Questions about Air Ride suspension ask here
Old Jan 5, 2014 | 11:59 PM
  #451
ChrisKG35's Avatar
Bagged/ Air ride suspension
Okay before everyone tells me off.. i have used the search function but i cant find my answers...
Anyways, i am wondering how hard it is to install (i know alot more then the average joe when it comes to vehicles and i've been raised by a DIY dad) Air ride and any advice previous or current owners have!
I've been looking at this kit
http://bagriders.com/modlab/products...EL-SYSTEM.html
with UAS and Accuair components (i believe these are the most common brands). Im going to be running this as a daily and I know it may be a little of a concern in terms of reliability but shouldn't be a problem with quality fittings etc...
Now the main reason I want to run this (pretty much everyone's reason) is because I want the simplicity of slamming the f@#K! out of it at local events but also being able to get out of my stupid neighborhood with about 12 speed bumps -.-.... with a static setup i obviously dont have the simplicity to adjust with a remote.
Thanks!
Chris
Old Jan 6, 2014 | 12:10 AM
  #452
Frankieg35's Avatar
I know there is a thread dedicated to any questions about airride..
Old Jan 6, 2014 | 12:16 AM
  #453
ChrisKG35's Avatar
Please point me to this! I did all possible combination on the search... i.e Airride, Air ride, Bags, Bagged, Slammed on bags, etc... nothing
Old Jan 6, 2014 | 12:17 AM
  #454
ChrisKG35's Avatar
... its a sticky, im a dumbass
Old Jan 6, 2014 | 12:18 AM
  #455
Frankieg35's Avatar
https://g35driver.com/forums/brakes-...tml?styleid=49
Old Jan 6, 2014 | 12:21 AM
  #456
ChrisKG35's Avatar
What do you guys think about this kit
Front:
Air Lift Performance
Rear:
UAS Rear kit
Stock shocks
4 Gallon tank
dual 400c compressors
standard VAIR check valves (what is this lol)
Dual needle gauge kit (what is this)
no water trap kit
1/4 inch line
gold sticker lol
Old Jan 7, 2014 | 08:24 PM
  #457
ChrisKG35's Avatar
Does anyone know if itd be bad to use bags over stock struts and shocks for a month or two?
Old Jan 7, 2014 | 08:39 PM
  #458
Frankieg35's Avatar
Should be fine as long as they fit..
Old Jan 7, 2014 | 10:46 PM
  #459
ChrisKG35's Avatar
yeah they do! Would i still be able to lay frame with them though? I just wanna run that set up for a few while I save up for some coils to complement my bags
Old Jan 7, 2014 | 10:59 PM
  #460
Frankieg35's Avatar
Not sure about that..
Old Jan 7, 2014 | 11:45 PM
  #461
bigc's Avatar
Wings Nation
You should be able to, but the best thing to do is to save up so you can do it all at once. Why do all the work twice (and pay the extra labor if you're not doing it yourself)?
Old Jan 8, 2014 | 06:47 PM
  #462
ChrisKG35's Avatar
That's true and I guess I would just like it ASAP, and I'd be doing it myself so I'd just be losing some hard work but that's always fun
But how long do you think the shocks would last with bags on them?
Old Jan 22, 2014 | 11:04 PM
  #463
g35loving's Avatar
Ok guys I have a few questions. I Recieved my kit from bagriders this week and trying to mock up my kyb shock and semi mock the rear kit. They are uas bags and looks like uas brackets possibly. So for the front the bottom plate is not slipping all the way down the shock. It is hitting the shock body. Do I just dremmel the hole bigger? Then for the rear kit. The kit I have has a bolt on one bracket and nothing on the other. If I screw the one bracket onto the bag it won't run but the other bracket will rub the bag. Does anyone have any suggestions or have pictures they can post? This is the hardest part I think to my kit. Everything else is plug n play. I am using the auto pilot v2 and comes with a pew built harness.
Old Jan 22, 2014 | 11:44 PM
  #464
g35loving's Avatar
Front figured out.
Old Feb 10, 2014 | 10:51 PM
  #465
Boostedef's Avatar
Sorry if the question has been asked before but is the Acuaair E Level the only auto system or is there another option ?
You have already rated this thread Rating: Thread Rating: 3 votes, 4.33 average.
