5AT gear ratio options?
Old 03-04-2008, 03:38 PM
stillmatic's Avatar
Does anyone know if these Nissan 4.08 gears will bolt up to a 5AT 3.3 diff.. or do I need to have a 6MT diff in order to swap the gears out??
And, what is needed to swap a diff or gears from a 350z, assuming they're interchangeable.. Thanks!
Old 03-04-2008, 04:36 PM
crashnburn's Avatar
im curious bout this too.... i think us %at do have to get a 6 speed pumpkin and then build it.... im not sure though... this will be my next mod..... also would i need a retune if i get tuned b4 i do gears? i dont think i would
Old 03-04-2008, 04:44 PM
stillmatic's Avatar
No, retune is not necessary. Only cruise control and maybe VDC will be affected. Gas would probably go down 1-2 MPG, but would improve city driving since you can get out of 1st, 2nd, and maybe 3rd a lot quicker. But does anyone know if the 5AT pumpkin is compatible with different gears??
Old 03-04-2008, 04:51 PM
06PlatinumG's Avatar
The pumkins are the same, although there are some things you need to know inorder to make the change. Check out the link below
https://g35driver.com/forums/reviews/72134-review-quaife-installed-now.html
Old 03-04-2008, 05:11 PM
stillmatic's Avatar
^Good info, but a lot of mixed information. Still not sure if different gears (3.7, 3.9, 4.08) will bolt right up to a 5AT 3.3 pumpkin without additional parts..
The Central 20 3.9 gears specifically states that it won't bolt up to a 5AT diff.
Old 03-04-2008, 05:13 PM
crashnburn's Avatar
im pretty sure they all work except for the 3.9.. all the others are stock on other nissans
Old 03-04-2008, 05:17 PM
stillmatic's Avatar
Yeah, it's confusing because on this website, it says the 4.08 gears are designed for cars with M/T.
Old 03-04-2008, 06:44 PM
DaveB's Avatar
I wish someone with a 2003 sedan would install some 3.5 to 3.7 gears to see if the CC still works. I could have sworn there were at least two accounts of 2003-2004 5AT sedans running 3.54 gears and the CC wouldn't work above ~72mph. I believe the issue was the CC was set to read rpm vs the wheel sensor speed. With the deeper gears, the rpms were higher in relation to wheel sensors therefore the ECU thought you were trying to set the CC at too high a speed. I believe the preset limit for CC is approximately 88mph. Apparently this isn't an issue with the 04.5+ cars unless OCG35 is setting the CC at only 60mph.
Old 03-04-2008, 06:47 PM
Klubbheads's Avatar
I know for a fact that in my 04.5 cruise control does NOT work in speeds above 90mph. I can try to set the cruise control in a lower gear see if its from the RPM reading or the actuall speedo reading.
Old 03-04-2008, 06:50 PM
crashnburn's Avatar
my cruise will set at 120mph on my 03 and it set at 145 on my 03 350z.... maybe the 03 didnt have a limit?...is there anyway to fix the cruise yet? not that it will keep me from doin the mod....i was going to do 4.08 but now im leaning more towards 3.9
Old 03-04-2008, 06:56 PM
shabarivas's Avatar
6mt ftw
Old 03-04-2008, 08:21 PM
sliderg35's Avatar
I have a Quaife Diff with 3.5 gears from a 6mt. They work great. The stock pinion gear for the AT is thicker than the MT. That is the only difference and that's why you can't just switch the gears. If you want to use the gears from an MT, you need to take the diff from a VLSD MT and you can use any of the gears that are made for the MT. (Or you can get a Quaife like I did)
Oh, and the CC still works fine.
Old 03-04-2008, 08:31 PM
stillmatic's Avatar
^Thank you, sir!
Old 03-05-2008, 08:29 PM
OCG35's Avatar
I haven’t had any issues with CC... not sure if I've used it above 88mph though - but definitely above 60... I guess if I can remember I'll check next time I drive the car...
Old 03-06-2008, 01:00 AM
DaveB's Avatar
I just did a search and sure enough, there at least three accounts of 03/04 sedans and one coupe having CC issues after installing the 3.5 gears. The CC will work to about 72mph and if you try to accelerate with it on and go over 72mph, it will turn off and won't come back on until you restart the car.
Quick Reply: 5AT gear ratio options?
