DIY: Rear Wheel Bearing Removal
Old Sep 5, 2016 | 07:57 PM
  #211
GreenPenguin's Avatar
Originally Posted by bythabay
easy way to remove the bearing stuck to the spindle/knuckle:
http://www.harborfreight.com/heavy-d...-pc-60327.html
just bolt that up and slide the hammer hard, the assembly will come off.
For me, this split the bearing in two with part of it coming off with the hub and the other frozen to the knuckle. The tap out method did it for me
Old Sep 5, 2016 | 08:10 PM
  #212
ProBballChamp's Avatar
I think I need to talk to my mechanic friend to see if he has a recommended size draft pin. I've been using a a punch that's been leaving indentation on the bolts. Did you use a deep well socket to hammer the bolts or did you use a skinny?
Fortunately nothing is broken this time I've taken apart my car so I can put it back together and drive to work tomorrow
Old Sep 6, 2016 | 04:37 AM
  #213
Its been over 3 years now but I recall using a punch with a smaller diameter than the bolt heads. At the time, I was more concerned with damaging the threads that I didnt even notice if there were any indentations. Surely there were some though...
Old Jul 6, 2017 | 10:32 PM
  #214
Pjanoo's Avatar
[QUOTE=drsifu1;4275778]Parts that were ordered:
$119- Hub assembly (comes with studs pre-installed)
$56- Bearing assembly
$16- Seal
$4- New axle nut
Below picture is courtesy of WaiJai. It includes everything I bought, just missing the axle nut. Nut is not required, but it's for my own piece of mind.
The hub assembly is also NOT required to replace the bearing, but again, it's for my own piece of mind.
I was changing my rotors today and, I stripped one of the studs. I tried to put a new one in and, stripped the inside of the hub assembly. I've looked online for a new hub and bearing and it costs around 200 for the hub alone. Where did you find the Hub for 100 dollars?
Old Jul 7, 2017 | 11:50 PM
  #215
Swaglife81's Avatar
[QUOTE=Pjanoo;7111099]
$16- Seal
$4- New axle nut
​​​​​​​Timken HA590255 $95 (rear wheel hub and bearing assembly) from Amazon - great reviews and this unit from Timken evidently last longer than the other brands without issues. $200 is way to much. If you find cheaper that's the correct part number. Do not pay more than $100 for the hub and bearing please
Old Jun 26, 2018 | 01:04 AM
  #216
coffeysm's Avatar
Just did half this job today on my car. I was able to pull out the whole assembly from the knuckle using a slide hammer. My hub and bearing was so fused though when I went to take it apart on my press the inner race was stuck. I ordered new hubs, because I would probably end up cutting into the hub with an angle grinder.
I also took everything off including the e-brake hardware, so I could clean and grease all that stuff. Using my 1/2 inch Milwaukee with a universal swivel joint made getting those four bolts out from the hub real easy.
I also took the axles out to clean up the rust and be able to grease them. I had to use a torch on one side, because the CV axle was fused to the flange. I was quoted 440 per side by my mechanic and I did these two for about 240 bucks including the press I had to buy (12 ton).
Old Oct 10, 2018 | 01:00 PM
  #217
hebermudez's Avatar
Great Shape with no modifications
did anyone here had this happen and is it normal for all wheel bearings?
Old Oct 24, 2018 | 06:36 AM
  #218
Brennan Wallman's Avatar
Coupe 5AT base
Mechanic in/near New Market MD
I just purchased an 05 coupe and I’d like to find a mechanic in Maryland who can do this job. I live in New Market but I will travel anywhere within an hour. Shop prices are are so high and it’d be great to find a local mechanic.
Thanks,
Brennan
410.714.4178
Old Oct 24, 2018 | 08:35 AM
  #219
LoSt180's Avatar
Thanks,
Brennan
410.714.4178
I'm just up the road in Urbana. Hill's Garage is the most highly recommended shop in the area.
If they're too far for you, Auto Clinic International in Frederick is the only local shop I trust.
Old Dec 16, 2019 | 09:33 AM
  #220
Matt Lindsey's Avatar
G35 infiniti coupe
Shaft
Originally Posted by LElzie
First off, I would like to thank you for such a detailed post on how to perform this work.
I have had this clicking for months and it was beginning to drive me crazy. I called the dealer yesterday and they quoted me 300 bucks for the job. I went and purchased 45 dollars worth of parts and what not that I did not already have, rolled up my sleeve, printed this post along with owners manual on the axle and got to it.
I was skeptical about this fixing my problem, but after greasing up the axle and putting everything back together, I went for a brisk drive to hear only the sounds of my Rev-Up Engine and Injen intake sucking in the cool evening air. It was music to my ears. No more clicking. All the conditions that previously generated the problem have gone. So I will keep a listen out for it over the next few weeks\months and see how it goes.
You saved me 250 bucks and MAN It is satisfying to know that I did it and have had success.
Sorry for the ramble, but I am pumped. Thanks again.
How long did it take to take the shaft off
Old Dec 5, 2024 | 08:11 AM
  #221
QX1's Avatar
QX1
agreed about reusing the hub. but i've read that it's always a good idea to replace both. bad wheel bearing may have put unnecessary stress on the hub. i'm not going back in to fix something that may cause problems in the future.
there is very limited space behind the axle to get to those four bolts. Without removing the axle itself, there is no way in hell you can fit a socket to get those bolts out.
before removing the hub assembly, I was able to push the shaft in far enough to get more room for the bolts, but still could not fit a socket to get them out. after I removed the hub, it gave me more room to wiggle the shaft to get my socket at those bolts.
how did you get to those four bolts? might help members avoid having to rent that tool from autozone.
noticed you are a mechanic at an Infiniti dealership? If so, any other tips you might have would be appreciated. Looking the the service manual, it instructs you to remove all the suspension components attached to the axle and than remove the axle itself. Another member removed some suspension components and the drive shaft where it connects to the differential to get to the bolts. I thought I was going the easier route, but maybe not. Any idea on costs to have the bearing pressed on?
PM sent
thanks in advance.
hy, is it absolutely essential to change the hub also? does infinti factory require that?
Old Mar 19, 2025 | 04:51 PM
  #222
sammmyG's Avatar
g35 2 door
thanks from the future
thank you for writing such a detailed article about replacing the bearing/ hub assembly. just finished replacing both rear bearings and even with all the youtube videos I watched it was your article that helped the most. so even more than a decade after your write up it is one of the best sources of information for this task!
Cajuncowboy
Jun 21, 2021 09:47 AM
rezendvous420
May 31, 2020 01:26 PM
Xfactor
Dec 1, 2019 12:52 PM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
rping
Jul 26, 2015 09:53 PM
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
