Diy: Sticky For Window Motor Repairs/door Panel Removal
Rating: Thread Rating: 7 votes, 5.00 average.
Old Jul 29, 2013 | 12:57 PM
  #421
Drboy25's Avatar
i made a video on how to remove the panel this is a Sedan. Probly the same for Coupe
Old Jul 29, 2013 | 10:40 PM
  #422
g35man04's Avatar
CLUB MODERATOR
Originally Posted by DEFT07
Help , i took my motor apart to clean it and not the copper thing that spins wont go all the way in ???
should just go back in by wiggling around
Old Jul 30, 2013 | 11:22 AM
  #423
ZFRED10's Avatar
For everyone who is having window problems, and you believe that it is your window motor. I would be happy to rebuild it with new motor brushings if you do not feel like spending a ton of $$$ on a new motor. I've done the project a few times now on my car and a few of my friends and have had no trouble with any of the motors yet. I'm not sure if this is allowed on here or not and if not let me know and I'll delete the post, but if you are interested you can p'm me for more details.
Old Aug 17, 2013 | 01:59 PM
  #424
Void's Avatar
Going to try this, been having some issues with my driver side window not always working, im hoping it will begin working again after cleaning it up!
Old Aug 19, 2013 | 06:40 PM
  #425
Void's Avatar
Need some help with this, I can't get the top cap to fit flush with the plastic either. I saw a few others having this problem and was wondering how to fix it. I posted a thread here: https://g35driver.com/forums/interio...dow-motor.html
if someone could help me out please!
Old Aug 27, 2013 | 05:40 AM
  #426
rsingerG35's Avatar
Does it matter if you don't put those round pieces of plastic back over the holes?
Old Aug 27, 2013 | 01:01 PM
  #427
ZFRED10's Avatar
No..
Old Aug 28, 2013 | 08:27 PM
  #428
rsingerG35's Avatar
Originally Posted by ZFRED10
No..
Whats the purpose of those things anyway?
Old Sep 8, 2013 | 02:19 AM
  #429
g06driver's Avatar
So I'm having this issue with my drivers side window and I have done a lot of research and have not come accross a similar problem...
As we all know when weopen and close our doors the anti-pinch mechanism allows the window to go slightly down when open and goes back up to close off the seal when closed. My issue is this: when i open the door it doesn't seem that the window drops down as much as it should (i can push it down to the point where it's suppose to be dropping to). So when I close my door the window is already basically where it needs to be when closed yet it tries to close the seal anyway. This applies unecessary pressure on the seal that's already sealed up, causing my window to make stress noises (because it's trying to raise it when there's no room left to raise). I tried removing my door panel and tried resetting the motor switch like most posts suggested to no avail. I was thinking 1 of 2 things: either my motor is dirty and needs to be cleaned/replaced or possibly the glass is not tightened to the track all the way? if anyone has any insight please help me out. Thanks.
Old Apr 4, 2014 | 12:30 AM
  #430
HACK213's Avatar
Window up or down?/
So I read through the pages and didn't find much on holding the window up..what is the best way to do this ? And if so if keeping the window up is the best way how can I keep it up? Any pictures ? I've read clamping it .. And using tape .. Any suggestions or tips thank you all
Old Apr 4, 2014 | 12:57 AM
  #431
saywat?'s Avatar
Down
Old Apr 4, 2014 | 09:59 AM
  #432
cocopete5243's Avatar
I'd say something about reviving a dead thread, but I'd want advice too, as I still own my G after 8 years now.
Here's what I use every time I take my window motors out for replacement or repair (more times than I care to share by now): http://www.homedepot.com/p/Irwin-4-1...3?N=5yc1vZc91j
They work great and protect the glass too. I just put them on the lower corners, by the mirror and by the handle. Good luck!
Old Apr 4, 2014 | 11:11 AM
  #433
HACK213's Avatar
Thanks for the reply bro but if I'm able to roll my windows down is it best for me to leave them down when cleaning up the motors?
Old May 1, 2014 | 07:49 PM
  #434
Edg35's Avatar
I cant put the cap back on the motor it won't go all the way in please helpppp
Old May 1, 2014 | 08:45 PM
  #435
blAk mAx's Avatar
the inside part may need to be pushed in / spun in more
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
