DIY: 2006 Projector Cutoff/Color Mod
Old May 11, 2009 | 02:51 PM
  #226
IvoryGT's Avatar
up and down and vibrate with the engine
Old May 14, 2009 | 03:25 AM
  #227
kn106518's Avatar
Ok this going to sound like a stupid question but i have to ask anyway.
I was doing the color mod, and Happen to **** up my cutoff shield completely. anyone knows where i can buy the cutoff shield?
Old May 14, 2009 | 04:06 AM
  #228
truexh's Avatar
how did you mess up the cut off shield? I don't think they sell cut off shield just by itself... you probably have to pick up a pair of broken headlight or something
Old May 14, 2009 | 04:24 PM
  #229
kn106518's Avatar
ah dam it dam it, dam it, the thing is i think i bend it too much now that the cutoff line isn't straight anymore, i try to bend it backward and forward but the result is the same freaking weird.
Old May 14, 2009 | 04:25 PM
  #230
IvoryGT's Avatar
did you put the shield back
Old May 14, 2009 | 04:28 PM
  #231
kn106518's Avatar
ya i put everything back to where it was. man, i really don't want to buy another projector after i put the clear len and color mod this one already. but i guess that can't be help.
Old May 14, 2009 | 04:33 PM
  #232
IvoryGT's Avatar
the guide i mean
Old May 14, 2009 | 04:38 PM
  #233
kn106518's Avatar
what do you mean the guide? i just put everything back as it was stock, everything else is fine except that the cutoff line is not straight. it straight in the middle but on the 2 sides it curve up then down. that is the weirdest ****.
Old May 14, 2009 | 05:01 PM
  #234
redlude97's Avatar
is that with the stock lens or with the clear lens?
Old May 14, 2009 | 05:04 PM
  #235
kn106518's Avatar
clear lens
Old May 14, 2009 | 05:12 PM
  #236
redlude97's Avatar
Some clear lenses cause the bowing that you see, its almost impossible to get rid of. What clear lens are you using?
Old May 14, 2009 | 10:21 PM
  #237
kn106518's Avatar
ah **** that maybe oh ****, i bought clear len on ebay.
Old May 17, 2009 | 02:46 PM
  #238
visibiliti's Avatar
did you just bend the cutoff shield or did you twist the sides, too? you could have twisted the cutoff shield in a weird way to get it to do that. i had that pattern at one point during messing around. and yea, you can't just buy another single cutoff shield without buying the whole setup, so i would try your best to fix it. just take a look at it and analyze what is happening to the light based on the shape you have it bent/twisted to.
Old May 25, 2009 | 01:12 AM
  #239
BokChoiBoi's Avatar
Hmm...This is an interesting mod. Ive retrofitted my old RSX with TSX projectors but this seems more complicated . Is this guide up to date with all the small tweaks such as the unwanted vibration?
Im still a little confused as to the shield and spacers.
If anyone is currently doing this can you post up pictures of them?
Im planning on doing this soon so im trying to get some creases ironed out before I actually start.
Also has anyone used the TSX-R clear lenses yet? I heard that they are better then the USDM version.
Loving the lights guys
Thanks
-Yi
Old May 28, 2009 | 04:17 AM
  #240
BokChoiBoi's Avatar
Anyone?
