DIY: Cutting Rear Springmount aka "the springmount mod"
Old Jan 30, 2009 | 10:01 AM
  #166
jlin615's Avatar
redlude97
I just saw couple shots of your ride from another thread. My car levels just like yours and I did the same 0.5" springmount mod as well. I guess the sagging problem I been talking about lately is only related to my tires, not that I cut too much on the springmount.
Old Feb 7, 2009 | 12:57 PM
  #167
spankey167's Avatar
If you are using a 245/35/19 or 255/35/19 in the front, then yes
Does most everyones Z H-Techs sit higher on the passenger side (both front and rear)? So by cutting the springmount 1/2 inch it should even out each side but you will not get an all around even drop right? Is that what people noticed?
Thanks
Old Feb 7, 2009 | 12:59 PM
  #168
jlin615's Avatar
Thanks
I had that experience before. Later it turns out that the car was not sitting on a even surface when I measured it.
Old Feb 7, 2009 | 02:32 PM
  #169
xx7sephiroth7xx's Avatar
G
Thanks
My Z H-Techs are higher on the passenger side than the driver side and are higher in the rear than in the front.
Old Feb 9, 2009 | 01:12 PM
  #170
redlude97's Avatar
Quite a few people have uneven drops side to side with the h-techs, as well as many other springs. I would recommend cutting the passenger side springmount 1/8" more than the driver side springmount in addition to any amount you cut off both sides to even it front to rear
Old Feb 10, 2009 | 09:36 AM
  #171
viceversa's Avatar
Originally Posted by tOOrweR
<a href="http://150vm.nnm.ru/">ïîðíî ãååâ - 150vm.nnm.ru</a>.×òîèëè êòî òåáÿ áîëüøå âñåãî âîçáóæäàåò? Ìèëûå äåâî÷êè, êîòîðûå çàñàñûâàþò è ñåäëàþò ìàññèâíûå ÷ëåíû? À, ìîæåò, èõ ïîäðóæêè, êîòîðûå âûëèçûôâàþò âëàæíûåå êèñêè? Èëè ìàòåðûå áàáåíêè, êîòîðûå òðàõàþòñÿ êàê â ïîñëåäíèé ðàç? Íå?ò Òû õî÷åøü ïîñìîòðåòü íà èãðû ìóñêóëèñòûõ ïàðíåé? Äàæå åñëè òåïåðü òû îòâåòèë íåò, áóäü óâåðåí, ÷òî íà íàøåïì ñàéòå íàéäóñÿ ïîðíî ôèüëìû è ëäÿ òåá!ÿ
76262
Excuse me, but can you please type this for me?
Old Feb 10, 2009 | 05:08 PM
  #172
1992_eg's Avatar
im getting ready to install z stechs on my ride, i wanna do the mount trick and cut maybe 1/2in. do you guys think thats too much, i got the stock 19in rays on my car.
Old Feb 10, 2009 | 06:36 PM
  #173
viceversa's Avatar
Originally Posted by DodoArrovab
Bonjourno dear friends! I was reading for a while and now i'm registered
Hope i'm welcome here)
you're not welcome here.
for real...whats up with these bots?
Last edited by viceversa; Feb 10, 2009 at 07:50 PM. Reason: removed unwanted link in quote
Old Feb 25, 2009 | 01:44 AM
  #174
spankey167's Avatar
Hey guys. Recently did the Spring Mount Mod with Jon (ThinkDiesel)
Anyways... I've run into an issue with the gap on the front of my car to that of the rear of my car. I did the measurements from the rim lip the the edge of the the fender on both sides and determined I needed to cut approximately 1/2 inch in the rears on both sides. I actually went conservative and cut off less than that (0.4 inch).
My driver's side rear looks like it sits lower than my driver's front (did the finger between tire and fender trick and confirmed that rear driver's side was lower than front driver's side), but when I measure rim lip to fender on the driver's side, the front has less gap (2.25"). The rear driver's side has a 2.4" gap.
I am running 245/35/19 Nitto NeoGens in the front and 275/35/19 Kuhmo SPTs in the rear. The sidewalls for the SPTs look more straight, while the NeoGens are more rounded. Could running two different brands be the reason why the rear seems to have less finger gap between tire and fender, even though the measure from rim lip to fender says otherwise?
Please help me out guys.
I am thinking of buying new rear spring mounts and cutting them, but if its just due to having mismatched tires, I will leave it as is.
Thanks!
Old Feb 25, 2009 | 01:46 AM
  #175
06g35meister's Avatar
Thanks!
35% of 275 >> 35% of 245
sidewall is taller in rear. Same issue i got, but the mod evens the look out.
Old Feb 25, 2009 | 11:17 AM
  #176
spankey167's Avatar
That's what I finally came up with as well. Do a lot of people have this issue?
Do you guys recommend installing another modified spring mount for that side or do you think going to a 30 profile will help?
How do your mods even things out? meaning its heavy in the front and somehow makes it look even?
Old Feb 25, 2009 | 01:17 PM
  #177
redlude97's Avatar
i'm not really following your issue. The goal of the springmount mod is the even out the gap above the tire, just like stock. The distance from the rim to the fender SHOULD be different from the front to the rear due to the staggered tire sizing. If you make that distance the same, then you will tuck the rear tires while the fronts still have wheel gap
Old Feb 25, 2009 | 03:00 PM
  #178
spankey167's Avatar
I understand the goal of the springmount mod. Maybe the way I measured the gap was incorrect. I assumed the more accurate way was to measure from rim to fender.
So the accurate way to measure what to cut would be tire to fender? I guess I will need to buy one new spring mount on my driver's side and recut it then, since my rear drivers side gap is less than my front.
Old Feb 26, 2009 | 12:54 AM
  #179
Sponger's Avatar
6MT Brembo Coupe
I have Z Stechs and oem 19s as well. I cut .5 on the passenger side and .3 on the driver side.
Old Mar 12, 2009 | 03:55 PM
  #180
OneManJoker's Avatar
i am planning to cut my springmount can anyone tell me how much would be the correct amount to cut. I am putting on z s-tech. I'm also on 19" VS-XX would that make a difference?
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
