DIY: Rear Wheel Bearing Removal
Rating: Thread Rating: 4 votes, 5.00 average.
Old Mar 4, 2013 | 12:43 AM
  #166
AwdGx's Avatar
Originally Posted by Beeblebrox
Assuming your time is worth something (I know mine is), it sounds like having a shop do the job might make more sense.
I see that there are a couple hundred dollars in parts
Some guys are buying presses so that's an additional expense
Then labor:
  • Involving: friends and neighbors
  • There is the time to go and get the assembly pressed at a shop (which not only costs $ but also your travel and waiting time)
  • Your labor for the removal/reassembly process which might be extensive due to corrosion or other unforeseen problems.
So the question is, if you get a reasonable quote from a reputable shop (not a dealer), assuming the parts costs are not too far off from online prices, what makes more sense? Wasting a weekend or having the work done by a pro?
I could do this job but it sounds like around 10 hours or so when including ALL labor. So if a shop could do it for under $500 (including parts, that sounds like it could be better route to go (unless mechanic work really winds your watch).
Only thing time consuming was getting ahold of the parts. Took me about an hour and a half I'd say to completely finish but I found a deal on a hub and bearing so I didn't need a press. My first time doing a bearing on my G too.
Old Mar 5, 2013 | 04:50 PM
  #167
obsdnoblivion's Avatar
Ten hours?! No way. I bought my press from Harbor Freight with a coupon that I paid like a dollar for on ebay. Yeah, I bought a coupon. But it made the press only about sixty bucks. Changing two bearings makes that worth it. And then I have the inner bushing on my left lower control arm that needs replacing, and I'll get to use the press again. Definitely beat paying the stealership. And I have the peace of mind of knowing they didn't screw something else up so they could then replace that and charge me for it too. With 230K, it'd be so easy to say this or that needs replacing and then charge me another $250. I freakin hate them.
Old Mar 11, 2013 | 02:54 PM
  #168
Simm0nS777's Avatar
I think my driver side rear bearing needs replaced. I've done both fronts in the last year and I think the rear is starting to go as well. 75,000 miles 2006 G35X. So it sounds like for the rears I just need the bearing and not the hub like I did on the fronts correct?
Also, if anyone in the NE Ohio area has done this before DIY and would be willing to do mine, I'd gladly pay you for your time!
Old Mar 11, 2013 | 03:22 PM
  #169
Wow 75k? Seems soon, but I guess in Ohio you have salt and stuff on the road that wears stuff out more quickly than here in the south. But yeah I would bet that you don't need hubs. I didn't at all. If the hub needed replacing, I would figure that you'd get some marked vibration in addition to the propeller airplane in the distance noise.
Old Mar 11, 2013 | 05:50 PM
  #170
sp00ky's Avatar
Originally Posted by drsifu1
here is the bearing puller attached to the hub. crank down on the center with a 1/2" socket to separate the hub from the bearing.
picture of area after hub is removed:
picture of hub removed:
You do not need to remove any suspension components to get access to those four bolts that hold the bearing in place. As I suspected, the shaft can be pushed in far enough to give you access to those four bolts. You'll need a 17mm socket and two different extensions to get to those bolts. First picture below is without the shaft pushed in and second picture is with it pushed in far enough to get access to the bolts. In the picture, I had already removed the bolts.
Picture after the bearing is removed:
Still waiting for parts to arrive before I put everything back together. Bearing looks to be in good shape. Below is a picture of Joaquin03's bearing compared to mine. His car has 133,000 miles on it. I still believe that when I drove around with a loose axle nut, it ruined my bearings. Hopefully I have made the correct diagnosis.
Joaquin03
DrSifu1
Does anyone know what size press is needed? http://www.northerntool.com/shop/too...ct_35090_35090
will this one work?
Old Mar 12, 2013 | 10:09 AM
  #171
Maybe you could fit a bearing and hub in there to press them together, but I don't think that one will give you enough space vertically to separate the hub and bearing. This is what I got.
http://www.harborfreight.com/12-ton-...ess-33497.html
Had to use some strategery to get the bearings off the hubs, but putting the new bearing on the hubs was a cinch.
