G35 Front Strut Tower brace
VRT Pro Series G35 Front Strut Tower brace
I have finally finished having the jigs made for this G35 front mount strut tower brace. It is made of aircraft grade 4130 chromeoly and it is TIG welded and powder coated. It is strong and relatively light. They seem to fit on most after market CAI. This strut bar mounts to the actual suspension (instead of the sheet metal) for the best rigidity and torsionall support possible for increased handling. I am going to produce these for sale, available through me or VRT. They bolt on with the existing holes (no drilling needed) and the provided hardware. The install is not too complicated, with the only hard part being the replacing of the (longer) front upper control arm bolt.
If interested e-mail me at wa2good@hotmail.com
Check out the pics...... More pics of the install tomorrow.
on
on
that looks exactly like mine...sort of. i had to use extended A-arm bolts too. nice work.
http://members.***.net/chadisrad/strut.htm
Good work to you as well.
Originally Posted by dklau33
I see one leg bolting up to the shock tower. Where is the other leg going to?
You must be looking at the (unfinished pics) I will take some better ones in a little while.
If anyone is interested in one of these.... e-mail me at wa2good@hotmail.com
