DIY 03 G35 Coupe 5AT to 07 G35S 5AT differential swap
Old Nov 20, 2011 | 10:38 PM
  #226
SDGenius's Avatar
2nd Gen 6MT, direct swap. 2nd Gen 5AT works w/pinion shaft modifications
Old Nov 21, 2011 | 05:23 PM
  #227
SuperTrooper699's Avatar
Alright man thanks i appreciate it. so if this guy is saying its a locking Diff that means it has LSD?
Old Nov 21, 2011 | 05:44 PM
  #228
ronniepetras's Avatar
I feel vibration after the install when I'm going 75-80mph
Old Nov 21, 2011 | 05:54 PM
  #229
and you just installed a 3.7? i wonder why?
Old Nov 21, 2011 | 06:42 PM
  #230
Yeah. Idk hopefully I get some answers
Old Nov 25, 2011 | 12:37 PM
  #231
pae9132's Avatar
What tool was used to remove the pinion nut? If you used a regular socket can you tell me what size? thanks everyone!
Old Nov 26, 2011 | 09:43 PM
  #232
pae9132's Avatar
Angry bump +
ok so I'm using a 30mm socket but how the hell have you guys gotten off the pinion nut....the damn flange just keeps spinning......another question....i think I might have messed up by already switching the diff fluid...will this fluid come out with the flange removed? thanks in advance
Old Nov 26, 2011 | 09:49 PM
  #233
herrschaft's Avatar
^I stuck a screwdriver through the flange which kept it from moving, and yes the fluid will leak with the flange off. If you keep the diff tilted back then it won't leak anything.
Old Nov 27, 2011 | 02:02 PM
  #234
pae9132's Avatar
Angry This sucks...
ok well i started work on my diff switch and it's a m****r f****r....if you are going to do this then make SURE that you have deep well sockets....even on the sway bar nut I'm stuck until my wife comes back with the other car....in addition to that I have a Stillen cat-back exhaust which is another pain in the ***....it's twin pipes are directly under my diff....well it's going to sit how it is until I can get more tools....good luck to everyone else trying this with a sedan
Old Nov 28, 2011 | 05:09 PM
  #235
pae9132's Avatar
Question Please help!!!
Ok well i ended up taking off my exhaust but now I'm stuck on the drive axle bolts...can somebody please tell me how you got them off...and if you had to turn the drive axle did you do it without starting the car? thanks in advance!
Old Nov 28, 2011 | 06:15 PM
  #236
herrschaft's Avatar
^Put the car in neutral and simply turn the drive shaft via the wheels. The E-brake will apply enough pressure to brake the nuts loose, its the same with the axle bolts. My car was in neutral the entire time I did the swap.
Old Dec 7, 2011 | 04:35 PM
  #237
pae9132's Avatar
Thank you!
Thanks herrschaft for the help....I've had it complete for about a week now and it's a HUGE difference....I can say it's the best mod I've done....
Old Dec 20, 2011 | 09:07 PM
  #238
Irrelevant's Avatar
Okay...yesterday I received a 3.7 VLSD from a 2008 G37 AT. $400 shipped. I'll be undertaking the swap sometime in the next few weeks...sooner, I hope.
Looks like about three hours is a reasonable time to budget for this?
From reading this thread, it sounds like I'll have to cut the input shaft a little. Anyone think a Dremel will do the job, or do I need to buy a die grinder/cutoff wheel combination? Maybe I could rent one instead.
For those who've done this swap at home, how are you supporting the car while working underneath it? I'm thinking jack it up at the differential, then place jackstands under the jack points on the unibody. I'm not a huge fan of crawling around under cars supported by jackstands, but without access to a lift, I don't see an alternative.
Thanks to those who've contributed information so far on this swap.
Old Dec 25, 2011 | 03:24 PM
  #239
Dsskyline's Avatar
Where did you find one with VLSD for that price? All the ones I've found are open diff.
Old Dec 25, 2011 | 04:37 PM
  #240
Irrelevant's Avatar
It took a lot of searching, but eventually I found someone who was parting out a totaled 2008 G37 Sport Coupe over on myG37.com.
Good luck with your search. Wish me luck finding the time to install the one I have!
