Bad Bearing: pics.
You guys think mine need replacing soon? When the car is cold I hear a whining noise coming from my right side. When I'm on the highway and go over 60 mph my steering wheel starts Vibrating a little. Thanks
I'm reading this 5 days after my left rear bearing locked up and took out a rotor and caliper in the process.. $800 I'll never see again
I'll have to look at replacing the others as a preventative measure
Props to Grubbs and Riverside Infiniti for the hookup on prices on separate occasions for the bearings as well.
Any truth to the claim that wheel spacers increase bearing wear and increase the risk of premature failure? Guy at my local shop refused to put them on saying it was asking for trouble. A lot of people use them on here but haven't heard of many problems?
Good question. It's not an easy thing to do if you don't have the right tools; as goes with most projects. I used an angled/jointed head ratchet and the shallowest socket availible to take them out. I also had to wiggle the axle around to get to the bolts as well.
Old thread, but it's a good question.
Your question needs to be split up in two parts.
Do spacers increase load on the wheel bearings? Yes they do. It's simply leverage and how it acts on this particular design of wheel bearing. Push the wheel's load on the wheel hub further away from the car and leverage on the fulcrum increases. The fulcrum is inside the bearing, so a spacer would increase the load. Increasing weight in the car would be equivalent.
Would it cause premature failure? Depends. Really depends on the manufacturers load rating of the bearing. Since only they have the data to say what for sure thismis, it's tough to know. How much safety factor did they build in. In other words, a wheel bearing built for a Mack truck could probably take the extra load of a 10mm spacer without a sweat, but a bearing barely adequate for a vehicles weight as is might see premature failures.
So it's not a rumor, there is scientific theory behind the statement, but without manufacturer data no way to know of the extra load would be acceptable.
Hubs can easily last 300,000 miles if they have not side swiped a curb and if your wheels are always balanced.
If it got to the point that dirt and water are getting in, then that is a clear indication that they were impacted into a curb.
However, this the attached picture would obviously be a problem.
