95K miles with stock suspension
My car just recently passed the 95K mark and has been on the stock sport suspension since new.
What's the consensus on replacing shocks/springs at this mileage? FYI, I don't want anything stiffer than how it is now, and no need to lower as I have a hard time as it is driving over things now.
TIA
TIA
Usually Nissan oem shocks last 60k/4 years before they are half as stiff on rebound as brand new. Shows up first to typical insensitive driver as a mild rear upward undilation on smooth highway.
Most aftermarket oem replacements are valved 10-15% stiffer to compenstate for rubber bushing wear and durometer hardness changes caused by ozone/salt/heat exposure. So the numb actually feel something after a change [worth spending the money], this goes away fast usually after 4-5,000 miles to equal oem stiffness.
Springs never change much [even after 15 years] so that as new feeling can only come from new shocks and all new bushings.
Q45tech - If you had to pick which suspension parts to replace with a shock change (since you can't economically replace bushings by themselves unless you're buddies with a mechanic with a hydraulic press and lots of time), which would you pick? Lower control arms + compression rods?
That's great info QAtech, I appreciate your feedback on this.
I didn't realize other suspension components needed to be replaced after such high mileage, but any additional thoughts and suggestions would be greatly appreciated.
Thx
Thx
Originally Posted by Dudefish
I'm at 76000 miles and def feel the lack of rebound damping. How much is it going to cost to replace bushings in addition to shocks?
- upper links
- transverse and lower links
- compression and radius rods
You really cannot tell just by looking at enclosed in metal bushings. If you disassemble the suspension you can feel old movement vs brand new movement.
When the camber goes progressively more negative and cannot be adjusted to NOMINAL [exact midle of range] you KNOWN the bushings are deformed and sloppy or something is BENT beyond spec.
Why you need a brand new alignment print out to reference the aging rate.
The designed in variable toe in/out under braking and acceleration is hard to measure so concentrate on rear bushings that localize fore/aft movement/toe.
I resisted replacing rear hard components until the Q rear subframe starting leaking and need replacement but around 180k I replaced almost everything, now at 318k/18 years I'm budgeting for another round.
I've replaced shocks 5 times so far in 18 years.
Most people don't keep cars long and never get the JOY of totally rebuilding them.
