Another G sedan with 350z suspension *PIX*
Old Apr 3, 2010 | 01:45 AM
  #286
NFSP G35's Avatar
? = 2B || !2B
^That should be ok. They will put a little more strain on your shocks though, but they shouldn't outright kill them like the non-sport shocks.
I would browse through this thread and others like it and PM any members you find that are running or have ran revised springs on sport shocks.
Ideally though, run 350Z shocks/struts if you can find them. That's what I did and everything has worked out great.
Old Apr 6, 2010 | 06:06 PM
  #287
Nicolai03's Avatar
rims?
what size rims are those?
Old Apr 6, 2010 | 07:09 PM
  #288
Hammerhead i-Eagle Thrust's Avatar
my rims?
Old Apr 14, 2010 | 01:31 AM
  #289
thescreensavers's Avatar
Mr.202?
Originally Posted by NFSP G35
^Oh nice. Thanks for that, that's really cool that your shop looked up the specs for the 350z!
Next time I have an alignment done, I'll just tell them to use 350Z specs
hmm sounds good, here they are
Left Front
Min Nominal Max
Camber -1.33 -0.58 -0.80
Caster 7.42 8.17 8.20
Toe 0.00 0.02 0.02
Right Front
Min Nominal Max
Camber -1.33 -0.58 0.17
Caster 7.42 8.17 8.92
Toe 0.00 0.02 0.04
Total Front
Min Nominal Max
Cros Camber -0.75 0.00 0.75
Cross Caster -0.75 0.00 0.75
Total Toe 0.00 0.04 0.08
Set Back
Left Rear
Min Nominal Max
Camber -2.08 -1.58 -1.08
Toe 0.02 0.04 0.05
Right Rear
Min Nominal Max
Toe 0.02 0.04 0.05
Total Rear
Min Nominal Max
Total Toe 0.4 0.8 0.11
Old Apr 14, 2010 | 07:58 AM
  #290
NFSP G35's Avatar
? = 2B || !2B
^Thanks. I'll save those.
Old Apr 30, 2010 | 03:14 PM
  #291
G35-Dan's Avatar
HELP PLEASE Z to G35X swap
I bought the set up off an 05 Z and thought it was a direct swap onto the G35X (06). My mechanic is telling me the front shocks don't bolt up the same way to the control arm and that he thinks the swap would only work on a RWD G. Anyone run into this before? What am I missing...
Old May 7, 2010 | 03:52 AM
  #292
Mr.202?
Originally Posted by RADIOGUY21
It depends. The unrevised 03-04 rear Z springs are about a 1/2" shorter than the 03-07 G35 coupe rear spring. So running an unrevised Z spring will be slightly lower on the sedan than a G35 rear spring. So yes there is a difference....
however, when they revised the Z and G spring to the 427lb rate in 2005, the Z spring was lengthened to the same length as the G35 rear spring. Both the 2005+ Z and G35 coupe rear springs are essentially the same, so there wont be any gap difference if you go the revised route.
IMO the rear G35 coupe or revised Z rear spring looks the best and offers a more even and balanced look.
oh wow I did not know that
Old May 7, 2010 | 10:39 AM
  #293
GAU-8's Avatar
Before install.
Stock G35 sedan spring vs. revised Z spring.
After install.
Old May 7, 2010 | 11:49 AM
  #294
NFSP G35's Avatar
? = 2B || !2B
I didn't know that either... I DID know the rear springs from the G Coupe with the SPORT pkg were the same (The ones that came with 19" Rays) because I compared the ones from a 2004.5 Z with a 2006 Coupe Sport and the rears were identical.
Oh, also of note, revised springs actually started in 2004.5 (on the Z at least) not 05.
Old May 9, 2010 | 09:51 PM
  #295
CAtoPA6mt's Avatar
so i've had a set of 350z springs to throw onto my 03 sedan, but i haven't been able to get someone to put them in around school in PA. i'm going to have my car out in the DC/Virginia and Maryland area this summer.. anyone who lives close want to help me out and make some money?
Old May 10, 2010 | 12:17 AM
  #296
just do it yourself...not that hard
Old May 10, 2010 | 12:20 AM
  #297
GAU-8's Avatar
Rent a spring compressor tool for the fronts and do the rest yourself. Maybe 2 hours of work on your own.
Old May 10, 2010 | 12:22 AM
  #298
the hardest part of the whole thing is wrenching the spring compressor..lol
Old May 10, 2010 | 12:28 AM
  #299
NFSP G35's Avatar
? = 2B || !2B
^+1 and ^^+1 and ^^^+1
Old May 10, 2010 | 01:21 AM
  #300
i miss having an impact gun
