ben35's Avatar
Looks very nice. Too bad I didn't know of it before I bought the PA15-INFI
Old Jan 30, 2014 | 05:28 PM
  #86
Adding this unit to the first post. Thanks for the info!
Old Feb 2, 2014 | 05:23 PM
  #87
Purplevike's Avatar
Sorry for the late reply to your question. No, I didn't take pics of the installation. It really is pretty straight-forward though. My only "tweak" to the installation was that I fabricated a flush-mount USB/AUX bulkhead jack in the ashtray.
Here's a link to the extension that I installed from Amazon.com.
Amazon.com: Xtenzi USB & 3.5mm AUX extension Flush Mount 2 Meter Cable , 1/8 AUX Car Bike Boat Motercycle Lead By Xtenzi: Car Electronics Amazon.com: Xtenzi USB & 3.5mm AUX extension Flush Mount 2 Meter Cable , 1/8 AUX Car Bike Boat Motercycle Lead By Xtenzi: Car Electronics
Old Feb 2, 2014 | 06:34 PM
  #88
JKL1031's Avatar
post pix of ur usb mount?
Old Feb 2, 2014 | 08:25 PM
  #89
Wow, it's pretty much identical to what I did with the factory socket, except I used five cents worth of hot melt glue instead of $30 (list price of $80???? WTF?) doing it.
Old Feb 2, 2014 | 10:55 PM
  #90
Purplevike's Avatar
Admittedly, $30 is a bit much for the function, but it's clean. I also didn't want to lose the accessory outlet. I use the outlet for my phone mount, which includes an additional 5v charging point.
Amazon.com
Amazon.com: Bracketron IPM-197-BL PowerDock Dual Auxiliary USB Power Mount with Grip-iT for GPS: GPS & Navigation Amazon.com: Bracketron IPM-197-BL PowerDock Dual Auxiliary USB Power Mount with Grip-iT for GPS: GPS & Navigation
Attached Thumbnails How to Add Auxiliary or iPod Input to the Factory Radio-20140202_204232.jpg   How to Add Auxiliary or iPod Input to the Factory Radio-81s5zknycdl._sl1500_.jpg
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
