Another G sedan with 350z suspension *PIX*
Old Mar 6, 2010 | 05:27 PM
  #271
NFSP G35's Avatar
? = 2B || !2B
^if you have red shocks, you have sport suspension.
Revised are a little sportier, that's what I have and I'm very happy with them.
Old Mar 6, 2010 | 05:32 PM
  #272
vipjd39's Avatar
nfsp1, thanks. No red shocks for me. So if I go with the revised, can i can them from any year 350z. I assume I will need the whole setup from shocks, springs, struts...
Old Mar 6, 2010 | 05:47 PM
  #273
NFSP G35's Avatar
? = 2B || !2B
Revised is only 04.5 year model Z and newer, and some of the coupe G with sport package (maybe all, not sure on that)
You can run the springs on your sedan shocks for a little while (like if you need to save up or something) but they will ruin them fairly quickly. If you want to keep OEM stuff, you def need to pickup springs/shocks/struts all together.
Old Mar 6, 2010 | 06:05 PM
  #274
vipjd39's Avatar
If I am wanting more of the level look should I look for revised z for the front and coupe sport package for the rears?
I would prefer to get them together so I only need to do one install.
Old Mar 6, 2010 | 06:35 PM
  #275
NFSP G35's Avatar
? = 2B || !2B
Coupe sport rears are exactly the same as 350z revised rears. The fronts are different.
The "level" look is from non-sport coupe springs in the rear.
Alternately, if you didn't want to lower it much, I have coupe front springs for cheap.
Old Mar 17, 2010 | 10:21 PM
  #276
vipjd39's Avatar
^All I can find that anyone has for sale are the unnrevised setups. Can i get the full unrevised setup and then the g35 sport coupe rears for the level look?
Old Mar 17, 2010 | 10:54 PM
  #277
NFSP G35's Avatar
? = 2B || !2B
^"revised" only applies to the rear suspension. 350z rears, revised or not, are going to lower the rear about an inch. G35 Coupe springs lower about a half inch, unless it's a coupe with the sport package. Then the rears are EXACTLY THE SAME as revised 350z rears. The fronts are different, but I don't have any information on them. I do have a pair though.
Old Mar 18, 2010 | 12:09 AM
  #278
olopez's Avatar
Here is mine
Old Mar 22, 2010 | 11:35 PM
  #279
Hammerhead i-Eagle Thrust's Avatar
Old Mar 24, 2010 | 05:59 PM
  #280
Matzo Ball's Avatar
I want to raise my rear a touch. Sedan S-Techs on the X was a bit aggressive a drop. Would the revised give me a good. 1-1.5" drop opposed to a 2" (looking for a 1.5-2 finger gap in the rear).
Old Mar 24, 2010 | 06:22 PM
  #281
olopez's Avatar
I have 06 revised Z springs & struts all around. Rear has a one inch gap (2 fingers)
Old Mar 24, 2010 | 06:47 PM
  #282
same here
Old Apr 2, 2010 | 08:51 PM
  #283
silvernm's Avatar
How can you tell the difference between revised z springs and unrevised z springs if the 350z is an '04?
Old Apr 2, 2010 | 09:49 PM
  #284
NFSP G35's Avatar
? = 2B || !2B
If the springs are off the car it's really easy, revised springs will have two red dots and one purple. If they're still on the car you'll have to find out if it's a 04.5. I'm not a z expert though so I'm not sure how to tell that. My cousin has a 04.5 though, I'll have him check his build date.
Old Apr 2, 2010 | 11:04 PM
  #285
silvernm's Avatar
thank you very much!
one more question, i have an 03 sedan with the sport suspension, would it be unadvisable to put the revised 350z springs on my car? i just found a set of 350z springs but they are the revised ones.
