NEW SPL PRO front compression rod bushings
Old Apr 1, 2010 | 09:48 PM
  #46
ELMACHOGERACHO's Avatar
air gap, as in the bushing isnt solid rubber. theres a sliver of a gap on the sides of the rubber.
Old Apr 1, 2010 | 09:49 PM
  #47
OCG35's Avatar
there are a couple tiny pin holes (not on the side)... but other than that - no gap.
Old Apr 1, 2010 | 10:00 PM
  #48
Old Apr 1, 2010 | 10:39 PM
  #49
OCG35's Avatar
^^^ I don't know what the hell that is on the right - but its not on my sedan (that I've had for 5.5 years and had two pair of bushings on)...
I've never seen a bushing like that... its not what the OEM part looks like for a sedan.
Sorry - you got bad info.
BTW, the photo I posted is an actual photo of my bushings...
Old Apr 1, 2010 | 10:40 PM
  #50
think what u want. its not like i have done at least a dozen comp rods and 2 dozen comp rod bushings....o wait.
Old Apr 1, 2010 | 10:44 PM
  #51
OCG35's Avatar
what do you mean think what I want... I posted a photo of me holding the bushing on my sedan... you post a paint blotch and insist sedan is different
Not only that, I posted a link to Riverside Infiniti's parts showing that coupes sedans and 350z are the same part...
I'm not sure why you are insisting otherwise - but at this point I don't care.
Old Apr 1, 2010 | 10:50 PM
  #52
they told u they are the same part cuz they are all interchangable. you can put steel awd comp rods on a 350z and coupe comp rods on an awd. they all fit. the difference is steel vs aluminum and solid and not solid rubber bushings.
Old Apr 2, 2010 | 12:08 AM
  #53
Tollboothwilley's Avatar
Mine looked like that pic on the right when i pushed out my stock ones. The revised looked like the ones on the left...
Old Apr 2, 2010 | 12:44 AM
  #54
AARONHL's Avatar
Anyone have tips for removing a STUCK ON compression rod? Can't pull it off after removing the nut!
Old Apr 2, 2010 | 03:06 AM
  #55
OCG35's Avatar
mine have always looked like the ones on left... I wonder if the ones on right are an old design?...
Either way - the ones on the left are what coupe/sedan and Z use (currently)... and since 04.5 at least in sedan... I've never had the ones on the right in my car.
Old Apr 2, 2010 | 03:09 AM
  #56
OCG35's Avatar
they didn't "tell me" anything... when you order the part online you get the same part - whether you are coupe or sedan... there are not two different parts.
Let's make this easy... please show me where to by the "sedan" bushing...
My sedan has never had the "not solid" bushing...
Old Apr 2, 2010 | 03:25 AM
  #57
sammy_G's Avatar
I think the "one on the right" is just what it looks like when it's really messed up and needs replacement.
Old Apr 2, 2010 | 03:29 AM
  #58
OCG35's Avatar
btw, what bushings/rods were all the coupe owners using in these threads?
https://g35driver.com/forums/brakes-...otal-crap.html
https://g35driver.com/forums/brakes-...used-help.html
https://g35driver.com/forums/brakes-...ing-worse.html
and the TSB: http://x.infinitihelp.com/forum/show...-013-2744.html why is it for coupe and sedan?
Old Apr 16, 2010 | 03:50 PM
  #59
dfaulk3's Avatar
Does anyone know if these will fit on an 04 G35X??
Old Apr 16, 2010 | 11:45 PM
  #60
itgogitrev's Avatar
^^^^ Different part numbers?
You have already rated this thread Rating: Thread Rating: 3 votes, 4.67 average.
