DIY: Cutting Rear Springmount aka "the springmount mod"
Old Aug 14, 2011 | 03:15 AM
  #226
Comatose's Avatar
Can anyone comment on the compatibilty of the spring mounts? I have an 07 G35X Sedan. Would spring mounts from either of the following work?
- G37 Coupe
- 370Z
- 350Z
Old Sep 20, 2011 | 12:35 PM
  #227
MUMM RA's Avatar
I picked up my 05 6mt back in Febuary and it's all stock except for the ride height, I think. The pics I see of other stock G's look like thry're higher than mine. How can I tell if I do have aftermarket springs?
I don't really want my car any lower, but my rears look like they could be lowered by an 1/5" to even things out. If I am on stock springs, can this mod still be done? Thanks guys.
It looks lower than this in person. Maybe this is why I think it looks lower than other stock G's.
Old Sep 26, 2011 | 05:35 PM
  #228
P10 WRC's Avatar
so, can i use a saws-all on this or does it have to be a hack saw? Also, is this mount all rubber, or is the center metal?
Old Sep 27, 2011 | 06:46 AM
  #229
RBull's Avatar
Rated M
You'll have a hard time controlling anything power. It took a while with a hack saw and is hard to stay even but that's probably the way to go.
Old Nov 27, 2011 | 11:11 PM
  #230
757_G35's Avatar
Thanks... Great diy...
I was kinda scared to attempt this, but I did it anyway... If I messed up, I was gonna call in sick tomorrow since the dealer was not open today... Thank goodness everything worked out well and the car is back together. After I did my cut (1/2"), I placed them on a flat even surface and placed a level on top of them. I kept sanding until it was levelled... That is how I achieved the even cut...
Old Dec 8, 2011 | 02:13 AM
  #231
invadertim's Avatar
can anything be done to lower the front more? has anyone cut or modified that black rubber piece that goes in the shock?
Old Dec 22, 2011 | 01:45 PM
  #232
DaGdriver's Avatar
pretty legit
Old Feb 3, 2012 | 02:47 PM
  #233
MannyFresh's Avatar
Has anyone removed the spring mount completely out?
Old Feb 3, 2012 | 04:56 PM
  #234
dan|el's Avatar
Yea that's what I ended up doing.. Rides fine, no issues.
Old Apr 6, 2012 | 04:44 PM
  #235
Jairen's Avatar
The rear springmount mod worked well for me. I may have cut off more than I should have, but I have never had an issue. This is with 350Z revised springs.
Old Apr 30, 2012 | 11:12 PM
  #236
DrkBLuG35Sdn's Avatar
Has anybody had an issue with this mod? I have asked many shops to help me out in doing it because I dont have the tools/ability to even take them out from my car at my current location and all of them have shuddered at the fact I would even consider that, and would'nt help me. So I am wondering if there are negatives here, because my rear drop is killing me with H-techs!
Thanks!
Old May 1, 2012 | 08:52 AM
  #237
SuperTrooper699's Avatar
Can you cut the front mounts or anythingto lower it more? My rear is fine I wanna drop the front more? If not I wanna get rid of my 350z s techs and go lower 350z Megan racing or h&r the lowest?
Old May 10, 2012 | 04:06 PM
  #238
StPete08G354D's Avatar
Can I do this mod with 09 370Z sport springs? I have an 08 sedan.
Old May 18, 2012 | 07:27 PM
  #239
Hotdawwgman's Avatar
What coil are you on and have you had issues with the spring poping out when jacking the car off the ground?
Old Sep 6, 2012 | 09:56 PM
  #240
AuAltima3.5's Avatar
The front mounts are pretty thin to begin with. I wouldn't do it.
Not using a rear mount is a bad idea. You will get metal on metal contact with could start a crack (cracks are sometimes started by gouging / deep scratches).
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
