DIY: Spring Install Only
Old Jan 19, 2011 | 03:34 AM
  #91
B2thaG's Avatar
I was planing on installing Eibach Pro Kit on my G but had a couple of concerns before i commit. If the kit says bout 1-1.5 inch drop, is this usually right? I heard you should expect a bit more when lowering with most kits. Im concerned because I dont want my G too low just alil more agressive look. Also i've seen my cousin go threw tires like crazy when lowering his hondas, i know a G is different from a honda but my question is should i expect the same result? should a go camber kit?...... thanks for any info
Old Jan 20, 2011 | 10:24 AM
  #92
G35CDriver's Avatar
It's your call on the camber kit... but I feel it is not needed if you are only going with a 1 - 1.5 inch spring drop. A more aggressive drop using coilovers then yes I would invest in a camber kit, but everyone has their own opinion.
Old Mar 28, 2011 | 12:06 AM
  #93
P10 WRC's Avatar
listen people, it's' Toe, not camber that will eat your tires like crazy. I recommend doing the install, waiting about a month for the springs to settle and then taking your car to an alignment shop. They will be able to see how out of spec you are. if your Toe is messed up, you may need to get some aftermarket toe bolts. if the camber is a bit negative, that will be okay in most cases and will not normally lead to crazy tire wear.
Old Mar 28, 2011 | 10:14 PM
  #94
WV350Z's Avatar
good write up!
Old Apr 13, 2011 | 09:51 PM
  #95
erral's Avatar
great writeup!
Old Jun 2, 2011 | 09:20 PM
  #96
uttarpradesh's Avatar
Question about "leaking springs"
Originally Posted by G35CDriver
Air tools are not required... They just make some things a bit easier. Your oem tire iron will work fine.
I left my car at the dealer to have my brakes replaced and rotors machined. They called me back today and said during the multipoint inspection they found that my rear driver side spring is leaking.
First, how is this possible? What could have caused it?
2nd, without seeing the "leak" does anyone know what the tech means and how much could this potentially cost to fix?
Old Jun 3, 2011 | 01:23 AM
  #97
G35CDriver's Avatar
The spring is a solid piece of steel. After years of service they can lose their life and begin to sag I guess but not leak. A strut or shock can leak or an airbag but I don't see how a spring can. Factory spring are available here in the marketplace all the time. Just search them out.
Old Jun 3, 2011 | 01:46 PM
  #98
ray1370's Avatar
+1, they meant the strut is leaking, could be caused by excessive wear or impact/accident. OEM struts are gas filled, you might not see the leak but you can feel it, the car tends to drive bouncy when the struts lose damping, and might sit lower. It might be a good time to invest in some good struts.
Old Jun 6, 2011 | 01:53 AM
  #99
yes. When I arrived he showed me under the car. The strut was yellow n I could see a trail of grease or liquid coming down from the top about 4-5 inches long. My car has never been in an accident as far as I know. 2nd owner clean carfax.
I do notice that my 05g rides rougher than my friends 2001 civic. I've always chalked it up to being a sportscar n thought it was normal.
The damaged strut is on rear driver side. Why didn't both go bad?
Where you recomend to have this work done. Assuming I go with oem how much should job n parts normally cost?
Old Jul 15, 2011 | 02:04 AM
  #100
geegeegee's Avatar
Pictures gone? D: Aw man, I was gonna try this tomorrow!
Old Jul 15, 2011 | 11:26 AM
  #101
G35CDriver's Avatar
My bad. Ill fix it
Old Jul 28, 2011 | 07:59 PM
  #102
IIIHawKIII's Avatar
yeah, i was hoping for some pics too.....
Old Jul 28, 2011 | 08:04 PM
  #103
G35CDriver's Avatar
I don't get it cause all my photos are still here and I can view them fine? ??
Old Jul 28, 2011 | 08:22 PM
  #104
IIIHawKIII's Avatar
dunno. maybe you moved the pic files? cause there aren't "broken link/images" place holders...they are just not there...
Old Jul 28, 2011 | 08:56 PM
  #105
G35CDriver's Avatar
Huh. That's so weird. I can see them on my home comp. Work comp. And cell. I will look into it. Ahh I think I have the albums marked private.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
