track settings for advanced driving school
Old May 22, 2006 | 04:14 PM
RBull's Avatar
Rated M
I have an '04 coupe 6mt with '05 350Z springs, stillen sways f&r currently med/med, D-Specs currently 4/4, OE 18" wheels & Pilot Sports.
I will be attending a track school on a short 1.5 mile tight, technical course with 80' of elevation change for two days in June. I am looking for suggestions on any changes to my current set up along with tire pressure suggestions.
Thanks
Old May 25, 2006 | 10:03 PM
RBull's Avatar
Rated M
Anyone?
Old May 25, 2006 | 10:12 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
JMO..
I don't think there's any need to change suspension settings you have now.
What tire pressure are you running now?
Can you get air at the track??
Some of the track guys can jump in...
But I think many chalk the sidewalls to see how much they're rolling over on the sidewall.
Then play with the pressure.
Old May 25, 2006 | 11:38 PM
dklau33's Avatar
I'll be running my D-Spec, '03 350Z Springs combo on the track for the first time this weekend. Right now on the street I have my settings at 3.5 from full stiff all around and that feels perfect too me. I felt 4 was a hair too soft although comfortable. So at the track I plan on starting at 2 all around and adjusting from there. My Stillen sways will be at med/med and my camber will be -2.5 F/ -1.8 R.
Old May 26, 2006 | 01:15 AM
Gsedan35's Avatar
How did you get your camber to -2.5F? I didn't know you had adjustable arms in the front
Old May 26, 2006 | 02:13 AM
dklau33's Avatar
Jim, yeah I picked up a set of Toyo RA-1's for the track and running the stock camber would be too unfriendly to the tires. So I got a set of Cusco A-Arms to be able to run more neg camber on track days. I'm sitting at -1.8 L -2.1 R for the street. I can go around -3 max if need be.
Old May 26, 2006 | 07:40 PM
RBull's Avatar
Rated M
Originally Posted by inTgr8r
JMO..
Thanks. Some track info Balzz sent me said +5 psi from factory recommendations is a good starting point. There is no air at the track but I have a compressor with tank I may bring there. I may also firm up the DSpecs a bit from where they are now too. Can't play with rears up there though.
Old May 26, 2006 | 07:41 PM
RBull's Avatar
Rated M
Cool. We'll wait for your feedback.
G/L at the track.
Old May 26, 2006 | 08:18 PM
GLuXuRy's Avatar
PM 350ZNV... he can give you his opinion
Old May 26, 2006 | 08:37 PM
dklau33's Avatar
G/L at the track.
Ditto.
BTW what is the track you'll be doing? Link?
Old May 26, 2006 | 08:42 PM
willthethrill's Avatar
I had a similar question a few days ago. Perhaps some of those replies will be of assistance to you.
https://g35driver.com/forums/brakes-suspension/100215-tokico-d-spec-setting-track-day.html
Old May 26, 2006 | 09:29 PM
RBull's Avatar
Rated M
Ditto.
Thanks. I live in a small city and low populated area with a small track about 20 miles from home. Here is the link.http://www.atlanticmotorsportpark.com/
And you??
Old May 26, 2006 | 09:38 PM
chenga's Avatar
I would bump up the stiffness in the rear sway bar, but that's just my preference for oversteer. Especially since it's a "driving school." The idea is to take your car to the limit and maybe a little bit beyond right? ;-)
Old May 27, 2006 | 02:07 AM
dklau33's Avatar
And you??
http://www.ncracing.org/reno-fernley.html
It's a 4 mile track!
Old May 27, 2006 | 09:20 PM
RBull's Avatar
Rated M
That's crazy man. Ours is 1.5 miles and it's narrow and bumpy. Not too much money spent on it.
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
reaper76
Aug 5, 2015 10:13 AM
itschuckster
Jul 25, 2015 08:07 AM
mushu
Jul 15, 2015 03:55 PM
quickspeed6
24
Jul 15, 2015 11:06 AM