Old Mar 13, 2013 | 10:15 PM
  #172
sp00ky's Avatar
ok, I see thanks for the reply. I saw a similar one at Northern Tool. My mechanic quoted $500 for the job with saving the Wheel hub. I saw a Timken bearing assembly at Rock auto for $44. So it looks like its gonna be all me.
Could you describe your strategy of pressing out the old bearing? Obviously a bearing puller won't work as this tears apart the bearing assembly and leaves part of it on the hub.
Nissan pisses me off sometimes.
Old Mar 14, 2013 | 09:56 AM
  #173
I couldn't figure out how to separate them on the press with the stuff I had, so I used four old rotors I had recently changed out. I used C-clamps to bind one pair (a front and a rear) with the outside sides of the rotors facing (so they would like H's) and then did the same with the other pair. I turned them flat (front rotors on top so there was more space on the bottom) and hung the bearing edges on the top rotors. I found something that fit down in the bearing about the diameter of the splined part of the hub and wailed away with a hammer until that sucker fell out. I couldn't find anything and didn't want to ruin any sockets I had so I ordered this freaking huge washer from Grainger with the exact diameter I needed. Lemme know if you need pics of this wacky setup; or I could draw it in windows' paint program later.
Okay here's a drawing. Crude but I think it shows what I did. I forgot to show the clamps, though, but you can probably guess you'd have to put them through the centers of the rotors and keep the clamp away from the center of the whole setup so that you have the space for hammerin'. Hope this at least gives you some ideas. Name:  bearing-hubseparation.jpg
Putting the new bearing on the hub with my nifty press took all of 90 seconds, and I was taking it really slowly to make sure I didn't screw anything up.
Old May 20, 2013 | 09:15 AM
  #174
smartin0924's Avatar
I just replaced the bearing on my G this weekend. In one of the pictures it shows a dust ring, but when I pressed my hub out of the old bearing I didn't see that ring. I had to cut the top portion of the bearing off because it was fused onto the hub, so maybe it was part of that and I didn't notice. When I pressed the new bearing on, I didn't add that ring. Will this cause any issues? I would hate to go through this whole process again for that ring not being there. Thanks
Old May 20, 2013 | 10:04 AM
  #175
GreenPenguin's Avatar
The pictures you mention above show the bearing being taken apart in TWO pieces. The same happened to me- when i took the old hub off my car, one piece of the bearing came off with it while the other was rusted solid to the knuckle exposing the packing grease and ***** inside. If you were able to get your bearing off in one piece congrats. There was definitly no dust cover with my assembly.
Old May 20, 2013 | 10:40 AM
  #176
Thumbs up
Thanks for the info, that is a relief!! I still have the other rear bearing to go.
Old Jul 12, 2013 | 08:29 PM
  #177
ahh-lee-g's Avatar
Seal
I have a question..
I bought a rear assembly hub and wheel bearing. I'm going to go have it pressed. Is it necessary to purchase a seal aswell?
Thanks
Old Jul 15, 2013 | 08:28 AM
  #178
The bearing comes in one piece. There should be nothing you need to do but press it onto the hub.
Old Jul 15, 2013 | 11:18 AM
  #179
Urbanengineer's Avatar
Can someone link me to the coupe bearings for the front and back? I am tired of searching and want to replace these ASAP . I would appreciate something better then OEM quality, but OEM is fine too! Also if there is any necessary grease I should buy let me know that too
Old Aug 5, 2013 | 09:57 PM
  #180
TunerMax's Avatar
G35
How I did it:
I chose to drop the spring buckets. You can do it without but it's a big PITA especially if you need to do this in your driveway, and you will probably need a big bar to crack the bolts free on the calipers and the wheel bearings, so the added room is priceless considering how easy it is to drop the spring buckets
Use a jack to support the bucket, remove the one 17mm Head bolt closest to the wheel end, and lower/pry it out as you lower the jack, then remove the spring. If the bushing is tight you can use rope, etc to keep it down and out of the way (as pictured).
At this point you have easy access to pull the CV shafts out safely without tearing the boots, and you have access to get a bar on the wheel bearing and Caliper bolts, which will likely be tighter than heck, especially if you live in a climate like mine!
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
