Could I use a table vise to remove control arm bushings?
Old Mar 3, 2014 | 09:41 AM
GMejia706's Avatar
I have a G35 Coupe with worn out front lower control arm bushings. Nissan refers it as the transverse link. I purchased some performence white line bushings. Would I be able to remove/replace the old ones with a giant clamp and vise table if i don't have access to a press??
Old Mar 3, 2014 | 10:34 AM
LoSt180's Avatar
Similar concept is to rent a bushing tool from AutoZone (usually free: pay deposit, get refund when tool is returned). Sometimes they don't have the correct size though, so might need to use a socket.
Old Mar 3, 2014 | 11:16 AM
GMejia706's Avatar
Thats what I meant by giant clamp sorry lol. Have you used this technique before?
Old Mar 3, 2014 | 11:18 AM
Urbanengineer's Avatar
Yeah... Can this be used to push out ball joints too (noob here)!
Old Mar 3, 2014 | 11:26 AM
LoSt180's Avatar
Yes, just haven't tried on the G35 yet though. Worked fine on a 240SX, Maxima, and G20. I would highly recommend using an impact gun though, turning a wrench will get tiring fast, don't care how strong you are.
Maybe, there's also some tool that's used for ball joints that looks like a claw.
Old Mar 3, 2014 | 11:44 AM
And "The Claw!" Can be used to put one back in?
Old Mar 3, 2014 | 11:47 AM
Egawd the local machine shop wants 20$ per bushing and 25$ per ball joint. That how much they cost for OEM
Old Mar 3, 2014 | 12:02 PM
LoSt180's Avatar
For whole new arms (with new bushings and ball joints), it would cost $200ea for compression rods and $206 for the lower control arms.
You can buy just the compression rod bushings for ~$25 ea from dealer. Not sure if you can get lower arm bushings stand alone though. Plenty of aftermarket bushings to choose from however.
Old Mar 3, 2014 | 12:08 PM
GMejia706's Avatar
I recommend white line bushings. Alot of good reviews on those aftermarket ones
Alex Koss
Oct 29, 2021 12:53 PM
rezendvous420
May 31, 2020 01:26 PM
nineiron
Sep 10, 2015 12:08 PM
erickLA
Aug 18, 2015 04:46 AM
Jussaku
Jul 29, 2015 11:45 AM
