DIY: 2006 Projector Cutoff/Color Mod
Old Apr 17, 2012 | 12:40 PM
  #286
IvoryGT's Avatar
Here's your quick reference, and I figured out a way where you don't need to cut your own shield, simply use the front shield that you would remove anyway and flip it horizontally so its direction of cutoff is ----\____ not ____/----- And glue over top of the rear shield.
Hope the pictures help.
Old Apr 19, 2012 | 04:23 PM
  #287
R6n350GT's Avatar
Thanks alot!
When looking close at arrows both the front sheild with the screw holes and the rear are connected as one piece and are ---\___, are you saying remove both these ---\____ and then flip horizontal? The the screw holes will be facing the other side unless you bend the concave back teh other way ? but then the flat screw hole part wont bent back to how it is now?
And then as you glue it back on, is to that bottom flat bit you see in the pic where the base of the bigger red arrow is?
and finally can i still do this CM mod to it?
Thanks once again I have my lights now so ill open them up on weekend and take pics
Old Apr 20, 2012 | 09:01 AM
  #288
R6n350GT's Avatar
I forgot to mention i got strafe v2 headlight and thought it would be same inside, obviously not!!
so this may make it easier...
and the cut off
what does that other little bit of metal do in pic 2?
Looking from inside the projector
So easy as gluing a bit of metal where the yellow is and then cutting where the white is?
would i need to extend that bit of metal in pic 2 so its at the same length to the edge as in pic 1?
Any other suggestion of improving light output and improving this ?
Also low beam uses H1 Philips H1 12258, any idea of brightest replacement?
Something like this?
http://www.ebay.com.au/itm/GENUINE-P...ht_3136wt_1168
Thanks
Old Apr 20, 2012 | 11:04 PM
  #289
IvoryGT's Avatar
Perhaps H1 HID replacement. The shield you have, you would need to add another shield on it, currently it's ___/----- you need it to look ----\____
Old Apr 20, 2012 | 11:39 PM
  #290
R6n350GT's Avatar
H1 is the high beam, uses D2S as low beam i think...
so your saying get a HID H1 kit? any suggestions on which one
I get the ----\___ bit (refering to my last picture) just cut where the white bit is and glue more metal to fill up the yellow section) so its ----\____ but what about that other bit of metal on the other side? how its closer to the edge with the ----/____ would i need to remove it and move it across to other side or what?
Thanks again Ivory GT
i see u are a vendor, do u sell bulbs still ?
Old Aug 3, 2012 | 05:26 PM
  #291
kahalawhat's Avatar
celica lens swap looking for feed back maybe something to make it better?
Uploaded with ImageShack.us
Old Aug 6, 2012 | 11:34 AM
  #292
IvoryGT's Avatar
Adjust the curve of the shield until the sides are flat and push/pull the center of the shield until the cutoff is focused.
Old Aug 7, 2012 | 09:08 PM
  #293
SAMzG35's Avatar
G35
Hi Paul. I tried messaging you but seems like your inbox is full
Where's a good spot I mount the second ballast?
Thanks!
Old Aug 8, 2012 | 10:07 AM
  #294
IvoryGT's Avatar
the area directly behind the cover of the bottom projector. on the outside of the housing.
Old Aug 8, 2012 | 11:01 AM
  #295
SAMzG35's Avatar
G35
Any pictures?
Old Aug 8, 2012 | 11:14 AM
  #296
IvoryGT's Avatar
Old Aug 8, 2012 | 12:19 PM
  #297
SAMzG35's Avatar
G35
You're the man!
Old Feb 5, 2015 | 12:45 AM
  #298
Urbanengineer's Avatar
I will be modifying mine this fall.. at least that is the budgetted plan .
Old Feb 21, 2015 | 03:49 PM
  #299
Hogbone's Avatar
Urbanengineer do you understand what he is talking about beacuse I lost.
Old Feb 21, 2015 | 04:56 PM
  #300
What are you confused about here? His choice of background is uber confusing (blinds warped in the lens).
He is showing what the modified mounting is like.
