$160 labor cost for compression rod bushing replacement
Old Mar 30, 2011 | 01:02 PM
biochemist's Avatar
Hi, I received a quote for just the labor at $160 to replace both compression rod bushings at a service center near Chicago. Is this a reasonable price for the area? Thanks.
Old Apr 1, 2011 | 10:46 PM
VQEric's Avatar
I think that's pretty reasonable. I was quoted that much to replace just one lower control arm bushing, so I'm going to try doing both LCA bushings myself and also one compression rod bushing while I'm at it.
Old Apr 1, 2011 | 10:52 PM
WhosRich's Avatar
Reasonable. Price includes the uninstall compression rod/bushing removal/bushing replacement/install of the compression rod. Pretty labor intensive.
Old Apr 2, 2011 | 08:05 AM
biochemist's Avatar
Thank you for the feedback. Another specialty shop that works on Z's and G's quoted about the same price- ~$170..
Old Apr 2, 2011 | 12:42 PM
The Stimulation's Avatar
Why not just buy new arms that have the bushings? I would figure it would be cheaper to do that and install shouldn't be much.
Old Apr 2, 2011 | 03:52 PM
biochemist's Avatar
The bushings are less than $20 a piece online and even with the labor charge, it's half the price of buying the compression rods which cost over $300 for the pair plus labor to install.
Old Apr 2, 2011 | 04:30 PM
You can find them on ebay for under $100. Just recently I saw a pair go for $100 shipped.
Old Apr 2, 2011 | 04:58 PM
biochemist's Avatar
They were used rods. I haven't seen any new ones at that price.
Old Apr 3, 2011 | 01:20 AM
AuAltima3.5's Avatar
That's definitely a fair price.
The bushings are 60, so 100 for labor?
I wish I could a shop like that around here.
I did it myself, and it isn't bad if you an impact.
Old Apr 3, 2011 | 05:52 PM
biochemist's Avatar
Actually, I bought the bushings for $42 shipped online. $160 was just for labor.
Old Apr 3, 2011 | 05:56 PM
WhosRich's Avatar
Which bushings did you buy? Might as well get the SPL ones and get it done right the first time.
Old Apr 3, 2011 | 06:23 PM
thescreensavers's Avatar
Mr.202?
Its like an hour and a half of labor. on the tsb I believe
Old Apr 3, 2011 | 09:08 PM
biochemist's Avatar
Ended up buying the OEM Infiniti ones again from a dealer.
Old Apr 3, 2011 | 10:56 PM
the_sedan's Avatar
yeah but the dealer wont charge tsb time. thats factory warranty pay. this is customer pay so it will be more. and yes, it is labor intensive....more from changing the bushings rather than removing the part itself.
Old Apr 4, 2011 | 02:39 AM
prinny's Avatar
It's hard to find a shop that specializes or is good with aftermarket or uncommon installs and etc.
There's an awesome shop like 45 mins away from me that quoted me $160 for the compression rod bushings and the LCA bushings for $160. Then I went and called Pepboys and they didn't know wtf I was talking about. The guy had to spend like 10 minutes looking it up on the computer then he said $140 for the compression rod bushings and either $200 or $130 for the LCA. He wasn't sure, but I'm sure it was the $130 one. Still though.. that ridiculous.. going to do it myself.. even though $160 isn't bad at all.
MyfistYourFace
Aug 8, 2015 11:58 AM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
itschuckster
Jul 25, 2015 08:07 AM
cyrus32
Jul 18, 2015 06:22 PM
LoSt180
Jul 15, 2015 08:31 AM
